Jeff Martin and the Free Energy Quadrature Decoder.
Thank you, Jeff Martin, for you free energy quadrature encoder object http://obex.parallax.com/objects/24/. I was about to run out of cogs... and was beginning to wonder if I was ever going to build
my own electric car. Jeff Martin to the rescue... freed up my cogs and restored my faith in my future.
Here's the story ... I was building the worlds cheapest telepresence robot, Zippy http://www.peanutbutter.com/, entirely out of peanut butter lids, 2 falhaber motors, a Chinese bluetooth and a wireless camera that I picked up a one of the unofficial Propeller meetings... total investment (excluding controller) , $16. The motors require two counters each, the serial com 1 cog, and the quad encoders two counters each. Not really a problem, but for my personal vehicle, I'm going to want 4 motors and encoders... hopes wained... until I found Jeff's ancient object, written in the early days.... all the encoders I want... 1 cog.
Hooked everything up... except I forgot the 5V and ground to the encoders... and one of the encoders still worked:) No kidding, swear to God, hope to die if I lie.
That is one hell of an object there Jeff.
Hey guys, what's up with this?
Rich
Rich
You're welcome Rich! Glad my object helped you.
I certainly didn't design it to be a "free energy" object.
Thanks for the response, that is one beautiful object.
1. The two encoders WERE identical. They are part of a Faulhaber geared motor from the Electronic Goldmine (thank you erco). There is now a generic form of it for $3. I have fifteen of them lying around:)
David Cook has a nice write up: http://www.robotroom.com/FaulhaberGearmotor.html. The motor and encoders
are supplied by separate sources and have separate connections. I had the motor power supplied with 7.4v and running full tilt, but the 5v supply for the encoders was not hooked up at all
(no wires present!!!).
2. I hacked one apart, and it appears to be a magnet based sensor... so, I was wondering if a current was being generated by the spinning magnet, with my input pin acting as a drain or maybe there is a short...
3. I don't see how... they weren't hook up:) This was a first for me... usually I hook them up backwards. This time, I just forgot about them altogether.
4. I don't have an oscilloscope... gave it away since I never seemed to need it:) Have my eye on a PropScope for Christmas.
Rich
