UART between two micro controllers.
Hi,
I have connected ATmega32a to AT90USB1287 using UART and AT90USB1287 to PC using USB.
Intially,
AT90USB1287 is talking to the PC via USB.
ATmega32A is talking to the PC via USART(RS232).
Now i have connected ATmega32A board to AT90USB1287 using UART communication(RS232 cable by disabling connection to PC) Because both boards has to work together with one PC. Easiest way is UART connection between those two.
If i want to send data from ATmega32A to PC means, I have to get data from ATmega32A to ATusb901287 and send it to PC via USB.
[FONT=Tahoma, Arial, sans-serif]I have implemented UART functionality for both controllers.
The problem is i am not able to send the command that i got from PC to AT90USB1287 via USB. the command will be in USB receive buffer. I have to send the command to another micro controller using UART of AT90usb1287.
I have the fallowing code.
Intially,
[/COLOR][/FONT]
#include <90usb1287.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <ctype.h>
#include <interface.h>
#define CMD_SIZE 9
flash unsigned char * flash cmdList[CMD_SIZE] = {
"", // [0] no com
"INF", // [1] Displayes version date etc.
"TEMP", // [1] Displayes temp etc.
"RESET",
"GOTO_BOOT",
"SETID",
"SENS1", // [1] Displayes sensor1 etc.
"USB", // [1] Displayes usb etc.
"DISP", // [1] Displayes calibration etc.
//this was implemented by me ////
C O M U N I C A T I O N RS-232
unsigned char SerIn[SIBUFSIZE]; // Input buffer (raw data)
unsigned char RxCnt; // Location of next byte to be written
unsigned char RdCnt; // Location of next byte to be read
unsigned char BufCnt; // Size of unread contents in ring buffer
unsigned char CompIndex; // Index in Copmare array
unsigned char Compare[COMPBUFSIZE]; // Command string tokenizer
unsigned char Command; // Current Command is executed
unsigned int Param; // Parameter used in command
float Param2; // Optional (second) parameter used in command
unsigned long Param3; // Optional (third) parameter in command
extern unsigned char Plot;
unsigned char Step;
//extern unsigned char state;
//extern unsigned int status;
//extern unsigned char debug;
#define RXB81 1
#define TXB81 0
#define UPE1 2
#define OVR1 3
#define FE1 4
#define UDRE1 5
#define RXC 7
#define FRAMING_ERROR (1<<FE1)
#define PARITY_ERROR (1<<UPE1)
#define DATA_OVERRUN (1<<OVR1)
#define DATA_REGISTER_EMPTY (1<<UDRE1)
#define RX_COMPLETE (1<<RXC)
//USART1 Receiver buffer
#define RX_BUFFER_SIZE1 32
char rx_buffer1[RX_BUFFER_SIZE1];
#if RX_BUFFER_SIZE1<256
unsigned char rx_wr_index1,rx_rd_index1,rx_counter1;
#else
unsigned int rx_wr_index1,rx_rd_index1,rx_counter1;
#endif
// This flag is set on USART1 Receiver buffer overflow
bit rx_buffer_overflow1;
// USART Receiver interrupt service routine
interrupt [USART1_RXC] void usart1_rx_isr(void){
char status;
status=UCSR1A;
// data=UDR1;
SerIn[RxCnt] = UDR1;
if ((status & (FRAMING_ERROR | PARITY_ERROR | DATA_OVERRUN))==0)
rx_buffer1[rx_wr_index1]=SerIn[RxCnt];
if (++rx_wr_index1 == RX_BUFFER_SIZE1) rx_wr_index1=0;
if (++rx_counter1 == RX_BUFFER_SIZE1)
rx_counter1=0;
rx_buffer_overflow1=1;
#ifndef _DEBUG_TERMINAL_IO_
// Get a character from the USART Receiver buffer
#define _ALTERNATE_GETCHAR_
#pragma used+
char getchar(void){
char data;
while (rx_counter1==0);
data=rx_buffer1[rx_rd_index1];
if (++rx_rd_index1 == RX_BUFFER_SIZE1) rx_rd_index1=0;
#asm("cli")
--rx_counter1;
#asm("sei")
return data;
#pragma used-
#endif
////// USART Transmitter buffer
#define TX_BUFFER_SIZE1 32
char tx_buffer1[TX_BUFFER_SIZE1];
#if TX_BUFFER_SIZE1<256
unsigned char tx_wr_index1,tx_rd_index1,tx_counter1;
#else
unsigned int tx_wr_index1,tx_rd_index1,tx_counter1;
#endif
//// USART Transmitter interrupt service routine
interrupt [USART1_TXC] void usart1_tx_isr(void){
if (tx_counter1){
--tx_counter1;
UDR1=tx_buffer1[tx_rd_index1];
if (++tx_rd_index1 == TX_BUFFER_SIZE1) tx_rd_index1=0;
//#asm("WDR"); // For long words and slow baud-rates
//// Write a character to the USART Transmitter buffer
#define _ALTERNATE_PUTCHAR1_
#pragma used+
