is .35 volts at 35 amps possible?
I am working on a project with a friend - and he's done the math and says we need .35 volts at 35 amps and I told him I didn't think it was possible and that nothing exists that would do that
so I'm looking to be set straight or looking for back up
Jamie
Jamie
The fact that it's possible doesn't make it practical. That's not much resistance. You need pretty large wires made of very conductive material to keep the circuit resistance below 10 milliOhms total over any significant distance. You need fairly large area connectors, again using very conductive material, to make connections ... and not too many such connectors. Another issue ... how are you going to get that much power produced at that voltage with that sort of low source resistance. Remember that any sort of power generation device has its own internal resistance.
If you've got a load of 10 milliOhms that you need to run 35 Amps through, you can generate the 35 Amps at a higher voltage and compensate for the voltage drop through your wires and across any connectors as well as compensate for the generator's internal resistance. This is commonly done by using a voltage regulator and measuring the voltage to be regulated at the load itself. The regulator takes into account any voltage drops across wiring and connectors, etc. Remember that 35A through any conductor is going to generate a significant amount of heat. The bigger the conductor, the less the resistance and the less heat would be produced. Think about automotive starter cables or plugs/wiring for electric dryers or ovens.
we need that wire to get to more than 260 degrees Celsius so that's (apparently) 35 amps? (I really know nothing of nichrome wire)
the end goal is to build a better heating element for 3d printers
The single cell solar cells parallax sells put out ~.6v at ~ 5 amps each. You could use an array and store the collected energy in a supercap (array) and chop it out from there to get 0.35v average.
Or you could modify a classic linear power supply stage (mains->transformer->bridge rectifier->capacitor->dc out) to use two transformers, ie two 10:1 gives 110:11v followed by 11v to 1.1v, then rectify and chop from there. You'd waste heat in your rectifiers but you could manage that.
Ok, so its for 3D printing. The 3v3 rail of an ATX power supply should put out ~30 A, you could just store that in a big supercap and chop the output and let the nichrome wire itself smooth it out thermally.
the Nichrome wire said it had a resistance of 1.67 per foot so I *assumed* I would divide that to get the ohms for an inch - could be completely wrong there
but the consensus I'm hearing is that it's doable - glad I'm wrong about that then
the big thing for me was wasting time on something that was impossible - but if it's possible then I'll work it out
Thanks for the info guys!
Duane J
You're playing around with quite a bit of power ... as others have mentioned, there's not a lot of difference between what you're handling and an arc welder.
Duane J
The more popular choice these days is a 5.6Ohm, 5W Resistor embedded in the printhead itself.
http://reprap.org/wiki/J_Head_Nozzle
As the resistor is inside the head, heat transfer can be made much more efficient.
You'll be dumping around 12W into that little piece of wire, and you'd need THICK (4mm square or more) cables from the PSU to the head...
The 5.6Ohm resistor draws around .9A at 5V (4.46W) to heat up.
In fact, almost any AC transformer has space to add a turn or two of heavy gauge wire (or wire braid) around the core.
it doesn't burn in air when at orange heat.
Anyway I think this is all academic because a bare wire heater will cause localised overheating and charring of the plastic, a
heated nozzle is probably most reliable as a copper tube with an insulated heater winding around it - spreading the heat evenly
over a large surface area and in a way that is compatible with temperature sensing - temperature control is all important surely?
A while ago, I designed an analog circuit that would regulate the temperature of a heater by maintaining its resistance, then had an output voltage proportional to the power going into the heater; the intent, at the time was as a hot-wire mass-airflow meter.
I'm not really here to discuss exactly what or how I'm trying to build the hot end - the hot end I have now has the resistor and that's fine - but I'm trying to build something different... may not work out that it's any better (or works at all) but that doesn't mean I'm not going to try some different things
please note that this one idea is not the whole part of my idea - just one little part
I do appreciate all the suggestions and advise - but I'm not going to discuss my master plan just yet - I just wanted to know about the voltage at that amperage
Thanks for understanding
Jamie
http://hackaday.com/2012/11/03/hijinks-at-50000-amps/
It wouldn't do what you require, but it looks fun.
Lawson
