spin trying to send and receive bytes to linux host
Here is spin program that awaits 4 bytes from host over serial port (they come every 10 seconds) and the propeller (quickstart) sends back 4 bytes of the long for the elapsed milliiseconds
Here is the output from the host, the 2nd column should be milliseconds (bout 10000 more each time) from the propeller, and the first few lines are OK, but then it goes funky, but every so often you will again see 10000 increments.
The LED is flashing, so the propeller is getting a host message every 10 seconds (and the host program) has been used with other boards (maple, uno). If I send back a constant value, that seems to work, or if just send back the 4 bytes from the host, that seems to work. But somehow CNT or something isn't working like I expect ??
help.
' drift run with hostdrift, send millis on recv 4 bytes CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 VAR long ms,t0,t1 OBJ pst : "Parallax Serial Terminal" PUB drift ' Method declaration pst.start(115200) ' Start PST on another cog. dira[17] :=1 t0 := cnt repeat ' Endless loop prevents ' program from ending. ms.byte[0] := pst.CharIn ' Get value ms.byte[1] := pst.CharIn ' Get value ms.byte[2] := pst.CharIn ' Get value ms.byte[3] := pst.CharIn ' Get value t1 := cnt ms := (||(t1-t0)/(clkfreq / 1_000)) ' ms ' ms := 70000 pst.Char(ms.byte[0]) pst.Char(ms.byte[1]) pst.Char(ms.byte[2]) pst.Char(ms.byte[3]) !outa[17] ' toggle
1353788943.317606 3080 0.000000 0.000000 -2147483648 1353788953.319655 13082 10.002049 10.002000 4 1353788963.321925 23084 20.004319 20.004000 15 1353788973.323339 20600 30.005733 17.520000 416111 1353788983.324908 10599 40.007302 7.519000 812059 1353788993.326382 598 50.008776 -2.482000 1049631 1353789003.328036 9403 60.010430 6.323000 894634 1353789013.329704 19404 70.012098 16.324000 766840 1353789023.331784 24280 80.014178 21.200000 735046 1353789033.333597 14278 90.015991 11.198000 875599 1353789043.335052 4277 100.017446 1.197000 988032 1353789053.336930 5724 110.019324 2.644000 975967 1353789063.338710 15725 120.021104 12.645000 894643 1353789073.340377 25727 130.022771 22.647000 825822 1353789083.342016 17958 140.024410 14.878000 893747 1353789093.343525 7956 150.025919 4.876000 967498 1353789103.345161 2044 160.027555 -1.036000 1006473 1353789113.346580 12045 170.028974 8.965000 947273
help.
But that only delays the problem. After about 53 seconds, t1 will wrap around and past t0, and your results will be off again. So you need to keep track of those wraps-arounds in order to correct the results.
Your current code is structured so: Clearly the difference between t1 and t0 will get bigger and bigger until it overflows 32 bits, about 4 billion ticks or 40 odd seconds.
You could arrange to count milliseconds per loop, something like You could then add something like "msTotal += msPerLoop" as well and now you measure total run time up to 40 of thousand seconds. If you want to time longer runs than that the start tallying up seconds, minutes, hours, days, etc separately.
