BoeBot Ping navigation program — Parallax Forums
EleutherEleuther Posts: 20
edited 2012-11-28 16:16 in General Discussion
Hi I was wondering if the Boe Bot were to encounter something with the Ping sensor is there a way to program the bot to randomly choose to turn right or turn left or something better? Please help thanks.
    edited 2012-11-27 16:32
    Don't see why not, just use the random function to select the choice of left or right
    The only thing is you want to avoid an obstacle so moving randomnly may cause you to hit the obstacle
  • EleutherEleuther Posts: 20
    edited 2012-11-27 16:38
    thx for the advice. I tried the random thing but I don't know how to set up the program for that. Do you know how?
    edited 2012-11-27 16:54
    In the Basic Syntax and reference manual the random command section shows a demo program that chooses "heads or tails" you could adapt this to select right or left
    edited 2012-11-27 17:23
    You ask so many questions, young Grasshopper. Please show us what you have done (code, videos) so we can assist you.
    edited 2012-11-27 18:40
    ok so I looked that up and it helped me understand it better but I still dont know how I would set it up and where to put what.
    edited 2012-11-28 14:32
    There is also the Roaming with the PING))) code which, when an object is detected causes the BOE-Bot to do a scan across 180 degrees to find the most open path. If you don't have the PING))) mounting bracket you could instead change the code so that the whole robot turns to find the most open path.
    edited 2012-11-28 14:36
    I have that program and have used it many times but I want something more smooth.
    edited 2012-11-28 14:38
    here is my code that I have been experimenting with.
    ' File...... RoamingWithPING.bs2
    ' Purpose... Roam And Scan Using PING))) Mounting Bracket
    ' Author.... Parallax, Inc.
    ' E-mail.... support@parallax.com
    ' Started...
    ' Updated... 12-21-2005
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    [ Program Description ]
    ' This programs demonstrates roaming with the Parallax PING))) Mounting
    ' Bracket, which allows you to pan-scan with your Parallax PING))) sensor.
    ' This program assumes you have already set your BOE-Bot up for roaming
    ' with IR sensors. You must also have the PING))) Mounting bracket
    ' installed as per the instructions, with the servo connected to P14 and
    ' the PING))) sensor connected to P15.
    ' Due to the way the PING))) bracket mounts you may have to trim your IR
    ' detectors down so that they don't stick up in the way of the moving
    ' PING))) bracket as it rotates. It's best to angle them off at 45
    ' degree angles so that the BOE-Bot doesn't run into anything while
    ' moving along a wall at a narrow angle.
    ' The BOE-Bot will now roam around and when it senses an object, it will
    ' scan within a 180 degree field of view for the clearest path, which it
    ' will then navigate scanning for an object again. The IR Sensors prevent
    ' hitting a wall when coming at it from a narrow angle where the PING)))
    ' might have trouble seeing it due to the lack of reflection of sound.
    ' Calibration is important to this code working properly. If you do not
    ' have the correct values for your servos then you may get strange results
    ' from your BOE-Bot. The necessary calibration information is listed in
    ' each section of the code where it is required.
    [ Revision History ]
    ' This code is basically a modified version of the Roaming With IR code
    ' from the Robotics With The BOE-Bot Manual, written by Andy Lindsay.
    ' Much of the original code was left untouched so you can see how it was
    ' altered.
    [ I/O Definitions ]
    Piezo PIN 4 ' Piezo Speaker
    RightServo PIN 12 ' Right Servo
    LeftServo PIN 13 ' Left Servo
    PingServo PIN 14 ' PING))) Servo
    Ping PIN 15 ' PING))) Sensor
    [ Variables ]
    pulseCount VAR Byte ' Used For Measuring Turns
    distance VAR Word ' Current Distance Of Object
    oldDistance VAR Word ' Old Distance Value
    counter VAR Word ' PING))) Cycle Counter
    task VAR Nib ' button input
    flip VAR Word ' a random number
    coin VAR flip.BIT0 ' Bit0 of the random number
    trials VAR Byte ' number of flips
    Left VAR Byte ' throws that come up heads
    Right VAR Byte ' throws that come up tails
    btnWrk VAR Byte
    [ Initialization ]
    FREQOUT Piezo, 300, 2000
