xbee not recieving proper values — Parallax Forums
graffixgraffix Posts: 389
edited 2012-11-25 21:06 in Accessories
Ive been struggling with some code for awhile.Ive taken the code Ive been working with and ommited alot of it to try and simplify the process and Im still struggling with it.Currently I'd like to get two parallax 2 axis joysticks to control a boe's drive wheels. Via xbee modules. I dont think there is any wiring issues, just code. Basically one joystick controls up-down values and the other left right values. Sent to the boe via xbee modules. Both codes have debug commands. The controller gives good values in its debug window. The recieving boe does not display the same values in its debug window. They also dont refresh at the same rate. Im attaching some code for each and a video. If someone can look it over and suggest a fix that would be great. Thanks ahead of time. If you have any questions please ask. Ps I already have all the demo code and different variations.
http://www.youtube.com/watch?v=ab_NkBmQvtg&feature=plcp
'recieving boe
'{$STAMP BS2}
'{$PBASIC 2.5}
' -----[ Constants ]-------------------------------------------------------
L_FWD     CON  1000
L_REV     CON  500
L_STOP    CON  750
R_FWD     CON  500
R_REV     CON  1000
R_STOP    CON  750
BAUD_MODE CON  84 '9600 Baud, 8n1 true
'---Variables-------------------------------------------
UD               VAR     Byte
LR               VAR     Byte
a                VAR     Word
b                VAR     Word
c                VAR     Word
d                VAR     Word
e                VAR     Word
f                VAR     Word
i                VAR     Byte
rx_data          VAR     Byte
'---Pin Descriptions------------------------------------
xbee_rts         PIN     9
xbee_Rx          PIN     10    ' Dout
xbee_Tx          PIN     11    ' Din
Rwheel           PIN     13
Lwheel           PIN     12
'---initializations------------------------------------
LOW Lwheel
LOW Rwheel
'---main program------------------------------------------
DO
  SERIN XBee_Tx, 84, [UD,LR]
  DEBUG HOME, "UD =", DEC UD, CLREOL, CR,
  "LR = ", DEC LR, CLREOL
  SELECT UD
    CASE  < 270
      UD = a
      GOSUB forwards
    CASE  > 400
      UD = b
      GOSUB backwards
    CASE 270 TO 400
      UD = c
  ENDSELECT
  SELECT LR
    CASE < 220
      LR = d
      GOSUB left
    CASE > 380
      LR = e
      GOSUB right
    CASE 220 TO 380
      LR = f
  ENDSELECT
  IF (UD = c)AND(LR = f) THEN
    GOSUB stall
  ENDIF
LOOP
'---Subroutines------------------------------------------
forwards:
    PULSOUT Rwheel, L_FWD
    PULSOUT Lwheel, R_FWD
    PAUSE 20
  RETURN
backwards:
    PULSOUT Rwheel, R_REV
    PULSOUT Lwheel, L_REV
    PAUSE 20
  RETURN
left:
    PULSOUT Lwheel, L_FWD
    PULSOUT Rwheel, R_STOP
    PAUSE 20
  RETURN
right:
    PULSOUT Lwheel, L_STOP
    PULSOUT Rwheel, R_FWD
    PAUSE 20
  RETURN
stall:
    PAUSE 20
  RETURN
'xbee controller
' {$STAMP BS2}
' {$PBASIC 2.5}
'----------------[Initialize]---------------------------
PAUSE 5
SEROUT 0, 84, [22,12]
SEROUT 0, 84,50, [22,17, "Hello", 13, "John"]
PAUSE 1000
'---------------[Variables]-----------------------------
LR            VAR     Word
UD            VAR     Word
btn1wrk       VAR     Byte
btn2wrk       VAR     Byte
green         VAR     Bit
red           VAR     Bit
distance     VAR     Word
'---------------[Constants]-----------------------------
#SELECT $STAMP
 #CASE BS2, BS2E, BS2PE
   T9600      CON     84
#ENDSELECT
Lcd           PIN     0
Btn1          PIN     7
Btn2          PIN     5
Tx            PIN     9  ' XBee DIN
Rx            PIN     10 ' XBee DOUT
LRjoy         PIN     6
UDjoy         PIN     4
Led_A         PIN     15
Led_B         PIN     14
stickUD       CON     25
stickLD       CON     25
Baud          CON     T9600
'-------------------------[Main]---------------------------
Main:
DO
HIGH 6
PAUSE 2
RCTIME 6, 1, LR
HIGH 4
PAUSE 2
RCTIME 4, 1, UD
  SEROUT Rx, 84, [UD]
  SEROUT Rx, 84, [LR]
LOOP
    edited 2012-10-23 10:59
    The XBees are transmitting and receiving two bytes, UD and LR, range 0..255. However the program is expecting them to be Word values greater than that. The Word values are coming from the RCTIME command. Say RCTIME finds a value of 325, and it will print that on the controller debug screen, but the XBee will only transmit the least significant byte, 69, which is what the receiver will show. (325 = 256 + 69).
