XBee wireless troubles — Parallax Forums
gennarobasso81gennarobasso81 Posts: 84
edited 2012-11-24 22:00 in Accessories
thank you for looking at my post,
I am having some issues with the xbee. I read through the manual for reference and still not sure.
I am trying to make a wireless remote control for a boe bot.
Using:
1 x 2 axis joystick
2 x push buttons
2 x BS2
1 x lcd
so far i am still testing the xbee's to get a better understanding of them. I have code for making the pushbuttons make two leds light up. I would like to make the pushbuttons do preset servo actions.
eventually i would like to use the 2 axis joystick to control the servo's forward and back, left and right. The push buttons would be for a 90 degree turn left and right. The code is still in the begining stage.
' {$STAMP BS2}
' {$PBASIC 2.5}
'----------------[Initialize]---------------------------
PAUSE 5
SEROUT 2, 84, [22,12]
SEROUT 2, 84,50, [22,17, "Hello", 13, "Geno"]
PAUSE 1000
PAUSE 5
'---------------[Variables]-----------------------------
LR            VAR     Word
UD            VAR     Word
btn1wrk       VAR     Byte
btn2wrk       VAR     Byte
'---------------[Constants]-----------------------------
BUTTON btn1, 1, 0, 0, btn1Wrk,0, No_Press
BUTTON btn2, 1, 0, 0, btn2Wrk,0, No_Press
Btn1          PIN     6
Btn2          PIN     7
Tx            PIN     14 ' XBee DIN
Rx            PIN     15 ' XBee DOUT
stickUD       CON     25
stickLD       CON     25
led           CON     0
led1          CON     1
'-------------------------[Main]---------------------------
Main:
HIGH 13
PAUSE 2
RCTIME 13, 1, UD
HIGH 12
PAUSE 2
RCTIME 12, 1, LR
DEBUG HOME, "UD =", DEC UD, CLREOL, CR,
"LR = ", DEC LR, CLREOL
IF UD > stickUD + 2 THEN GOSUB Forward
IF UD < stickUD - 2 THEN GOSUB Backwards
IF UD = stickUD     THEN GOSUB Clear
IF LR > stickLD + 2 THEN GOSUB Right
IF LR < stickLD - 2 THEN GOSUB Left
IF LR = stickLD     THEN GOSUB Clear
IF btn1 =1 THEN
DEBUG CR, "Button 1 pushed"
GOSUB Left_Turn
DEBUG CLS
ENDIF
IF btn2 = 1 THEN
DEBUG CR, "Button 2 pushed"
GOSUB Right_Turn
DEBUG CLS
ENDIF
No_Press:
 GOTO main
GOTO main
'-------------------------[Sub Routine]-----------------------
Forward:
SEROUT 2,84, 20, [17, 128, "Forward"]
PAUSE 200
RETURN
Backwards:
SEROUT 2, 84, 20, [17, 128, "Backwards"]
PAUSE 200
RETURN
Right:
SEROUT 2, 84, 20, [17, 148, "Right"]
PAUSE 200
RETURN
Left:
SEROUT 2, 84, 20, [17,148, "left"]
PAUSE 200
RETURN
Clear:
SEROUT 2, 84, [12,17]
PAUSE 200
RETURN
Left_Turn:
IF  Btn1 = 1 THEN     SEROUT 2, 84, ["Left", 13, "Turn"]
                      SEROUT Tx, 84,[DEC 0,CR]
                      PAUSE 500
IF  Btn1 = 0 THEN     SEROUT 2, 84, [12]
                      PAUSE 5
                      RETURN
Right_Turn:
IF btn2 = 1 THEN      SEROUT 2, 84, ["Right", 13, "Turn"]
                      SEROUT Tx, 84, [DEC 1,CR]
                      PAUSE 500
IF btn2 = 0 THEN      SEROUT 2, 84, [12]
                      PAUSE 5
                      RETURN
the code above just controls two leds
The code below is an attemp to control servos in a faster response from the xbees. I am very new to this and dont fully understand all of pbasic and how everything works. so this is all trial and error.
' {$STAMP BS2}
' {$PBASIC 2.5}
' ***************** Configure XBee in AT Command Mode
PAUSE 500
DEBUG CLS,"Configuring XBee..."
