Old Camera, New Tricks
New project time.
This Fall, I am building a camera controller for use with an old Tandberg "Camera Unit III" (aka "WAVE") videoconferencing camera. The reasons we selected this camera were:
The basic needs for a controller/terminal are:
Check back for updates.
- PTZ capabilities
- 20x zoom
- Remote mounting options
- Conventional video outputs (Composite & SVideo)
- Oh yeah, it was the one we could get for free.
- Pan, tilt, and zoom
- Focus (man & auto)
Here is a almost complete protocol breakdown for the Tandberg camera unit III
Tandberg camera unit 3 api
tested on camera version:0c0d fw:63
Send
Receive (ack/response)
Example
IF_Clear
88 01 00 01 FF
88 01 00 01 FF
Address set
88 30 01 FF
88 30 02 FF
Send
Start UP
81 01 06 01 0V 0W 03 01 FF
90 50 FF
Start DOWN
81 01 06 01 0V 0W 03 02 FF
90 50 FF
Start LEFT
81 01 06 01 0V 0W 01 03 FF
90 50 FF
Start RIGHT
81 01 06 01 0V 0W 02 03 FF
90 50 FF
Stop PAN/TILT
81 01 06 01 0F 0F 03 03 FF
90 50 FF
Direct position
81 01 06 02 0V 0W 0Y 0Y 0Y 0Y 0X 0X 0X 0X FF
90 50 FF direct
Get Position
81 09 06 12 FF
90 50 0Y 0Y 0Y 0Y 0X 0X 0X 0X FF
Home
81 01 06 04 FF
90 50 FF
YYYY: pan position: approx. F980 to 0680 (center 0000)
XXXX: tilt position: approx. FE00 to 00D5 (center 0000)
81 = 8q - q ADRESS 1 TO 8
V pan speed 1 to 7 Does not work
W tilt speed 1 to 7 Does not work
Start ZOOM IN
81 01 04 07 2T FF
90 51 FF
Start ZOOM OUT
81 01 04 07 3T FF
90 51 FF
Stop ZOOM
81 01 04 07 00 FF
90 51 FF
Direct ZOOM
81 01 04 47 00 0Z 0Z 0Z FF
90 51 FF when zoom done
Get ZOOM
81 09 04 47 FF
ZZZ: zoom position 000 to 3FF (000 wide)
T: ZOOM SPEED (WORKS)
FOCUS auto
81 01 04 38 02 FF
90 51 FF
FOCUS manual
81 01 04 38 03 FF
90 51 FF
Start FOCUS FAR (in manual)
81 01 04 08 02 FF
90 51 FF
Start FOCUS NEAR (in manual)
81 01 04 08 03 FF
90 51 FF
Stop FOCUS (in manual)
81 01 04 08 00 FF
90 51 FF
Direct FOCUS (in manual)
81 01 04 48 0S 0S 0S 0S FF
90 51 FF when focus done
81 01 04 48 07 0E 00 00 FF
Get FOCUS
81 09 04 48 FF
90 50 0S 0S 0S 0S FF
Get FOCUS mode
81 09 04 38 FF
90 50 02 FF Auto
90 50 03 FF Manual
SSSS Focus Poisition 6000 to 2AC2 (6000 near)
Focus range depends on zoom-level
WB Auto
81 01 04 35 00 FF
90 51 FF
WB Indoor
81 01 04 35 01 FF
90 51 FF
WB Outdoor
81 01 04 35 02 FF
90 51 FF
WB Manual
81 01 04 35 03 FF
90 51 FF
Set WB (in manual)
81 01 04 10 05 FF
90 51 FF when done
Get WB mode
81 09 04 35 FF
90 50 00 FF Auto
90 50 01 FF Indoor mode
90 50 02 FF Outdoor mode
90 50 03 FF OnePush mode
Auto - exposure auto
81 01 04 39 00 FF
90 51 FF
M - exposure manual
81 01 04 39 03 FF
90 51 FF
S - shutter proirity
81 01 04 39 0A FF
90 51 FF
A - Iris proirity
81 01 04 39 0B FF
90 51 FF
P - Bright mode
81 01 04 39 0D FF
(exposure auto - set iris/shutter ratio with bright control)
Get EXPOSURE mode
81 09 04 39 FF
90 50 00 FF Full Auto
90 50 03 FF Manual
90 50 0A FF Shutter priority
90 50 0B FF Iris priority
90 50 0D FF Bright mode
EC on (works in auto)
81 01 04 3E 02 FF
90 51 FF
EC off (works in auto)
81 01 04 3E 03 FF
90 51 FF
EC up (Exp Auto and EC on)
81 01 04 0E 02 FF
90 51 FF
EC down (Exp Auto and EC on)
81 01 04 0E 03 FF
90 51 FF
exposure reset (Exp Auto and EC on)
81 01 04 0E 00 FF
90 51 FF
BRIGHT up (works in P)
81 01 04 0D 02 FF
90 51 FF
BRIGHT down (works in P)
81 01 04 0D 03 FF
90 51 FF
BRIGHT reset (works in P)
81 01 04 0D 00 FF
90 51 FF
IRIS open (only works in M or A)
81 01 04 0B 02 FF
90 51 FF
IRIS close (only works in M or A)
81 01 04 0B 03 FF
90 51 FF
IRIS reset (only works in M or A)
81 01 04 0B 00 FF
90 51 FF
Direct IRIS (only works in M or A)
81 01 04 4B 0I 0I 0I 0I FF
90 51 FF
Get IRIS
81 09 04 4B FF
90 50 0I 0I 0I 0I FF
same string from gain iris and shutter
IIII: iris 0000 TO 0011
GAIN up (only works in M)
81 01 04 0C 02 FF
90 51 FF
GAIN down (only works in M)
81 01 04 0C 03 FF
90 51 FF
GAIN reset (only works in M)
81 01 04 0C 00 FF
90 51 FF
Direct GAIN (only works in M)
81 01 04 4C 0G 0G 0G 0G FF
90 51 FF
Get GAIN
81 09 04 4C FF
90 50 0G 0G 0G 0G FF
GGGG: Gain 0000 to 001B (0000 -3db)
SHUTTER Faster (works in M or S)
81 01 04 0A 02 FF
90 51 FF
SHUTTER Slower (works in M or S)
81 01 04 0A 03 FF
90 51 FF
SHUTTER Reset (works in M or S)
81 01 04 0A 00 FF
90 51 FF
Direct SHUTTER (works in M or S)
81 01 04 4A 0§ 0§ 0§ 0§ FF
90 51 FF direct
Get SHUTTER
81 09 04 4A FF
90 50 0§ 0§ 0§ 0§ FF
§§§§ - Shutter speed 0001 to 001B (0001 slow)
POWER on
81 01 04 00 02 FF
POWER off
81 01 04 00 03 FF
Get POWER
81 09 04 00 FF
90 50 02 FF (on)
90 50 03 FF (off)
Camera and software version
81 09 04 22 FF
90 50 KK KK 00 MM FF
KKKK Camera version
MM Firmware version
Video system (PAL/NTSC)
81 09 06 23 FF
90 50 01 FF (PAL)
90 50 00 FF (NTSC)
IR on
81 01 06 08 02 FF
90 50 FF
IR off
81 01 06 08 03 FF
90 50 FF