void putchar(char c){
//chz c = getcharb();
while (tx_counter1 == TX_BUFFER_SIZE1);
#asm("cli")
if (tx_counter1 || ((UCSR1A & DATA_REGISTER_EMPTY)==0)){
tx_buffer1[tx_wr_index1]=c;
if (++tx_wr_index1 == TX_BUFFER_SIZE1) tx_wr_index1=0;
++tx_counter1;
else
UDR1=c;
#asm("sei")
#pragma used-
#endif
// USB Receive
void catchString(void){
while(UEBCLX){
if(++BufCnt >= SIBUFSIZE){ // Increment & check for buffer overflow
BufCnt = SIBUFSIZE-1; // Set to max value
// printf("!Overflow\r\n");
// UENUM = 2;
return; // Skip char
}else{ // Else: if buffer ok
if(++RxCnt >= SIBUFSIZE) RxCnt = 0; // Increment read counter, if 10 -> 0 (max 9)
SerIn[RxCnt] = UEDATX; // Write to SBUF (load the transmit register)
//// Read from ringbuffer
char getcharb(void){
if(BufCnt){ // If anything
BufCnt--; // Decrement buffer counter
if(++RdCnt >= SIBUFSIZE) RdCnt = 0; // Increment read counter, if 10 -> 0 (max 9)
return SerIn[RdCnt]; // Read from SBUF (access receive register)
return 0;
void help(void){
unsigned char i;
printf("Commands: ");
for(i=0;i<CMD_SIZE;i++){
printf(cmdList[i]);
printf(", ");
}printf("\r\n");
S T R I N G T O K E N I Z E R
Searches the input buffer for valid commands
returns the id of the command if a match is found or 0 if no cmd
void getcom(void){
unsigned char c;
// Read from ring-buffer and fill in Compare buffer
while(BufCnt){ // while unread contents in ring-buffer
c = getcharb(); // fetch next byte
if(CompIndex >= COMPBUFSIZE) CompIndex = 0;// overflow protection
// Analyze char
if(c == '#'){ // Manual start
CompIndex = 0;
}else if(c == '\r'){ // CR continue (end of cmd without argument)
Compare[CompIndex]='\0'; // fill in end character of comp string
break; // possible valid cmd received -> check out
}else if(c == '\n'){ // New line (ignore)
// Do nothing (ignore)
}else if(c == 8){ // Backspace
if(CompIndex) CompIndex--; // decrement index
}else if(c == 9){ // Horizontal TAB
help(); // Write out cmds
}else if(c == 27){ // ESC button
Command = 0; // Stop current command
Param = 0; // Clear argument
Plot = 0; // Stop plotting
Step = 0;
}else{
Compare[CompIndex++]=c; // Default action: Store character
}if(!BufCnt) return; // if no more data to read -> exit
}CompIndex=0; // reset, ready for next command
c = 1;
while(c<CMD_SIZE){ // For each command
if(strncmpf(Compare,cmdList[c],strlenf(cmdList[c])) == 0) break;
c++;
if(c<CMD_SIZE){ // If match on normal commands
Command = c;
if(isdigit(Compare[strlenf(cmdList[c])])){
Param = atoi(&Compare[strlenf(cmdList[c])]);
c = strpos(Compare,':');
if(c > 0){
Param2 = atof(&Compare[c+1]);
c = strrpos(Compare,':');
if(c > strpos(Compare,':')) Param3 = atol(&Compare[c+1]);
else Param3 = 0;
}else{
Param2 = 0;
Param3 = 0;
}else{
Param = 0;
Param2 = 0;
Param3 = 0;
printf("@%s\r\n",&Compare); //Ack command
}else{
printf("&E;1;\r\n"); // Command not found
printf("->Unknown command: '%s'\r\n",&Compare); // If no match
Command = 0;
Param = 0;
Param2 = 0;
Param3 = 0;
[FONT=Tahoma, Arial, sans-serif][COLOR=#000000]
[/FONT]
It is a big world and supporting each and every AVR and ATmega chip in every possible configuration has a different support culture.
It looks like there has been some help given on this school project already on AVRFreaks (and StackExchange, and All About Circuits etc). Kind of a shotgun blast approach to asking for help.
Conceptually, it seems the UARTs are all working. So it is a matter of polling the buffers and moving data along. The middle device has to have two Rx and Tx buffers - a pair for the RS232 and a pair for the USB. Data has to cross over from a Rx buffer to a Tx buffer in order to move along in either direction.
If that is all you want to do, it is rather simple. But if you want to have the communications change to a different configuration, you need to have some idea of what is going to drive that change and what is going to be a default configuration.
I do have my own AVR projects unrelated to Parallax products and I wouldn't not expect to get someone here to sort out my code. Same goes for my CubieBoard and my TINI ds80c400.
