$3 DC Step Up Converter
Saw this on another forum. Hadda gitmee twovum. Up to 94% efficiency? YMMV...
http://www.ebay.co.uk/itm/280754693171
True, except for Apple products which is why I don't buy them.
I know next to nothing about DC to DC converters. But now that I have a pair of 24 volt motors heading my way I've been wondering about 12 volt to 24 volt DC to DC converters. My idea is to use a 12 volt battery regulated down to 5 volts for the electronics, but boosted up to 24 volts for the motors.
I bet you'll find a real 24V battery is the best & simplest way to go. Lead acid are cheap & easy to charge and provide excellent traction
Excellent guess!
24 to 5 is 19 volts and I've heard voltage regulators get pretty hot when the source and destination are that different. So if I go the 24 volt battery route I gather a separate battery for the electronics would be a good idea?
Resistor, that is.
Phil's 5V switching regulator is a bargain at $3.65. Gotta gitmee sumdem.
Of course, a linear regulator like a 7805 gets hotter as the current and/or voltage drop increase. If your electronics drew very small current, you could put up with that. Your 24V source would likely be several batteries, you could tap off of that (6V or 12V) to reduce the voltage drop and heat dissipation.
Many ways to Carnegie Hall, but the best way is practice, practice, practice.
