Anyone having SNTP / RTC issue on Spinneret today?
Hey all,
Yesterday the sntp protocol on my spinneret worked fine. Today, I keep getting 31/12/2013 for the date (Dec 31, 2013)
I'm trying to troubleshoot it and I'm pretty sure it's the sntp object that isn't calculating it correctly. But if anyone else is getting the correct date after using SNTP then I guess that's not the issue (using the same object of course.)
DAT approot byte "\", 0 defaultpage byte "index.htm", 0 logfile byte "log.xml", 0 binFile byte $0[13] binDir byte $0[9] loadFile byte $0[13] 'note FS byte "/", 0 crlf byte 13, 10, 0 crlf_crlf byte 13, 10, 13, 10, 0 tempNum byte "0000",0 numBuff ੲ摩猽彬癳㑮弲㐲ਵ㸊琼⁤汣獡㵳猢畯捲≥㰾牢㰾琯㹤⼼牴㸊琼ੲ摩猽彬癳㑮弲㐲ਸ਼㸊琼⁤汣獡㵳猢畯捲≥‾†䐠⁄㴺䠠⁈ 㐲††††††††††††⌦㤳☻瑬ⴻ搠祡⁳桴獩礠慥
Somehow, between the last time I saved and shutdown the propeller tool just now, I got the HTTPServer object file corrupted or something, shown above. wth??
Also- earlier today, I was able to get something outta pst. Shown below:
PRI GetSntp(id) | tempMask 'pst..str(string(13, "GET SNTP Time")) tempMask := tcpMask SetTcpSocketMaskById(id, 0) Socket.Close(id) pause(delay) 'pst..str(string(13, "Initialize UDP Socket")) InitializeSntpUdpSocket(id) pause(delay) 'pst..str(string(13, "Request Time")) if GetSntpTime(id, @tempBuff) ' Decode 64-Bit time from server pst.Str(String("Got this")) '≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈ if sntp.GetTransmitTimestamp(Zone,@tempBuff,@LongHIGH,@LongLOW) '(Offset,BufferAddress,Long1,Long2) pst.Str(String("Got something")) else pst.Str(String("Got nothing")) ' Display Reference/Sync TimeZone corrected Time '≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈ 'DisplayHumanTime ' Set RTC to Internet Time 'pst..str(string(13, "SET RTC")) '≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈≈ {{ rtc.SetDateTime(byte[@MM_DD_YYYY][3], { <- Month } byte[@MM_DD_YYYY][2], { <- Day } word[@MM_DD_YYYY][0]-2000, { <- Year } byte[@DW_HH_MM_SS][3], { <- (day of week) } byte[@DW_HH_MM_SS][2], { <- Hour } byte[@DW_HH_MM_SS][1], { <- Minutes } byte[@DW_HH_MM_SS][0]) { <- Seconds } }} ''PUB writeTime(second, minute, hour, day, date, month, year) rtc.writeTime(byte[@DW_HH_MM_SS][0], { <- second } byte[@DW_HH_MM_SS][1], { <- minute } byte[@DW_HH_MM_SS][2], { <- hour } byte[@DW_HH_MM_SS][3]+2, { <- (day of week) } byte[@MM_DD_YYYY][2], { <- date } byte[@MM_DD_YYYY][3], { <- month } word[@MM_DD_YYYY][0]) { <- year } pst.str(string("test")) pst.newline pst.dec(byte[@MM_DD_YYYY][0]) pst.Newline pst.dec(byte[@MM_DD_YYYY][1]) pst.Newline pst.dec(byte[@MM_DD_YYYY][2]) pst.Newline pst.dec(byte[@MM_DD_YYYY][3]) pst.Newline ' Reset the socket Socket.Disconnect(id) pause(delay) 'Socket.SocketClose(id) 'pause(delay) ' Reset the tcpMask tcpMask := tempMask InitializeSocket(id) pause(delay) return
It's interesting that you got "13/229/2013" from the rtc.readTime though.... My date is 31/12/2013 but if I use pst as I've shown above:
The pst.Dec(byte[@MM_DD_YYYY][X]) showed the values 7, 221, 229 and 13. I don't remember which order now, and I also get nothing but 0's now. I haven't changed the code since earlier, at all.
(I'm still trying to figure out how HumanTime does everything, so in the mean time I wrote a sample that works. It's clunky and nothing to be proud of, but it does work. I'm going to see if I can adapt it for use in the sntp object soon.)
