lib1funcs.asm won't compile.
Heater.
I just cloned propgcc (rev. 3a2a070bb63b of 24th Nov) and rebuilt the performance branch on Debian Squeeze with gcc (Debian 4.4.5-8) 4.4.5
The build failed when gcc/gcc/config/propeller/lib1funcs.asm would not assemble. Turns out gas does not like underscores in hex constants. Here is the diff I made to fix it:
Also, as this was a new install of Debian I had to install libncurses5-dev before propgcc would build.
diff -r 3a2a070bb63b gcc/gcc/config/propeller/lib1funcs.asm
--- a/gcc/gcc/config/propeller/lib1funcs.asm Sat Nov 24 09:54:35 2012 -0400
+++ b/gcc/gcc/config/propeller/lib1funcs.asm Tue Dec 04 13:37:59 2012 +0200
@@ -147,15 +147,15 @@
'-------------------- constant values -----------------------------------------
-Mask23 long $007F_FFFF
-Bit28 long $1000_0000
+Mask23 long $007FFFFF
+Bit28 long $10000000
endfloat
.section .kernel
.global __Bit31
-__Bit31 long $8000_0000
+__Bit31 long $80000000
.compress default
.text
Eric
What Propeller binutils?
That was the first clone and build of propgcc on a new install of Debian. The machine had never seen propgcc before.
binutils is included in the propgcc repository, so if you did a fresh checkout and build you should have gotten the most recent version. I don't understand why your build would be any different. If I get a chance I'll try downloading Debian and see if there's anything unusual in that environment.
Eric
The big change here is that I now have Squeeze instead of my old Lenny. It's a brand new install as my old disk committed suicide last week.