PAUSE 3000 ' Guard time
SEROUT Tx,84,["+++"] ' Command Mode Sequence
PAUSE 2000 ' Guard time
SEROUT Tx,84,["ATGT 3,MY 0",CR] ' Set low guard time and Base address
SEROUT TX,84,["ATCN",CR] ' Exit Command Mode
PAUSE 5
PAUSE 1000
PAUSE 5
LR            VAR     Word
UD            VAR     Word
btn1wrk       VAR     Byte
btn2wrk       VAR     Byte
Btn1          PIN     6
Btn2          PIN     7
stickUD       CON     25
stickLD       CON     25
led           CON     0
led1          CON     1
Main:
HIGH 13
PAUSE 2
RCTIME 13, 1, UD
HIGH 12
PAUSE 2
RCTIME 12, 1, LR
IF btn1 =1 THEN
GOSUB Left_Turn
DEBUG CLS
ENDIF
IF btn2 = 1 THEN
GOSUB Right_Turn
DEBUG CLS
ENDIF
No_Press:
 GOTO main
GOTO main
Forward:
PAUSE 200
RETURN
Backwards:
PAUSE 200
RETURN
Right:
PAUSE 200
RETURN
Left:
PAUSE 200
RETURN
Clear:
PAUSE 200
RETURN
Left_Turn:
                      PAUSE 500
                      PAUSE 5
                      RETURN
Right_Turn:
                      PAUSE 500
                      PAUSE 5
                      RETURN
any help is appreciated
    edited 2012-10-24 15:20
    First you have to learn to program in PBasic and start with simple programs until you are comfortable with how PBasic works. One telling thing is that you're using the BUTTON statement as a kind of declaration. It's actually a specialized form of GOTO and has to be executed in some kind of loop. Add features one at a time and make sure they work before adding the next feature.
    I notice that routines like Left_Turn and Right_Turn use indenting for nesting. That works for Spin and the Propeller, but doesn't exist in PBasic. Look at the examples for the IF statement in the PBasic manual.
  • gennarobasso81gennarobasso81 Posts: 84
    edited 2012-11-20 19:17
    Mike,
    thank you for replying...sorry it has been so long since i have been on to say thank you. Crazy month here had a baby then had hurricane sandy hit us directly. Just getting back to normal life now.
    You are correct in ur observation though, i am new to programing and reading ever bit of info i can while working on a project at the same time.
    so if the button command isnt the right command to use then what should i use?
    edited 2012-11-21 07:20
    The BUTTON statement works fine. You just have to use it properly. There are examples of its use in the Basic Stamp Syntax and Reference Manual and there are lots of examples of the use of pushbuttons in the Manual and in the What's a Microcontroller? tutorial. Both are freely downloadable. Go to the main Parallax webpage and click on the Downloads tab. You'll see buttons for Stamp Documentation and for Educational Tutorials and Translations. Those webpages have links to the manuals' PDF files as well as a host of other information.
    Yeah, new babies and massive hurricanes have a way of distracting people. Glad things are getting back to normal although babies have a way of shifting that mark.
    edited 2012-11-21 08:24
    Congratulations on the baby -- you may well find that he or she is a bigger storm than Sandy! Beware and enjoy!
    BUTTON is useful mostly if you need its auto-repeat capability, where holding down a key causes its action to repeat at some interval. Otherwise it is overkill. Straightforward code needs only a single bit variable to manage the button actions for key-up-transition, key-down-transition, key-held-up and key-held-down. I have a writeup on the inner workings of BUTTON posted at http://emesystems.com/BS2fsm.htm#BUTTON.
  • graffixgraffix Posts: 389
    edited 2012-11-21 21:14
    Have you tried temporarily adding an apostrophe before the debug commands? So the code skips over them and loops faster.
