Power issue with MAX7219?
Hello All,
I am using a MAX7219 to drive a 4 digit display and I believe that I have a power issue which results in the going blank after only a few minutes of use. The program (clock) continues to run however I have no display. I believe that I have a power issue as the display seems to shut down only when it is asked to drive too many segments, ie 1:11 is no problem however 12:58 is. The other reason that I think that this is a power issue is that the voltage regulator on my BS2sx get very hot, the only thing that does not seem to fit is that when I use a BS2 it's voltage regulator does not overheat yet the display still blanks out. I have tried multiple stamps, displays and MAX7219 chips.
Does anyone have an idea as to what I am missing?
Also, I am using a Professional Development Board and from what I understand this should bypass the Basic Stamps voltage regulator and utilize the PDB's onboard voltage regulator instead.
Zeus
Zeus
Here is a working schematic, obviously ignore everything on the rightmost side as I am using the Professional Development Board right now.
Zeus
I was wondering if it could be the BS2sx myself because when I revert back to a BS2 the BS2 regulator does not seem to generate any heat, however the display still drops out.
Zeus
