·I am trying to set-up one Basic stamp board to use the 2-Axis joystick and wireless to control my Boe-Bot. Has anyone tried this with any luck? All
·I have been able to accomplish is it will rotate left and right. I have not figured out how the reverse the signal for the servos to get the forward and reverse. Thank you for any help with this.
Jax
If a robot has a screw then it must be romoved and hacked into..
Jax
Run the JoystickRCTIMERecorder.bs2 first then follow the directions in the JoystickControl.bs2 program to make the changes for your servos values.
Jax
Jax
Thank you for all of you hard work.
Chris Savage
Parallax Engineering
Jax
joystick.bs2
Thanks Bridger
