Door access card reader and BS2p
Hi,
I would like to read 125kHz Wiegand cards to get the user ID. I have a BS2p available, but from reading the forums I see that the BS2 is not fast enough to read the Wiegand output from this type of card reader.
The card reader I have does not have an RS232 output, but it can output in clock/data format, which is a synchronous form of serial communication, where the clock as well as the data is supplied from the card reader. This means I can't use the SHIFTIN command, as the BS2 provides the clock.
Anyone know of another way I can get the info from the card reader into the stamp?
Is the mentioned 125kHz the frequency of data coming from the Wiegand card?
Keep thinking out loud though!
