Let's Make a Robot Do These Maneuvers
Bicycle trials riders do such amazing maneuvers. Watch the first two minutes of this video. Where would you even begin to make a robot attempt anything close to these? Multiple gyros, accelerometers, IMUs, PID, machine vision, IDK? First, call Sebastian Thrun...
Duane, here's an extreme case where I'll admit, the software is harder than the hardware. There, I said it.
The words easier and simpler seem to understate the problem....it's still a great challenge but it's all in relatives terms!
I have worked with the 2D accelerometers from Parallax... way back. And if programmed right, I think they are stable enough and fast enough to contribute useful data. I was able to get inertial data that was stable over a 3 mile road course in a car... but everything I have read about gyro's gives me pause. Never looked at them but I don't think they have good enough long term accuracy for a robot that could do this any old time... maybe in the beginning. or the robot could rest while it was regaining its gyro senses.
All of the really good stuff about quad copters seems to use external vision to figure out the where and when of everything... at the hobby level that would be a kinect box... which is really interesting and really works nicely in the right light with the right contrast at the right distance but with somewhat less than the claimed accuracy. Hooking it up to a Prop...through a computer... using Processing.org is fairly painless and the data you get could keep you busy for years.
And you can build yourself a graphical interface ... to plot out your moves... and it is all free. Speed is an issue, particularly if you have lots of code... it sits right there in the main event loop clogging everything up.
Processing.org v1.5 works well with serial up to 115K baud. Setting up for bluetooth was easy peasy... so xbee shouldn't be a problem.