    Probably the easiest solution is on the controller, to scale the RCTIME value down to fit in a byte.
  • graffixgraffix Posts: 389
    edited 2012-10-23 12:37
    I'll give that a try. Thank you
    It worked, Thanks again
    edited 2012-10-27 11:14
    Ok so that portion works. The joysticks control the servos(continuous servo's). Now Im trying to add in the push buttons. The controller code works ok. If I push Btn1 then Btn1 = 1 and Btn1 = 0 when not pressed in the coresponding debug terminal.Same with the Btn2. However the Boe Bot is recieving different values. When I press Btn1 there is no change in the Boe's debug terminal. When I press Btn2, Btn1 then = 1. Btn2 on the boe's debug terminal seems to be displaying the UD value.
    After I get the Boe to display the correct values for Btn1 and Btn2. I hope to use one of them to change into a different mode of operation. Say when I press Btn1 the LR joystick then controls the Ping servo(standard servo) while sending the ping value back to be displayed on the controllers LCD until I press Btn1 again. If I can get some some help with this portion that would be great. Thanks ahead of time.
    P.S. I would move this to two Prop Boe's if I had the funds to do so.
    controller
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    ' XBee controller
    PAUSE 5
    PAUSE 1000
    LR            VAR     Word
    UD            VAR     Word
    Btn1wrk       VAR     Byte
    Btn2wrk       VAR     Byte
    green         VAR     Bit
    red           VAR     Bit
    distance     VAR     Word
    #SELECT $STAMP
       T9600      CON     84
    #ENDSELECT
    Lcd           PIN     0
    Btn1          PIN     7
    Btn2          PIN     5
    Tx            PIN     9  ' XBee DIN
    LRjoy         PIN     6
    UDjoy         PIN     4
    Led_A         PIN     15
    Led_B         PIN     14
    stickUD       CON     25
    stickLD       CON     25
    Baud          CON     T9600
    Main:
    DO
      HIGH 6
      PAUSE 2
      RCTIME 6, 1, LR
      HIGH 4
      PAUSE 2
      RCTIME 4, 1, UD
      UD = UD/3
      LR = LR/3
      DEBUG HOME, "Controller Com 1" ,CLREOL, CR,
                  "UD = ", DEC UD, CLREOL, CR,
                  "LR = ", DEC LR, CLREOL, CR,
                  "Btn1 = ", DEC Btn1, CLREOL, CR,
                  "Btn2 = ", DEC Btn2, CLREOL
      SEROUT Rx, 84, [UD,LR]
      SEROUT Rx, 84, [Btn1,Btn2]
    LOOP
    Boe Bot
    '{$STAMP BS2}
    '{$PBASIC 2.5}
    'Recieving Boe Bot
    L_FWD     CON  1000
    L_REV     CON  500
    L_STOP    CON  750
    R_FWD     CON  500
    R_REV     CON  1000
    R_STOP    CON  750
    UD               VAR     Word
    LR               VAR     Word
    a                VAR     Word
    b                VAR     Word
    c                VAR     Word
    d                VAR     Word
    e                VAR     Word
    f                VAR     Word
    Btn1             VAR     Word
    Btn2             VAR     Word
    i                VAR     Byte
    rx_data          VAR     Byte
    xbee_rts         PIN     9
    Rwheel           PIN     13
    Lwheel           PIN     12
    LOW Lwheel
    LOW Rwheel
    DO
      SERIN XBee_Tx, 84, [Btn1,Btn2]
      DEBUG HOME, "Boe Bot Com 13", CLREOL, CR,
      SELECT UD
        CASE < 90
          UD = a
          GOSUB forwards
        CASE > 110
          UD = b
          GOSUB backwards
        CASE 90 TO 110
          UD = c
      ENDSELECT
      SELECT LR
        CASE < 116
          LR = d
          GOSUB right
        CASE > 140
          LR = e
          GOSUB left
        CASE 118 TO 140
          LR = f
      ENDSELECT
        GOSUB stall
      ENDIF
    LOOP
    forwards:
      FOR i = 0 TO 2
        PAUSE 20
      NEXT
      RETURN
    backwards:
      FOR i = 0 TO 2
        PAUSE 20
      NEXT
      RETURN
    left:
      FOR i = 0 TO 2
        PAUSE 20
       NEXT
      RETURN
    right:
      FOR i = 0 TO 2
        PAUSE 20
       NEXT
      RETURN
    stall:
        PAUSE 20
      RETURN
    edited 2012-10-28 08:49
    controller:
    LCD - pin 0
    UDjoystick - pin 4
    LRjoystick - pin 6
    Btn1 - pin 7
    Btn2 - pin 5
    XBee Rx - pin 10
    XBee Tx - pin 9
    XBee RTS- pin 8
    LED_A - pin 15
    LED_B - pin 14
    BoeBot:
    XBee RTS - pin 9
    XBee Rx - pin 10
    XBee Tx - pin 11
    servo pal - nInp pin 12
    servo pal - alarm pin 13
    HM55B Clk pin 0
    HM55B En pin 1
    HM55B Din/Dout pin 2
    Bi_clrLEDred pin 6 ' when high + low 7
    Bi_clrLEDgreen pin 7 ' when high + low 6
    This is all of hardware I'd like to incorporate and pins used for both controller and Boe Bot.
