LS, C, HC series
Hey,
I'm drawing up a schematic in ExpressPCB, and in my actual project, I have Low-power Schottky, CMOS, and High-speed CMOS series logic chips. I probably shouldn't have mixed types, but they're what I can get to right now.
In ExpressPCB's component library, there are only components for the LS series. As one would expect, I don't think that creating custom parts for each series of the logic chips is efficient. Are the LS, C, and HC series all pin compatible with each other? If so, I could just use the components for the LS series.
If I were you, I'd look up specific datasheets for the parts you're using, just to make sure, but I imagine you're just fine.
Good idea...
LS is rated for 4.5 volts to 5.5 volts supply, a threshold of 0.5 volts, and typically a drive current for ten LS inputs. Similar for AS, S, F, ALS ...
HC is rated for 2.0 volts to 6.0 volts supply, a threshold of 50% of supply voltage, and typically a drive current for ten HC inputs. Similar for AC, BC ...
C is somewhat orphaned, it's electrically identical to the 4k series, it is rated for 3.0 volts to 15.0 volts supply, a threshold of 50% of supply voltage, and typically a drive current for ten C inputs.
Then you get the HCT and ACT variants that have HC drives but with 0.5 volt thresholds. And further there is the low voltage variants that explicitly target the 1 volt to 3 volt supply ranges.
I always check each one.
Duane J
I'm not quite following, is this question for schematic symbols, or real. physical parts ?
Generally, parts with the same derivative part number are 100% pin-compatible - but this is quickly checked on the net.
On Symbols, it is common to have Generic TTL library parts, that are placed and tagged with a specific part number.
So a /04 symbol, could be labeled as any of HC04/HCT04/HCU04/AHC04/LVC04/VHC04/LVX04/LV04 .....
If you are talking about mixing physical parts, 'C' parts tend to be low drive, and may struggle into a LSxx device
- eg you will see data tags like this
Fan out of 2 driving 74L
- best to simply bin the dinosaur parts, and get at least HC, as then you can cover 3V and 5V.
