Chip antenna versus wire antenna
Anyone have any comments or experiences with either they would like to share? Advantages or disadvantages of either. Obviously the chip version allows for a more compact design.
Thanks.
Don
Thanks.
Don
http://www.parallax.com/tabid/829/Default.aspx
and read the article linked to in the paragraph beginning "the range of the modules...".
(that article is the .pdf that Leon mentions below, and it does make an attempt to quantify the difference, though they're pretty tentative about the results)
I had the chance to talk about this a few times with Digi, XBee manufacturer.
Digi offers about 70-80 variants of the XBee with at least four antenna styles. The most common are the chip and wire antenna. The wide variety is available because of customer-specific preferences.
From the datasheets you may not find specifics, but the very general impression I've had from engineers at Digi is that the wire antenna provides "a bit more range" though they don't quantify it for us.
From a sales standpoint, we sell about 40% more wire antenna XBees than chip antenna.
Parallax Inc.
I know it is dependent on how much range one is looking for etc.
@Ken- the sales indicator is a good tool to go by as well. Thanks for sharing.
Re. the wire antennas' sturdiness, I've crashed a couple in rockets without damaging them. I have an XBee with wire antenna here that has been in a rocket that hit the ground twice at well over 40 MPH and it still works perfectly. I'm sure the chip is sturdier, but the wire is not as delicate as it may look.