    Im not sure how I'd like to use and code functionality of all of it. Im not sure of how much varible space would be required for each.
    Im also not sure how I should establish a two way communication between the xbees so my loops dont freeze up.
    I've yet to get the HM55B properly calibrated even in a code by its self. I have three different compasses and I get different readings
    from each. I'm sure it's interference, but thats where I'm at regardless.
    Here is latest attempt
    controller
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    ' XBee controller
    PAUSE 5
    PAUSE 1000
    LR            VAR     Word
    UD            VAR     Word
    Btn1wrk       VAR     Byte
    Btn2wrk       VAR     Byte
    green         VAR     Byte
    red           VAR     Byte
    inDistance    VAR     Word
    #SELECT $STAMP
       T9600      CON     84
    #ENDSELECT
    Lcd           PIN     0
    Btn1          PIN     7
    Btn2          PIN     5
    Tx            PIN     9  ' XBee DIN
    RTS           PIN     8
    LRjoy         PIN     6
    UDjoy         PIN     4
    Led_A         PIN     15
    Led_B         PIN     14
    stickUD       CON     25
    stickLD       CON     25
    Baud          CON     T9600
    Main:
    DO
      HIGH 6
      PAUSE 2
      RCTIME 6, 1, LR
      HIGH 4
      PAUSE 2
      RCTIME 4, 1, UD
      UD = UD/3
      LR = LR/3
                  "Btn2 = ", DEC Btn2, CLREOL, CR
      PAUSE 100
      IF Btn2 = 1 THEN
        GOSUB Get_ping
      ENDIF
    LOOP
    Get_ping:
      SERIN Tx, 84, [inDistance]
      DEBUG "inDistance = ", DEC3 inDistance, CLREOL
      RETURN
    Boe Bot
    '{$STAMP BS2}
    '{$PBASIC 2.5}
    'Recieving Boe Bot
    L_FWD            CON     1000
    L_REV            CON     500
    L_STOP           CON     750
    R_FWD            CON     500
    R_REV            CON     1000
    R_STOP           CON     750
    CmConstant       CON     2260
    InConstant       CON     890
    UD               VAR     Byte
    LR               VAR     Byte
    a                VAR     Byte
    b                VAR     Byte
    c                VAR     Byte
    d                VAR     Byte
    e                VAR     Byte
    f                VAR     Byte
    Btn1             VAR     Byte
    Btn2             VAR     Byte
    i                VAR     Byte
    rx_data          VAR     Byte
    cmDistance       VAR     Word
    inDistance       VAR     Word
    time             VAR     Word
    xbee_rts         PIN     9
    nInp             PIN     12    'Define the input pin of servo pal
    Alarm            PIN     13    'Define the alarm pin of servo pal
    HM55B_clk        PIN     0
    HM55B_en         PIN     1
    HM55B_Din_Dout   PIN     2
    Bi_clrLEDred     PIN     6     ' when high + low 7
    Bi_clrLEDgreen   PIN     7     ' when high + low 6
    INPUT nInp                'Make sure nInp isn't being driven.
    DO : LOOP UNTIL nInp      'Wait for ServoPAL to power up.
    LOW nInp                  'Set pin to an output and hold it low
    PAUSE 100                 '  for 100mS to reset ServoPAL.
    HIGH nInp                 'Raise the pin.
    PAUSE 100
    DO
      PULSOUT 15, 5
      PULSIN 15, 1, time
      cmDistance = cmConstant ** time
      inDistance = inConstant ** time
                  "Btn2 = ", DEC Btn2, CLREOL, CR,
                  "cm = ", DEC3 cmDistance,CLREOL, CR,
                  "in = ", DEC3 inDistance,CLREOL
      SELECT Btn2                                  'code locks up when pressed
        CASE Btn2 = 1
          SEROUT XBee_Rx, 84, [indistance]
      ENDSELECT
      SELECT UD
        CASE < 90
          UD = a
          GOSUB forwards
        CASE > 110
          UD = b
          GOSUB backwards
        CASE 90 TO 110
          UD = c
      ENDSELECT
      SELECT LR
        CASE < 116
          LR = d
          GOSUB right
        CASE > 140
          LR = e
          GOSUB left
        CASE 118 TO 140
          LR = f
      ENDSELECT
        GOSUB stall
      ENDIF
    LOOP
    forwards:
      PULSOUT nInp, 1000       'Program right servo for full forward.
