Blink problem
bluejay
Would somebody please tell me why when I turn a simple led on my Stamp2 blink blinks every few seconds? Is it a common problem? Can I put a code to stop it on my initial program? This problem does not occur when there is a loop in the coding. I would appreciate a response.
You can put a STOP command at the end of your program and it will keep running. Or a program loop
DO : LOOP
It won't go to sleep.
'example
HIGH 15
The_end
GOTO The_end
That will not work as typed. This, however, does:
HIGH 15
blazes:
GOTO blazes
That little colon identifies any alphanumeric string as a label.