In case anyone needs to get the sntp functionality on the spinneret working quickly, here's my sample. It might help you figure out a much better way to do it.
{{ SAMPLE: *Alternative way to use UTC seconds to determine date from an NTP time server. *Does NOT adjust for daylight savings time. *Does NOT work after feb 29th, 2020 unless you place 2020 as a condition for leap year. *Here is a good website for calculating UTC. http://www.mbari.org/staff/rich/utccalc.htm *Example: April 23, 2015, 8:25:49 GMT would be a UTC value of 1429777549 Enter this UTC value in pst and it'll spit out the date and time. If you're in Eastern time zone, it'll tell you 3:25:49 if you have -5 in the Zone constant. }} CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 utc2010 = 1262304000 'This is the UTC seconds value of Jan 1, 2010, 0:00 hours Zone = -5 'Time zone in relation to GMT. example: EST = GMT-5, so enter -5 for this constant. VAR long day,month,year,hours,minutes,seconds OBJ pst: "parallax serial terminal" pub Main pst.Start(115_200) pst.Str(String("Starting...")) pst.Newline repeat pst.Str(String("Enter UTC seconds value:")) seconds:=pst.DecIn pst.Dec(seconds) Get_Date pst.NewLine pst.Str(String("Year: ")) pst.Dec(year) pst.NewLine pst.Str(String("Month: ")) pst.Dec(month) pst.NewLine pst.Str(String("Day: ")) pst.Dec(day) pst.NewLine pst.Str(String("Hours: ")) pst.Dec(Hours) pst.NewLine pst.Str(String("Minutes: ")) pst.Dec(Minutes) pst.NewLine pst.Str(String("Seconds: ")) pst.Dec(Seconds) pst.NewLine pst.Str(String("-----------------")) pst.NewLine pst.NewLine pub Get_Date seconds-=utc2010 'Subtract the value of utc2010 from the value we got from the time server. seconds+=(Zone*3600) 'Adjust the value again for our time zone. year:=2010 'This is our starting year. Month:=1 '...our starting month. day:=1 '...our starting day. repeat while seconds=>86400 'More than a day in seconds left? If (month==1) and (seconds=>86400) 'Month is 1 and more than a day in seconds left? if ((daycounter(31))== 31) AND (seconds=>86400) 'Did we max our day value for the month? month:=2 'move to next month Day:=0 'set first day value to 0 If (month==2) and (seconds=>86400) and ((year==2012) OR (year==2016)) 'same as above- leap year?? if ((daycounter(29))== 29) AND (seconds=>86400) month:=3 Day:=0 If (month==2) and (seconds=>86400) if ((daycounter(28))== 28) AND (seconds=>86400) 'same as above- not a leap year?? month:=3 Day:=0 If (month==3) and (seconds=>86400) 'same for all remaining months if ((daycounter(31))== 31) AND (seconds=>86400) month:=4 Day:=0 If (month==4) and (seconds=>86400) if ((daycounter(30))== 30) AND (seconds=>86400) month:=5 Day:=0 If (month==5) and (seconds=>86400) if ((daycounter(31))== 31) AND (seconds=>86400) month:=6 Day:=0 If (month==6) and (seconds=>86400) if ((daycounter(30))== 30) AND (seconds=>86400) month:=7 Day:=0 If (month==7) and (seconds=>86400) if ((daycounter(31))== 31) AND (seconds=>86400) month:=8 Day:=0 If (month==8) and (seconds=>86400) if ((daycounter(31))== 31) AND (seconds=>86400) month:=9 Day:=0 If (month==9) and (seconds=>86400) if ((daycounter(30))== 30) AND (seconds=>86400) month:=10 Day:=0 If (month==10) and (seconds=>86400) if ((daycounter(31))== 31) AND (seconds=>86400) month:=11 Day:=0 If (month==11) and (seconds=>86400) if ((daycounter(30))== 30) AND (seconds=>86400) month:=12 Day:=0 If (month==12) and (seconds=>86400) if ((daycounter(31))== 31) AND (seconds=>86400) year:= year+1 'Still have more seconds? Increment year and start over. month:=1 Day:=0 Get_Time pub daycounter(maxday) repeat while (seconds=>86400) seconds-=86400 day++ if day == maxday quit return day pub Get_Time Hours:=0 Minutes:=0 repeat while (seconds=>60) seconds-=60 minutes++ if minutes == 60 hours++ minutes:=0