      PULSOUT nInp, 500        'Program left servo for full forward.
      PULSOUT nInp, 10         'Program alarm for 1 seconds.
      DO : LOOP UNTIL Alarm    'Wait for Alarm.
      RETURN
    backwards:
      PULSOUT nInp, 500        'Program right servo for full reverse.
      PULSOUT nInp, 1000       'Program left servo for full reverse.
      RETURN
    left:
      PULSOUT nInp, 2000       'Turn right servo off.
      RETURN
    right:
      PULSOUT nInp, 2000       'Turn left servo off.
      RETURN
    stall:
      RETURN
    though I've added some things to the code I still have same issues as before
    608 x 718 - 77K
    edited 2012-10-28 12:11
    As you get deeper into this, you will need to provide for hardware flow control on the BOE side at least. The Stamp serial port is unbuffered, which means that characters sent by the XBee in quick succession can be lost. For example in the following sequence without flow control, the XBee may send all of the data before the before the Stamp is ready to receive.
    Also, the transmitter and receiver can get out of sync and there is no way for the receiver to distinguish UD,LR data from Btn data. So you end up with UC data where you were expecting Btn data. For that reason, it can help to insert a sync character, one that will never be a data value. On the receiving end the command will look something like this:
    SERIN XBee_Tx\XBee_rts, 84, [wait(sync),UD,LR,Btn1,Btn2]
    where XBee_rts matches the hardware RTS pin, and the sync character may be something like a byte value of 255. With the RTS flow control implemented, it will also be possible to add a timeout to the SERIN, so the BOE can go off and do other things while it is waiting for a command. Or two way communication with flow control on both ends.
    edited 2012-10-30 06:48
    Im still trying different things. The sync character worked fine. Though I'm not done. I wanted to thank you again and just let you know Im still working on it.
    edited 2012-11-04 04:30
    Ok I have another update. I put together code for the ping bargraph it also displays the inches away value in line 2 of the LCD. It only covers the ping and lcd on a single Bs2.
    ' {$STAMP BS2}                               ' Target device = BASIC Stamp 2
    ' {$PBASIC 2.5}                              ' Language      = PBASIC 2.5
    ' -----[ I/O Pins ]-----------------------------------------------------------
    LcdPin         PIN     0                    ' I/O pin connected to LCD's RX
    Ping           PIN     15
    ' -----[ Constants ]----------------------------------------------------------
    T9600          CON     84                    ' True, 8-bits, no parity, 9600
    LcdCls         CON     12                    ' Form feed -> clear screen
    LcdCr          CON     13                    ' Carriage return
    LcdOff         CON     21                    ' Turns display off
    LcdOn          CON     22                    ' Turns display on
    Line0          CON     128                   ' Line 0, character 0
    Line1          CON     148                   ' Line 1, character 0
    Define         CON     248                   ' Address defines cust char 0
    InConstant CON 890
    ' -----[ Variables ]----------------------------------------------------------
    custChar       VAR     Nib                   ' Custom charcter selector
    index          VAR     Nib                   ' Eeprom index variable
    dotLine        VAR     Byte                  ' 5-pixel dotted line
    cursor         VAR     Nib                   ' Cursor placement
    value          VAR     Byte                  ' Value to be graphed.
    charCnt        VAR     Byte                  ' Character counting variable
    line           VAR     Byte                  ' Line0 or Line1
    inDistance  VAR   Word
    time        VAR   Word
    ' -----[ Initialization ]-----------------------------------------------------
    PAUSE 100                                    ' Debounce power supply
    SEROUT LcdPin, T9600, [LcdOn, LcdCls]        ' Initialize LCD
    PAUSE 5                                      ' 5 ms delay for clearing display
    custChar = 3                                 ' Select Custom Character 3
    dotLine = %11111                             ' Black all pixels in each line
    GOSUB Def_Horiz_Bar_Char                     ' Character define subroutine
    line = Line0                                 ' BarGraph on Line 0.
    ' -----[ Main Routine ]-------------------------------------------------------
    DO                                           ' Main loop
      PULSOUT 15, 5
      PULSIN 15, 1, time
      SEROUT 0, 84,[line1, DEC3 inDistance, "inches away"]
      value = inDistance
      GOSUB Bar_Graph                            ' Display as bar graph
      PAUSE 100
    LOOP                                         ' Repeat main loop
    ' -----[ Subroutine - Bar_Graph ]---------------------------------------------
    Bar_Graph:
      ' Fill from left with black bars
      value = value MAX 80                       ' Limit value - 0 to 80
      charCnt = value / 5                        ' Number of black bars
      custChar = 3                               ' Choose black custom character
      IF charCnt > 0 THEN                        ' If black bars to print then
        FOR cursor = 0 TO charCnt - 1            ' Print charCnt - 1 black bars
          GOSUB Disp_Cust_Char                   ' Print the black bar
        NEXT
      ENDIF
      ' Display Custom Character 2 with a certain number of black columns.
      cursor = charCnt                           ' Place cursor
      custChar = value // 5                      ' How many 5ths of a bar?
