Purpose of "Stop" method?
lardom
I ran into a problem trying to find a way to 'restart' a cog after I used cogstop(1). The only way I could get the repeat loop to run was to comment out the "Stop" method call. Why is this?
Parent object:
Child object:
Parent object:
OBJ
ct : "CognewTest"
PUB main
dira[11]~~
repeat
ct.Start
waitcnt(clkfreq + cnt)
cogstop(1)
Child object:
VAR
long stack[6]
byte cog
PUB Start : success
' Stop 'remove the cogstop command to restart the cog
success := cog := cognew(main, @stack + 1)
PUB Stop
if cog
cogstop(cog~ - 1)
Pub main
dira[11]~~
repeat 200
outa[11]~~
waitcnt(clkfreq/10 + cnt)
outa[11]~
Normally, the bootloader uses cog 0, then starts the program using the same cog with all other cogs stopped. If, for some reason, you use some other mechanism to start up your program, like loading it from an SD card using some kind of other loader, all bets are off. Your program could start up in any cog. For most situations, they're all identical.
@Mike Green, I replaced cogstop(1) with cogstop(ct.Start) and cogstop(ct.main) but that did not stop the cog. I see the danger of resource conflicts. (I did not try cogstop(ct.Stop) but I'm not through experimenting.)
In the modified code below, which works, I subtracted "1". I'm assuming the remainder will always equal cogid. I'm going to test it by restarting several cogs.
PUB main | A repeat A := ct.Start waitcnt(clkfreq + cnt) cogstop(A - 1) waitcnt(clkfreq + cnt)(BTW, I did admit I was dense!)
PUB main repeat ct.Start waitcnt(clkfreq + cnt) ct.Stop waitcnt(clkfreq + cnt)
