W5200: Possible Gotcha & Fix
Hey Mike:
I've been experimenting & stress testing, came across an issue but think I have a fix.
In tens words or less it appears buff can overrun by a byte if the wiz buffer fills up. I discovered the problem when I was moving stuff around and using a variable for a website name. At some point I ended up with...
...and then I started experiencing intermittent failures with the DNS portion of REPEATed DHCP-DNS-TCP stress test. Looking closer I could see the first byte of the site variable getting clobbered...
Below is code I think you can use to confirm. It's essentially the TCSDDD demo modified to REPEAT the entire DHCP-DNS-TCP sequence.
On my setup the first byte of the site variable gets clobbered as above on the second iteration. If you look down in the code you can see the way I force it fail by inserting a pause after the GET insuring the wiz buffer fills with 2KB...
...note that, on my setup, taking out the pause will generally allow the loop to work but it eventually fails (I think depending whether the wiz buffer happens to fill). As well, reversing the order of the site and buff variable declaration allows the loop to run - in this case I think buff+1 may have been clobbering the next var in line (t1) but gone unnoticed.
I've tried this fix...
...and it seems to be working but don't know if it's as simple as that.
Otherwise software seems rock solid, I've run thousands of DHCP-DNS-TCP test cycles at this point.
buff byte $0[BUFFER_2K] site byte "finance.google.com", $0
Getting network parameters Requesting IP.....10.0.0.157 Lease Time........86400 DNS...............10.0.0.1 DHCP Server.......10.0.0.1 Router............10.0.0.1 Gateway...........10.0.0.1 DNS Init (bool)...-1 DNS Lookup........finance.google.com Resolved IP(0)....74.125.224.64 Resolved IPs......11 Initialize Socket Begin Client Web Request Connecting to.....74.125.224.64 Sending HTTP Request Bytes Sent........99 Bytes Received....7066 Disconnect Getting network parameters Requesting IP.....10.0.0.157 Lease Time........86400 DNS...............10.0.0.1 DHCP Server.......10.0.0.1 Router............10.0.0.1 Gateway...........10.0.0.1 DNS Init (bool)...-1 DNS Lookup........ Resolved IP(0)....0.0.0.0 00 69 i 6E n 61 a 6E n 63 c 65 e 2E . 67 g
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
{ Protocol }
#0, CLOSED, TCP, UDP, IPRAW, MACRAW, PPPOE
{ PST Display }
CR = $0D
LF = $0A
BUFFER_2K = $800
ATTEMPTS = 5
{ Serial IO PINs }
USB_Rx = 31
USB_Tx = 30
{ Run time DHCP and DNS socket paramters }
DHCP_SOCKET = 7
DNS_SOCKET = 6
VAR
DAT
request byte "GET /index.htm HTTP/1.1", CR, LF, {
} byte "User-Agent: Wiz5200", CR, LF, CR, LF, $0
request2 byte "GET /default.aspx HTTP/1.1", CR, LF, {
} byte "Host: agaverobotics.com", CR, LF, {
google byte "GET /finance/historical?q=FB&output=csv HTTP/1.1", CR, LF, {
} byte "Host: finance.google.com", CR, LF, {
weather byte "GET / HTTP/1.1", CR, LF, {
} byte "Host: [URL="http://www.weather.gov"]www.weather.gov[/URL]", CR, LF, {
t1 long $0
null long $00
OBJ
pst : "Parallax Serial Terminal"
wiz : "W5200"
sock : "Socket"
dhcp : "Dhcp"
dns : "Dns"
PUB Main | bytesToRead, buffer, bytesSent, receiving, remoteIP, dnsServer, totalBytes, i, dnsInit
if(ina[USB_Rx] == 0) '' Check to see if USB port is powered
outa[USB_Tx] := 0 '' Force Propeller Tx line LOW if USB not connected
else '' Initialize normal serial communication to the PC here
pst.Start(115_200) '' [URL]http://forums.parallax.com/showthread.php?135067-Serial-Quirk&p=1043169&viewfull=1#post1043169[/URL]
pause(500)
pst.str(string("Initialize W5200", CR))
wiz.QS_Init
'Loop until we get the W5200 version
'This lets us know if the W5200 is ready to go
i := 0
repeat until wiz.GetVersion > 0
pause(250)
if(i++ > ATTEMPTS*5)
pst.str(string(CR, "SPI communication failed!", CR))
return
pst.str(string("WizNet 5200 Ver: ") )
pst.dec(wiz.GetVersion)
pst.char(CR)
wiz.SetMac($00, $08, $DC, $17, $62, $ca)
REPEAT
receiving := true
bytesToRead := 0
dnsInit := 0
pst.str(string("Getting network parameters", CR))
dhcp.Init(@buff, DHCP_SOCKET)
' pst.str(string("--------------------------------------------------", CR))
'SetRequestIp allows us to request a specific IP - No guarentee
'dhcp.SetRequestIp(192, 168, 1, 110)
' t1:=0
pst.str(string("Requesting IP....."))