      ' Choose bit pattern for custom character definition
      LOOKUP custChar,
             [%00000, %10000, %11000, %11100, %11110],
             dotLine
      custChar = 2                               ' Set custom character to 2
      GOSUB Def_Horiz_Bar_Char                   ' Define the custom character
      GOSUB Disp_Cust_Char                       ' Display the custom character
      ' Print over everything to the right with spaces.
      IF (charCnt + 1) < 15 THEN                 ' Partial char left of char 15?
        FOR cursor = (charCnt + 1) TO 15         ' Fill to right with " "
                 [line + cursor, " "]
        NEXT
      ELSEIF value = 80 THEN                     ' Special case: value = 80
               [line + cursor, 3]
      ELSEIF charCnt = 14 THEN                   ' Special case: 75 <= value <= 80
        SEROUT LcdPin, T9600, [line + 15, " "]
      ENDIF
      RETURN
    ' -----[ Subroutine - Def_Horiz_Bar_Char ]------------------------------------
    Def_Horiz_Bar_Char:
      SEROUT LcdPin, T9600,                      ' Define custom character
             [Define + custChar]
      FOR index = 0 TO 7                         ' 7 bytes, define 7 dotted lines
        SEROUT LcdPin, T9600, [dotLine]          ' Send it to the LCD
      NEXT
      RETURN
    ' -----[ Subroutines - Disp_Cust_Char ]---------------------------------------
    ' This subroutine displays a custom character.  The line variable can
    ' be set to either Line0 or Line1, and the cursor variable can be set
    ' to a value between 0 and 15.  The custChar variable selects one of the
    ' LCD's custom characters and should be set to a value between 0 and 7.
    Disp_Cust_Char:
      SEROUT LcdPin, T9600,                    ' Print custom character
             [line + cursor, custChar]
      RETURN
    I've also worked on the controller and boe bot codes last posted here http://forums.parallax.com/showthread.php?143468-push-button-routine
    I posted that code just before I left for work. I thought it was good to go. Turns out I lost the right turn functionality of it. I tried all kinds of things. Finally I started removing some of the older variables I hadnt used in awhile and assigning the proper space for what was left. It fixed that problem. I also omitted the debug statements (tip I got from Erco) and the code seemed quite fast and responsive. I also added Btn1 centers the ping servo.
    controller
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    ' XBee controller
    '---[Initialize]-------------------------------------------------
    PAUSE 5
    SEROUT 0, 84,50, [22,17, "Hello", 13, "Mr.President!!!"]
    PAUSE 1000
    '---[Variables]---------------------------------------------------
    LR            VAR     Word
    UD            VAR     Word
    Btn1wrk       VAR     Byte
    Btn2wrk       VAR     Byte
    green         VAR     Byte
    red           VAR     Byte
    inDistance    VAR     Word
    mode          VAR     Bit
    '---[Constants]----------------------------------------------------
    #SELECT $STAMP
       T9600      CON     84
    #ENDSELECT
    stickUD       CON     25
    stickLD       CON     25
    Baud          CON     T9600
    capture       CON     500
    '---[Pin descriptions]---------------------------------------------
    Lcd           PIN     0
    Btn1          PIN     7
    Btn2          PIN     5
    Tx            PIN     9  ' XBee DIN
    RTS           PIN     8  ' XBee RTS
    LRjoy         PIN     6
    UDjoy         PIN     4
    Led_A         PIN     15
    Led_B         PIN     14
    PIEZO         PIN     3
    '---[Main]-----------------------------------------------------------
    Main:
    DO
      HIGH 6
      PAUSE 2
      RCTIME 6, 1, LR
      HIGH 4
      PAUSE 2
      RCTIME 4, 1, UD
      UD = UD/3
      LR = LR/3
    '  DEBUG HOME, "Controller Com 1" ,CLREOL, CR,
     '             "UD = ", DEC UD, CLREOL, CR,
     '             "LR = ", DEC LR, CLREOL, CR,
     '             "Btn1 = ", DEC Btn1, CLREOL, CR,
