Hidden BS2 Code
bluejay
Whenever there's power in a Stamp, a program code is always running until a new code is written over. Is there a way to see the code that' sstored in the BS2 by using some special keys or keystokes on the keyboard or by using the Debug screen? In other words, how would someone find out what the current code is stored if someone forgot it?
Thanks in advance for a response.
Longer answer No, but if you want to see a hex dump of most of the eprom there is a way to that. This will not get you code you can read though.
