Inexpensive 180 degree metal gear servo
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=27725
I just got some nice Turnigy 180 degree servos from HobbyKing for $4.57 each.
Shipping was about 2 weeks.
Turnigy metal gear analog mini servo with 180 degree stop to stop movement.
180 degree rotation is perfect for pan and tilt camera mounts or any other articulated application. This servo also offers good torque, speed, excellent centering and a great price!
The gear train is all metal.
Specs:
Weight: 12g
Torque: 2.0kg.cm (6.0v)
Speed: 0.12sec/60deg (4.8v) - 0.10 sec/60deg (6.0v)
Voltage: 4.8-6.0v
Type: Analog Micro
Gear Train: Metal
Ball Bearing: No
Lead Length: 180mm
Plug: JR/Futaba
Specs:
Weight: 12g
Voltage: 4.8-6.0v
Type: Analog Micro
Gear Train: Metal
Ball Bearing: No
Lead Length: 180mm
Plug: JR/Futaba
Thanks for posting.
I once used HobbyKing faster shipping service (IIRC "EMS"). With the faster method the shipping was less than a week. It's usually about three weeks for me.
I have some of the Hextronik HXT900 but only got 90 degrees which is why I searched for 180 degree ones. (they are the same physical size).
These guys?
Edit: I just noticed the servos you linked to are also micro servos.
Have you tried pulses outside the normal 1000us to 2000us range?
I think both erco and I have videos on the forum showing these servo move just over 180 degrees. I can probably find at least one of these videos if you're interested.
Duane, I tested them using a BS2 and I get 180 with the Turnigy and 90 with the HXT900
'{$STAMP BS2} '{$PBASIC 2.5} minval CON 300 maxval CON 1200 stepval CON 50 x VAR Word y VAR Word servo PIN 0 here: FOR y=minval TO maxval STEP stepval ' DEBUG CLS, DEC y,CR PULSOUT servo,y PAUSE 20 NEXT PAUSE 1000 FOR y=maxval TO minval STEP stepval ' DEBUG CLS, DEC y,CR PULSOUT servo,y PAUSE 20 NEXT PAUSE 1000 GOTO here
In the video, I'm using 300us and 3000us as endpoints.
Here's another video showing the range of motion of the HXT900 servos. I dont' think I had the endpoints set at the absolute extremes since I was trying to get smooth motion from the servos. They look like they are turning just under 180 degrees.
The BS2 does easily drive this Turnigy 180 degrees using the PULSOUT command (see code in post #6)
With a HXT900 hooked up to your BS2, try having your "y" go from 150 to 1500 instead of 475 and 1000.
This should be about the same as my 300us to 3000us pulses. I wouldn't try it on your metal gear servo. It might over drive it.
Do you have a QuickStart board? If so try out my servo tester program. I included some instructions to post #2 (IIRC) of the thread. It will let you change the end points on the fly.
I played around with the values and ranging from 300 to 1200 gives me pretty close to a 180 degree sweep with the HXT900.
Thanks for the suggestions.
Don't have a QuickStart board - need to get one someday - the touch buttons would be handy...
- Ron