     '             "Btn2 = ", DEC Btn2, CLREOL, CR,
     '             "inDistance = ", DEC3 inDistance, CLREOL, CR,
     '             "mode = ", DEC mode, CLREOL
      SEROUT Rx\RTS, 84, ["!",UD,LR,Btn1,Btn2,mode]
      IF Btn1 = 1 THEN HIGH 15 ELSE LOW 15
      IF Btn2 = 1 THEN
        mode = mode + 1
        'GOSUB Get_ping
      ENDIF
      IF mode = 1 THEN HIGH 14
        'GOSUB Get_ping
      IF mode = 0 THEN LOW 14
    LOOP
    '---[ Subroutines ]--------------------------------------------------------
    'Get_ping:
      'SERIN Tx\RTS, 84,149, Com_error,
            '[WAIT("in"),inDistance]
      'GOTO main'return
    Com_Error:                      ' Handle timeout during tilt controlled navigation
      DEBUG "A communication error occurred...Reconnecting", CR     ' Error message
        FREQOUT PIEZO, 100, 3000                 ' Indicate error
        PAUSE 100
        PAUSE 100
        PAUSE 1000
      GOTO main
    Boe Bot
    '{$STAMP BS2}
    '{$PBASIC 2.5}
    'Recieving Boe Bot
    '---[ Constants ]-------------------------------------------
    L_FWD            CON     1000
    L_REV            CON     500
    L_STOP           CON     750
    R_FWD            CON     500
    R_REV            CON     1000
    R_STOP           CON     750
    CmConstant       CON     2260
    InConstant       CON     890
    BAUD_MODE        CON     84
    UD               VAR     Byte
    LR               VAR     Byte
    A                VAR     Bit
    B                VAR     Bit
    Btn1             VAR     Bit
    Btn2             VAR     Bit
    cmDistance       VAR     Word
    inDistance       VAR     Word
    time             VAR     Word
    mode             VAR     Bit
    '---[Pin Descriptions]------------------------------------
    xbee_rts         PIN     9
    HM55B_clk        PIN     0
    HM55B_en         PIN     1
    ping             PIN     15
    ping_servo       PIN     14
    '---[Initializations]------------------------------------
    PAUSE 100
    '---[Main Program]------------------------------------------
    DO
      SERIN XBee_Tx\xbee_rts, 84, [WAIT("!"),UD,LR,Btn1,Btn2,mode]
      PULSOUT 15, 5
      PULSIN 15, 1, time
    '  DEBUG HOME, "Boe Bot Com 13", CLREOL, CR,
    '              "cm = ", DEC3 cmDistance,CLREOL, CR,
    '              "in = ", DEC3 inDistance,CLREOL, CR,
    '              "mode = ", DEC mode,CLREOL
      SELECT Btn1
        CASE = 1
        PULSOUT ping_servo,750
      ENDSELECT
      'SELECT Btn2
       ' CASE  = 1
        'SEROUT XBee_Rx\xbee_rts, 84, ["in",indistance]
      'ENDSELECT
      SELECT mode
        CASE = 1
          IF LR = > 140 AND mode = 1 THEN PULSOUT ping_servo, 1200
          IF LR = < 110 AND mode = 1 THEN PULSOUT ping_servo, 250
          PULSOUT 15, 5
          PULSIN 15, 1, time
      ENDSELECT
      SELECT UD
        CASE < 80
          GOSUB forwards
        CASE > 120
          GOSUB backwards
        CASE 80 TO 120
          UD = A
      ENDSELECT
      SELECT LR
         CASE > 140
          IF LR = > 140 AND mode = 0 THEN
            GOSUB left
          ENDIF
        CASE < 90
          IF LR = < 90 AND mode = 0 THEN
            GOSUB right
          ENDIF
        CASE 110 TO 140
          LR = B
      ENDSELECT
      IF (UD = A)AND(LR = B) THEN
        GOSUB stall
      ENDIF
    LOOP
    '---[Subroutines]------------------------------------------
    forwards:
    RETURN
    backwards:
    RETURN
    left:
    RETURN
    right:
    RETURN
    stall:
    RETURN
    The problems I mentioned in the other thread are still there. Im going to work on combining these three codes into two. I still havent managed to get the ping reading from the boe back to the controller without locking up the program. Any help I can get, would be great. Thanks
    edited 2012-11-08 08:23
    I still cant get a two way conversation with these Xbee's. Any thoughts, please.
    Im gonna guess that it has to do with the +++ atch atid stuff that isnt present in the above code. Ive tried implementing it and I havent got it to work.
