micro-SD Card Adapter Documentation Is Missing Some Critical Dimensions
idbruce
To Whom It May Concern
I was not sure where to put this grievance, so I am posting it here.
I am currently designing a board to which I want to add a micro-SD Card Adapter. The micro-SD Card Adapter and PCB board will be housed inside a project box, so you can imagine that all dimensions are critical for the designing stage, especially since I want to mount the micro-SD Card Adapter to the main PCB board and have the receptacle of the adapter placed within a cutout of the project box. I have attached an image that clearly shows the lacking critical dimensions for such an endeavor. Additionally, there is also no front view with dimensions that would help facilitate the design of the necessary cutout for the card receptacle.
Bruce
Bruce
One of these additional measurements state:
-Mike
Addendum: your second missing dimension, as built on my sample, is 0.7 mm.
Yes, Parallax is definitely very accommodating. Without any doubt, they usually provide specific documentation upon request. I would imagine that Parallax staff has not seen this thread yet, otherwise I would have probably already received an answer. I don't like to call for stuff like this, because then it only helps me as an individual, whereas if it becomes part of a thread and the question is answered, then everyone has access to the provided information.
Now that is a very handy piece of information. Thank you very much for providing me with those dimensions.
Bruce
Since you have digital calipers, I am sure you realize that all dimensions are pretty much critical when designing something, especially in a situation where seperate entities form a whole unit and where one entity must fit into the hole of another entity, with minimal clearance.
So yes:
All dimensions are nice to have when designing something. Even if you don't think you need a specific dimension, you may discover that the lack of a specific dimension will impede your progress. Whenever I design something, I try to acquire all the handy information that I can gather, even if I don't think I will need it, because I have learned that I usually need that information, and then I have to search for it all over again.
So once again, thank you for taking the time and effort to provide the information and photos. You have been most helpful.
Bruce
Parts "A" & "B"
Don't mean to jack your thread!
Yea, I work with metal quite a bit also, so I understand the unforgiving part.
Some companies provide very detailed drawings with very accurate dimensions, while others provide somewhat adequate information, but still not quite upto snuff, and then there are those companies which provide very poor information, such as no drawings, poor drawings, or inaccurate dimensions.
LOL... Don't worry about it. I am not as picky about it as some of the others. Although I am sure some of them would hang you from the nearest tree
Bruce
