Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Rostock 3D printer — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Robotics
Rostock 3D printer
jdolecki
726
2012-12-16 12:03
edited 2013-02-18 21:09
in
Robotics
Not wanting to be left out I've decided to build a 3d Printer
http://www.thingiverse.com/thing:17175
98K
94K
Martin_H
4,051
2012-12-16 13:51
edited 2012-12-16 13:51
What are you using for the spherical bearings? Those seem like the most critical part of a rostock.
jdolecki
726
2012-12-16 14:22
edited 2012-12-16 14:22
Basically they are just plastic ujoints with 3mm screws for axles.
There are a few built with the rod ends from rc trucks.
I will try it stock for now.
I would like to make all thebrackets in aluminum but I will see how the printed ones work.
Mark_T
1,981
2012-12-16 16:57
edited 2012-12-16 16:57
The Geomag construction kits have a great solution to this issue, they have magnets embedded in plastic tubes that stick to ball bearings but allow rotation:
http://www.ebay.co.uk/itm/geomag-color-42-/261142345744?pt=UK_Construction_Toys_Kits&hash=item3ccd4bf810
The motion is pretty smooth and on excess force developing the joint falls apart (perhaps less damaging than the alternative, perhaps not).
jdolecki
726
2013-01-09 05:52
edited 2013-01-09 05:52
Finished building the hot end. Its a combination of several styles I found on the web.
The 2 large holes are for the resistors and the 1 small is the temp sensor. The aluminum is .625 square I had laying around.
There are many examples of people using a brass acorn nut for a nozzle I will try that before i machine a nozzle.
Drilled a .039 (1mm) hole to start
1024 x 765
99K
99.1K
jdolecki
726
2013-01-20 18:08
edited 2013-01-20 18:08
Last week a video link was posted on the other forums I hang in showing how to make the feeder bolt.
I machined a fixture the hold the bolt and bearings to clamp it in my small mill
I used a 8/32 tap and applied cutting lube.
Here is the results.
I will get some more bolts and experiment with different taps and see which on works best.
1024 x 765
70K
1024 x 765
62K
1024 x 765
46K
69.6K
62.4K
45.8K
jdolecki
726
2013-01-20 18:46
edited 2013-01-20 18:46
Arduino Mega with ramps board plugged in on top. LCD panel with control knob.
1024 x 765
97K
1024 x 765
82K
1024 x 765
105K
96.7K
81.9K
105.2K
prof_braino
4,313
2013-01-21 12:07
edited 2013-01-21 12:07
Looking good!
vanmunch
568
2013-02-04 10:33
edited 2013-02-04 10:33
Ya, very cool!
jdolecki
726
2013-02-10 17:31
edited 2013-02-10 17:31
My filament extruder need work but it is making some parts.
My filament feeder need some fine tuning.
And I have begun designing a filament machine to extrude filament from raw plastic pellets because a roll of filament is sooooo expensive
Here is the cad of the prototype.
1024 x 576
58K
58.4K
prof_braino
4,313
2013-02-18 21:09
A guy in Chicago is offering $40,000 for a the first pelet extruder design.
http://inventables.blogspot.com/2012/05/40k-desktop-factory-competition-to-make.html
I don't think anybody has claimed the prize yet, I hope you succeed!
Sign In
Register
to comment.