    edited 2012-11-10 08:06
    latest codes
    controller code
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    ' XBee controller
    PAUSE 5
    PAUSE 1000
    LR            VAR     Word
    UD            VAR     Word
    Btn1wrk       VAR     Byte
    Btn2wrk       VAR     Byte
    green         VAR     Byte
    red           VAR     Byte
    inDistance    VAR     Word
    mode          VAR     Bit
    Btn2new       VAR     Bit
    Btn2old       VAR     Bit
    #SELECT $STAMP
       T9600      CON     84
    #ENDSELECT
    stickUD       CON     25
    stickLD       CON     25
    Baud          CON     T9600
    capture       CON     500
    Lcd           PIN     0
    Btn1          PIN     7
    Btn2          PIN     5
    Tx            PIN     9  ' XBee DIN
    LRjoy         PIN     6
    UDjoy         PIN     4
    Led_A         PIN     15
    Led_B         PIN     14
    PIEZO         PIN     3
    Main:
    DO
      HIGH 6
      PAUSE 2
      RCTIME 6, 1, LR
      HIGH 4
      PAUSE 2
      RCTIME 4, 1, UD
      UD = UD/3
      LR = LR/3
                  "mode = ", DEC mode, CLREOL, CR,
                  "in = ", DEC3 inDistance, CLREOL
      Btn2new = Btn2
      IF Btn2new = 1 AND Btn2old = 0 THEN
        mode = mode + 1
        'GOSUB Get_ping
      ENDIF
      Btn2old=Btn2new
        'GOSUB Get_ping
    LOOP
    Get_ping:
      SERIN Tx\RTS, 84, 149, Com_error,[WAIT("in"),inDistance]      'receive ping reading or time out
      GOTO main                                                     'return
      DEBUG " A communication error occurred...Reconnecting", CR    ' Error message
        PAUSE 100
        PAUSE 100
        PAUSE 1000
      GOTO main
    boe code
    '{$STAMP BS2}
    '{$PBASIC 2.5}
    'Recieving Boe Bot
    L_FWD            CON     1000
    L_REV            CON     500
    L_STOP           CON     750
    R_FWD            CON     500
    R_REV            CON     1000
    R_STOP           CON     750
    CmConstant       CON     2260
    InConstant       CON     890
    BAUD_MODE        CON     84
    UD               VAR     Byte
    LR               VAR     Byte
    A                VAR     Bit
    B                VAR     Bit
    Btn1             VAR     Bit
    Btn2             VAR     Bit
    inDistance       VAR     Word
    time             VAR     Word
    mode             VAR     Bit
    xbee_rts         PIN     9
    HM55B_clk        PIN     0
    HM55B_en         PIN     1
    ping             PIN     15
    ping_servo       PIN     14
    piezo            PIN     4
    PAUSE 100
    main:
    DO
      PULSOUT 15, 5
      PULSIN 15, 1, time
                  "mode = ", DEC mode,CLREOL, CR,
      SELECT Btn1
        CASE = 1
      ENDSELECT
      'SELECT Btn2
       ' CASE = 1
      'ENDSELECT
      SELECT mode
        CASE = 1
          PULSOUT 15, 5
          PULSIN 15, 1, time
          'GOSUB send_ping
      ENDSELECT
      SELECT UD
        CASE < 80
          GOSUB forwards
        CASE > 120
          GOSUB backwards
        CASE 80 TO 120
          UD = A
      ENDSELECT
      SELECT LR
         CASE > 140
            GOSUB left
          ENDIF
        CASE < 90
            GOSUB right
          ENDIF
        CASE 110 TO 140
          LR = B
      ENDSELECT
        GOSUB stall
      ENDIF
    LOOP
    forwards:
    RETURN
    backwards:
    RETURN
    left:
    RETURN
    right:
    RETURN
    stall:
    RETURN
    send_ping:
      SEROUT XBee_Rx\xbee_rts, 84, 149, Com_error,["in",indistance]
        PAUSE 100
        PAUSE 100
        PAUSE 1000
      GOTO main
    test bar graph program. I eventually would like to have some variant of this working while in mode 1
    Ping           PIN     15
    InConstant CON 890
    inDistance  VAR   Word
    time        VAR   Word
    DO                                           ' Main loop
      PULSOUT 15, 5
      PULSIN 15, 1, time
      value = inDistance
      PAUSE 100
    Bar_Graph:
        NEXT
      ENDIF
      LOOKUP custChar,
             dotLine
        NEXT
               [line + cursor, 3]
      ENDIF
      RETURN
    Def_Horiz_Bar_Char:
             [Define + custChar]
      NEXT
      RETURN
    Disp_Cust_Char:
      RETURN
    edited 2012-11-22 07:33
    I noticed the program was hanging up at times while driving. It seemed stuck in a loop. I removed the A and B variables for the Boe code. It seems to not hang up now. Heres the new code without them.
