Capacitor Ident
Say I have some Ceramic-Disk Capacitors, and the only markings on them are :
Y5U
104m
I know the 10 ( with 4 trailing zeros in picos ) .01uF cap.
But how do I determine what its max voltage rating is ?
Y5U
104m
I believe that 104 is going to be by-pass capacitors for your Propeller at 5 or 3.3 volts, right. I would not worry about it. Ceramic capacitors are usually rated way above that.
Size generally indicates the capacitor will handle more voltage. But aside from the tiny super-capacitors, just about everything is made for more than 5 volts.
Googling around, I found something that may indicate the Y5U is a ceramic capacitor product line with a 25v or 50v rating. And the m indicates 20% variation.
Thank you,
Thats' Kind of what I figured. Like resistors you really don't know the watt rating, just guess by the size..
Thanks again.
The voltage rating is a separate spec entirely and is not typically indicated on the package of ceramic caps (probably due to a lack of room for it).
So when You open up a bin with a bunch of random caps in it ;x What do you normally do, Hook one up to a Power supply and keep stepping up voltage tell you pop it ( then u know the volt rating ) ? I kind of do this with random leds when I dont know there voltage or
current specs I just hook them up to my psu and step up voltage, tell the Led seems to be in its Operating range look at current I am supplying and then calculate My Resister, and Supply voltage based off that...
I am still very Green when It comes to actual electronics.
Radio Shack often buys in bulk and sometimes doesn't label complete information as the people doing the packaging of components may not know what is considered complete information.
I try not to deal of junk bins and buy only stuff that has all the information. But I think we all end up with some extra ceramic caps that have no clear voltage rating.
Sure, you find a voltage that enables the component to let out the magic blue smoke, but that may be way higher han the component's rated max voltage.
Another component of the same make/model/whatever may send smoke signals at half that voltage, or maybe at 50% higher...
And the function may be 'erratic' for quite a while before that.
Or they may simply fail after a few months of being used outside of specs.
Lawson
So buying 1000's of ceramic caps and randomly throwing them into bins is not a good idea ;x (I do this often with resistors) Guess Ill try to organize them via voltage rating somehow....
Thanks for the suggestion
The family of barium-titanate, lead-titanate and lead-zirconium-titanate ceramics are the principal ferroelectrics - being the electric equivalent of ferromagnetic, and
thus have _very_ high dielectric constants, non-linear reponse, hysteresis, high losses and furthermore change shape in response to the applied field (as the crystal unit cell is
distorted in the direction of the polarization). Thus all high-value ceramic capacitors can be expected to be "microphonic" (and are not a good choice for handling low
amplitude signals! Though fine for decoupling). Nice description of ferroelectricity on wikipedia BTW.
For lower value ceramics the dielectric need not be ferroelectric, and these are usually much more accurate / low-loss / stable (for instance values in the sub 100pF range
are typically like this unless extremely high voltage).