    edited 2012-11-24 19:06
    ok so here are two new codes
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    PAUSE 5
    PAUSE 1000
    PAUSE 5
    LR            VAR     Word
    UD            VAR     Word
    btn1wrk       VAR     Byte
    btn2wrk       VAR     Byte
    Led           VAR     Bit
    Led1          VAR     Bit
    Btn1          PIN     6
    Btn2          PIN     7
    stickUD       CON     25
    stickLD       CON     25
    Main:
    HIGH 13
    PAUSE 2
    RCTIME 13, 1, UD
    HIGH 12
    PAUSE 2
    RCTIME 12, 1, LR
    IF btn1 =1 THEN
    GOSUB Left_Turn
    DEBUG CLS
    ENDIF
    IF btn2 = 1 THEN
    GOSUB Right_Turn
    DEBUG CLS
    ENDIF
    No_Press:
     GOTO main
    GOTO main
    Forward:
    PAUSE 200
    RETURN
    Backwards:
    PAUSE 200
    RETURN
    Right:
    PAUSE 200
    RETURN
    Left:
    PAUSE 200
    RETURN
    Clear:
    PAUSE 200
    RETURN
    Left_Turn:
                          PAUSE 500
                          PAUSE 5
                          RETURN
    Right_Turn:
                          PAUSE 500
                          PAUSE 5
                          RETURN
    and the receiver
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    #SELECT $STAMP
    #CASE BS2, BS2E, BS2PE
    T9600 CON 84
    #CASE BS2SX, BS2P
    T9600 CON 240
    #CASE BS2PX
    T9600 CON 396
    #ENDSELECT
    ' ***************** Variables, Constants and Pins
    Baud CON T9600 ' Set Baud rate
    green PIN 0
    red   PIN 1
    Led   VAR Bit
    Led1  VAR Bit
    ' ***************** Main Loop
    DO
    SERIN Rx, 84, [DEC Led]
    SERIN Rx, 84, [DEC Led1]
    IF Led = 0 THEN
    HIGH green ' Turn on LED
    PAUSE 1000
    LOW green ' Turn off LED
    ENDIF
    IF Led1 = 1 THEN
    HIGH red
    PAUSE 1000
    LOW red
    ENDIF
    LOOP
    I THINK I GOT IT!!!!!!!
    ok so i can use the 2 axis joy stick to move my bot around now. I just did the joystick for now but since i got it working i will try on the other features...maybe just the ping like graffix is trying. Anyway here is code
    Base code:
    ' Xbee Servo Base test #1
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    PAUSE 5
    PAUSE 1000
    PAUSE 5
    LR            VAR     Word
    UD            VAR     Word
    btn1wrk       VAR     Byte
    btn2wrk       VAR     Byte
    Led           VAR     Bit
    Led1          VAR     Bit
    Btn1          PIN     6
    Btn2          PIN     7
    RTS           PIN     10
    stickUD       CON     25
    stickLD       CON     25
    Main:
    DO
    HIGH 13
    PAUSE 2
    RCTIME 13, 1, UD
    HIGH 12
    PAUSE 2
    RCTIME 12, 1, LR
    SEROUT tX, 84, [UD]
    SEROUT Tx, 84, [LR]
    LOOP
    No_Press:
    GOTO Main
    Remote code: (Note: the Remote xbee is the boe-bot)
    'Xbee Servo Remote test #1
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    #SELECT $STAMP
    T9600 CON 84
    #CASE BS2SX, BS2P
    T9600 CON 240
    #CASE BS2PX
    T9600 CON 396
    #ENDSELECT
    LR            VAR     Word
    UD            VAR     Word
    btn1wrk       VAR     Byte
    btn2wrk       VAR     Byte
    Led           VAR     Bit
    Led1          VAR     Bit
    Btn1          PIN     6
    Btn2          PIN     7
    RTS           PIN     10
    stickUD       CON     25
    stickLD       CON     25
    Baud          CON     T9600     'Set Baud Rate
    Main:
    DO
    SERIN Rx, 84, [UD, LR]
    IF UD > stickUD +2       THEN GOSUB Forward
    IF UD < stickUD -2       THEN GOSUB Backwards
    IF UD = stickUD +2 OR -2 THEN GOSUB Stay
    IF LR > stickLD +2       THEN GOSUB Right
    IF LR < stickLD -2       THEN GOSUB Left
    IF LR = stickLD +2 OR -2 THEN GOSUB Stay
    LOOP
    'IF btn1 = 1              THEN GOSUB Left_Turn
    'IF btn2 = 1              THEN GOSUB Right_Turn
    NO_Press:
    GOTO Main
    Forward:
      PULSOUT 13, 850
      PULSOUT 12, 650
      PAUSE 20
      RETURN
    Backwards:
      PULSOUT 13, 650
      PULSOUT 12, 850
      PAUSE 20
    RETURN
    Right:
      PULSOUT 13, 848
      PULSOUT 12, 850
      PAUSE 20
    RETURN
    Left:
      PULSOUT 13, 650
      PULSOUT 12, 650
      PAUSE 20
    RETURN
    Stay:
      PULSOUT 13, 750
      PULSOUT 12, 750
      PAUSE 20
    RETURN
