Caps on h-bridge IC circuit
rwgast_logicdesign
So if im using an l293 h bridge and I want to make a nice clean circuit using 2200uf caps would I place these across the+18v to the l293 or on the acual signal lines between the chip and the motor? Im thinking sticking caps like that on the signal will skew or just elminate the PWM signal correct? Im reading on how to make sure sudden current changes from a motor effect electronics and im thinking if the caps werent of the signal line the sudden starting and stiping of current would effect the l293 negatively, but maybe it built to handel that as long as you have diodes or your l293 variant has built in diode protection
Large decoupling goes on the supply, always.
Smaller capacitors can go across the motor windings to reduce inductive noise (RFI), but not nearly as large,
since such capacitance has to be driven by the bridge and will increase both the peak and average currents it has to handle and slow down the transitions (which need to be much less than the PWM period).
Don'y scrimp on the cap voltage rating, a motor can generate big inductive spikes, 50V caps would be more like it. High self-resonant frequency is good I suspect.