    Boe code
    '{$STAMP BS2}
    '{$PBASIC 2.5}
    'Recieving Boe Bot
    L_FWD            CON     1000
    L_REV            CON     500
    L_STOP           CON     750
    R_FWD            CON     500
    R_REV            CON     1000
    R_STOP           CON     750
    CmConstant       CON     2260
    InConstant       CON     890
    BAUD_MODE        CON     84
    UD               VAR     Byte
    LR               VAR     Byte
    Btn1             VAR     Bit
    Btn2             VAR     Bit
    inDistance       VAR     Word
    time             VAR     Word
    mode             VAR     Bit
    xbee_rts         PIN     9
    HM55B_clk        PIN     0
    HM55B_en         PIN     1
    ping             PIN     15
    ping_servo       PIN     14
    piezo            PIN     4
    PAUSE 100
    main:
    DO
      PULSOUT 15, 5
      PULSIN 15, 1, time
      SELECT Btn1
        CASE = 1
      ENDSELECT
      'SELECT Btn2
       ' CASE = 1
      'ENDSELECT
      SELECT mode
        CASE = 1
          PULSOUT 15, 5
          PULSIN 15, 1, time
          'GOSUB send_ping
      ENDSELECT
      SELECT UD
        CASE < 80
          GOSUB forwards
        CASE > 120
          GOSUB backwards
        CASE 80 TO 120
          GOSUB stall
      ENDSELECT
      SELECT LR
         CASE > 140
            GOSUB left
          ENDIF
        CASE < 90
            GOSUB right
          ENDIF
        CASE 110 TO 140
          GOSUB stall
      ENDSELECT
    LOOP
    forwards:
    RETURN
    backwards:
    RETURN
    left:
    RETURN
    right:
    RETURN
    stall:
    RETURN
    send_ping:
        PAUSE 100
        PAUSE 100
        PAUSE 1000
      GOTO main
  • gennarobasso81gennarobasso81 Posts: 84
    edited 2012-11-24 21:37
    i noticed on ur code you have serin tx. with my xbees i have to do serin Rx and serout TX. Not sure if that is causing any problems for you or not.
    Ok so I had to play around with the code some more...the last code i had that i though was good wasnt. However I think this is good, well atleast on the right track. I am having one problem with it and i think it is because i havent used a servo pal. As the code is, my bot moves very choppy. it goes where i want it...just slow and choppy. Would the servo pal fix this or is it the code?
    wireless Remote
    ' Xbee Servo Base test #1
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    PAUSE 5
    SEROUT 2, 84, [22,12]
    SEROUT 2, 84,50, [22,17, "Hello", 13, "Geno"]
    PAUSE 1000
    PAUSE 5
    LR            VAR     Word
    UD            VAR     Word
    btn1wrk       VAR     Byte
    btn2wrk       VAR     Byte
    Led           VAR     Bit
    Led1          VAR     Bit
    RTS           PIN     11
    Tx            PIN     14 ' XBee DIN
    Rx            PIN     15 ' XBee DOUT
    stickUD       CON     25
    stickLD       CON     25
    Main:
    DO
    HIGH 13
    PAUSE 2
    RCTIME 13, 1, UD
    HIGH 12
    PAUSE 2
    RCTIME 12, 1, LR
    SEROUT Tx, 84, [UD]
    SEROUT Tx, 84, [LR]
    LOOP
    Boe-Bot
    'Xbee Servo Remote test #2
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    #SELECT $STAMP
    T9600 CON 84
    #CASE BS2SX, BS2P
    T9600 CON 240
    #CASE BS2PX
    T9600 CON 396
    #ENDSELECT
    LR            VAR     Word
    UD            VAR     Word
    RTS           PIN     11
    Tx            PIN     6        ' XBee DIN
    Rx            PIN     7        ' XBee DOUT
    stickUD       CON     25
    stickLD       CON     25
    Baud          CON     T9600     'Set Baud Rate
     ' ************** XBee Configuration *********************
    PAUSE 500
    DEBUG "Configuring XBee...",CR
    PAUSE 2000 ' Guard Time
    SEROUT Tx,Baud,["+++"] ' Command Mode sequence
    SEROUT Tx,Baud,["ATD6 1,CN",CR] ' RTS enable (D6 1)
    ' Exit Command Mode (CN)
    ' ***************** Main Loop
    Main:
    DO
    SERIN Rx, 84, [UD, LR]
    IF UD > stickUD +2       THEN GOSUB Forward
    IF UD < stickUD -2       THEN GOSUB Backwards
    IF UD = stickUD +2 OR -2 THEN GOSUB Stay
    IF LR > stickLD +2       THEN GOSUB Right
    IF LR < stickLD -2       THEN GOSUB Left
    IF LR = stickLD +2 OR -2 THEN GOSUB Stay
    LOOP
    '-------------------------[Sub Routine]-----------------------
    Forward:
      PULSOUT 13, 850
      PULSOUT 12, 650
      PAUSE 20
    RETURN
    Backwards:
      PULSOUT 13, 650
      PULSOUT 12, 850
      PAUSE 20
    RETURN
    Right:
      PULSOUT 13, 848
      PULSOUT 12, 850
      PAUSE 20
    RETURN
    Left:
      PULSOUT 13, 650
      PULSOUT 12, 650
      PAUSE 20
    RETURN
    Stay:
      PULSOUT 13, 750
      PULSOUT 12, 755
      PAUSE 20
    RETURN