    PAUSE 10 ' Signal Program Start/Reset
    FREQOUT Piezo, 300, 1500
    PAUSE 10
    [ Program Code ]
    DO
    counter = counter + 1 ' Increment Passive Counter
    IF counter > 5 THEN ' Wait For 10 Servo Pulses
    GOSUB Ping_Out ' Activate PING)))
    ENDIF
    IF (distance > 1) THEN
    RANDOM flip
    ELSEIF Left THEN
    GOSUB Turn_Left
    ELSEIF Right THEN
    GOSUB Turn_Right
    ELSE
    GOSUB Forward_Pulse ' Otherwise Scan For Clear Path
    ENDIF
    LOOP
    [ Subroutines ]
    ' * USE THE APPROPRIATE PULSOUT VALUES TO MAKE YOUR BOE-BOT MOVE FORWARD *
    ' * WHILE THE PING))) IS FACING FORWARD. *
    Forward_Pulse: ' Send A Single Forward Pulse
    PULSOUT PingServo, 690 ' Ping Servo Forward Pulse Value
    PULSOUT LeftServo, 850 ' Left Servo Forward Pulse Value
    PULSOUT RightServo, 650 ' Right Servo Forward Pulse Value
    PAUSE 20 ' Refresh Delay
    RETURN
    ' * USE THE APPROPRIATE PULSOUT VALUES TO MAKE YOUR BOE-BOT TURN LEFT 90 *
    ' * DEGREES. USE THE SAME VALUE AS ABOVE FOR THE PING))) BRACKET SERVO. *
    Turn_Left: ' Left Turn, About 45 Degrees
    FOR pulseCount = 0 TO 1 ' Number Of Pulses To Turn
    PULSOUT PingServo, 840 ' Ping Servo Forward Pulse Value
    PULSOUT LeftServo, 650 ' Left Servo Left Pulse Value
    PULSOUT RightServo, 650 ' Right Servo Left Pulse Value
    NEXT
    RETURN
    ' * USE THE APPROPRIATE PULSOUT VALUES TO MAKE YOUR BOE-BOT TURN RIGHT 90 *
    Turn_Right: ' Right Turn, About 45 Degrees
    PULSOUT PingServo, 460 ' Ping Servo Forward Pulse Value
    PULSOUT LeftServo, 850 ' Left Servo Right Pulse Value
    PULSOUT RightServo, 850 ' Right Servo Right Pulse Value
    NEXT
    RETURN
    ' * USE THE APPROPRIATE PULSOUT VALUES TO MAKE YOUR BOE-BOT MOVE BACKWARD *
    Back_Up: ' Back Up
    FOR pulseCount = 0 TO 40 ' Number Of Pulses To Backup
    PULSOUT PingServo, 750 ' Ping Servo Forward Pulse Value
    PULSOUT LeftServo, 650 ' Left Servo Backup Pulse Value
    PULSOUT RightServo, 850 ' Right Servo Backup Pulse Value
    NEXT
    RETURN
    Ping_Out: ' PING)))
    counter = 0 ' Reset Passive Delay Counter
    LOW Ping ' Force PING))) Line Low
    PULSOUT Ping, 5 ' Activate PING))) Pulse
    PULSIN Ping, 1, distance ' Receive Return Pulse
    distance = distance ** 2257 ' Calculate Distance
    RETURN
    Ping_Around: ' Start 180 Degree Pan-Scan
    oldDistance = 30 ' Current Old Distance Values
    task = 0
    ' Current Task Priority
    ' * USE THE APPROPRIATE PULSOUT VALUE TO MAKE YOUR PING))) *
    ' * TURN 90 DEGREES LEFT. *
    FOR pulseCount = 0 TO 20 ' Number Of Pulses To Spin
    PULSOUT PingServo, 1085 ' Ping Servo 90 Left Pulse Value
    PULSIN Ping, 1, distance ' Receive Distance Value
    NEXT
    distance = distance ** 2257 ' Calculate Distance In cm
    IF distance > oldDistance THEN ' Is distance > Last Clear Path
    oldDistance = distance ' Update oldDistance Value
    task = 1
    ENDIF
    ' * TURN 45 DEGREES LEFT. *
    PULSOUT PingServo, 850 ' Ping Servo 45 Left Pulse Value
    NEXT
    task = 2
    ENDIF
    ' * TURN 45 DEGREES RIGHT. *
    PULSOUT PingServo, 400 ' Ping Servo 45 Right Pulse Value
    NEXT
    task = 3
    ENDIF
    ' * TURN 90 DEGREES RIGHT. *
    PULSOUT PingServo, 225 ' Ping Servo 90 Right Pulse Value
    NEXT
    task = 4
    ENDIF
    ON task GOSUB Task0, Task1, Task2, Task3, Task4
    distance = 50 ' Prevent Scan From Looping
    RETURN
    Task0: ' Forward Was Clearest Path
    GOSUB Turn_Right ' This Could Mean Narrow Path
    GOSUB Turn_Right ' So We'll Turn Around
    GOSUB Turn_Right ' You Can Change The Behavior
    GOSUB Turn_Right ' Of Any Of The Tasks
    RETURN
    Task1: ' 90 Degrees Left Was Clearest
    GOSUB Turn_Left
    GOSUB Turn_Left
    RETURN
    Task2: ' 45 Degrees Left Was Clearest
    GOSUB Turn_Left
    RETURN
    Task3: ' 45 Degrees Right Was Clearest
    GOSUB Turn_Right
    RETURN
    Task4: ' 90 Degrees Right Was Clearest
    GOSUB Turn_Right
    GOSUB Turn_Right
    RETURN
    edited 2012-11-28 15:50
    Eleuther wrote: »
    How is it working? Do you like how the robot behaves?
    I added an ultrasound sensor to my Scribbler 2. I also wondered about adding some sort of S turns so it didn't have to stop to look for an openning. One more thing to add to robotics todo list (which includes a robot todo my todo lists).
    BTW, it's a lot easier to read code if you use code blocks. Here's link to a tutorial by Phil.
    well it doesn't work, I'm still making tweaks to it.