repeat until dhcp.DoDhcp(true)
if(++t1 > ATTEMPTS)
quit
if(t1 > ATTEMPTS)
pst.char(CR)
pst.str(string(CR, "DHCP Attempts: "))
pst.dec(t1)
pst.str(string(CR, "Error Code: "))
pst.dec(dhcp.GetErrorCode)
pst.char(CR)
pst.str(dhcp.GetErrorMessage)
pst.char(CR)
return
else
PrintIp(dhcp.GetIp)
{ Stress test
repeat
t1 := 0
'wiz.SetIp(0,0,0,0)
repeat until dhcp.RenewDhcp
if(++t1 > ATTEMPTS)
quit
if(t1 > ATTEMPTS)
pst.char(CR)
pst.dec(t1)
pst.char(CR)
pst.char(CR)
return
else
PrintIp(dhcp.GetIp)
'pause(2000)
pst.str(string("Lease Time........"))
pst.dec(dhcp.GetLeaseTime)
pst.char(CR)
pst.str(string("DNS..............."))
dnsServer := wiz.GetDns
PrintIp(wiz.GetDns)
pst.str(string("DHCP Server......."))
printIp(dhcp.GetDhcpServer)
pst.str(string("Router............"))
printIp(dhcp.GetRouter)
pst.str(string("Gateway..........."))
printIp(wiz.GetGatewayIp)
pst.char(CR)
pst.str(string("DNS Init (bool)..."))
pst.dec(dns.Init(@buff, DNS_SOCKET))
pst.char(CR)
pst.str(string("DNS Lookup........"))
pst.str(@site)
pst.str(string(CR,"Resolved IP(0)...."))
'remoteIP := dns.ResolveDomain(string("[URL="http://www.agaverobotics.com"]www.agaverobotics.com[/URL]"))
remoteIP := dns.ResolveDomain(@site)
'remoteIP := dns.ResolveDomain(string("[URL="http://www.weather.gov"]www.weather.gov[/URL]"))
PrintIp(remoteIP)
if (byte[remoteIP][0] + byte[remoteIP][1] + byte[remoteIP][2] + byte[remoteIP][3]) == 0
REPEAT i from 0 to 17
pst.hex(byte[@site][i],2)
pst.char(" ")
pst.char(byte[@site][i])
pst.char(CR)
return
pst.str(string("Resolved IPs......"))
pst.dec(dns.GetIpCount)
pst.char(13)
pst.char(13)
'remoteIP := dns.GetResolvedIp(1)
pst.str(string("Initialize Socket"))
sock.Init(0, TCP, 8080)
sock.RemoteIp(byte[remoteIP][0], byte[remoteIP][1], byte[remoteIP][2], byte[remoteIP][3])
sock.RemotePort(80)
'PrintIp(wiz.GetRemoteIP(0))
pst.str(string(CR, "Begin Client Web Request", CR))
'wiz.setGateway(0,0,0,0)
'Client
'pst.str(string("Open Socket", CR))
sock.Open
sock.Connect
pst.str(string("Connecting to....."))
pst.char(CR)
'Connection?
repeat until sock.Connected
pause(100)
pst.str(string("Sending HTTP Request", CR))
'bytesSent := sock.Send(@request2, strsize(@request2))
bytesSent := sock.Send(@google, strsize(@google))
'bytesSent := sock.Send(@weather, strsize(@weather))
pst.str(string("Bytes Sent........"))
pst.dec(bytesSent)
pst.char(13)
pause(3000) 'wait for wiz buff to fill
totalBytes := 0
repeat while receiving
'Data in the buffer?
bytesToRead := sock.Available
totalBytes += bytesToRead
'Check for a timeout
if(bytesToRead < 0)
receiving := false
pst.str(string("Timeout", CR))
' return
if(bytesToRead == 0)
receiving := false
'pst.str(string(CR, "Done Receiving Response", CR))
next
if(bytesToRead > 0)
'Get the Rx buffer
buffer := sock.Receive(@buff, bytesToRead)
' pst.str(buffer)
bytesToRead~
pst.str(string("Bytes Received...."))
pst.dec(totalBytes)
pst.char(CR)
pst.str(string("Disconnect", CR, CR))
sock.Disconnect
pause(5000)
PUB DisplayMemory(addr, len, isHex) | j
pst.str(string(13,"-----------------------------------------------------",13))
pst.str(string(13, " "))
repeat j from 0 to $F
pst.hex(j, 2)
pst.char($20)
pst.str(string("-- "))
pst.char(13)
repeat j from 0 to len
if(j == 0)
pst.hex(0, 4)
pst.char($20)
pst.char($20)
if(isHex)
pst.hex(byte[addr + j], 2)
else
if(byte[addr+j] < $20 OR byte[addr+j] > $7E)
if(byte[addr+j] == 0)
pst.char($20)
else
pst.hex(byte[addr+j], 2)
else
pst.char($20)
pst.char(byte[addr+j])
pst.char($20)
if((j+1) // $10 == 0)
pst.char($0D)
pst.hex(j+1, 4)
pst.char($20)
pst.char($20)
pst.char(13)
pst.char(13)
pst.str(string("Start: "))
pst.dec(addr)
pst.str(string(" Len: "))
pst.dec(len)
pst.str(string(13,"-----------------------------------------------------",13,13))
PUB PrintIp(addr) | i
i := 0
repeat i from 0 to 3
pst.dec(byte[addr][i] & $FF)
if(i < 3)
pst.char($2E)
else
pst.char($0D)
PRI pause(Duration)
waitcnt(((clkfreq / 1_000 * Duration - 3932) #> 381) + cnt)
return
pst.dec(bytesSent)
pst.char(13)
pause(3000) 'make sure wiz buf fills
totalBytes := 0
BUFFER_2K = $801
Is the $800+1 byte always the same value?
1000 passes is not too shabby.
