Working with variables across cogs- what am I missing?
Hey all,
I'm trying to figure out a better/more efficient way of working with variables.
My main object looks like this:
My Comms object looks like this:
I actually need to get about 60 longs into my "Main_comms" method for transmission via the serial.
What can I do to get my Main_comms method to have access to all 60 longs without passing them via parameters? Is there a simple way to achieve this? (Main_comms needs to be ran in a separate cog so that the loop continually monitors for an incoming start signal.)
Thanks in advance
Robert
PUB Main Comms.Start(@Level_Status,@Sigstr,@IO_0_Status[2],@IO_1_Status[2],@IO_2_Status[2],@IO_3_Status[2],@IO_4_Status[2],@IO_5_Status[2],@IO_6_Status[2],@IO_7_Status[2],@IO_8_Status[2],@IO_9_Status[2],@IO_10_Status[2],@IO_11_Status[2])
OBJ
xfds: "FullDuplexSerial"
VAR
long Cog
long Stack[60]
PUB Start(Level,Signal,IO0,IO1,IO2,IO3,IO4,IO5,IO6,IO7,IO8,IO9,IO10,IO11)
Stop
Cog:=cognew(Main_comms(Level,Signal,IO0,IO1,IO2,IO3,IO4,IO5,IO6,IO7,IO8,IO9,IO10,IO11),@Stack)+1
PUB Stop
if Cog
cogstop(Cog~-1)
PUB Main_comms(Level,Signal,IO0,IO1,IO2,IO3,IO4,IO5,IO6,IO7,IO8,IO9,IO10,IO11)|Poke
xfds.Start(26,27,0,9600) '(RXpin, TXpin, Mode, Baud) ' This gets FullDuplexSerial going
repeat
Poke:=xfds.rxTime(10)
If Poke=="!"
xfds.tx(long[Level])
xfds.tx(long[Signal])
''etc etc
Thanks in advance
Robert
(Thanks for looking! Hopefully I got this figured out.)
Then instead of:
xfds.tx(long[Level]) xfds.tx(long[Signal]) . . .Use:
index := Level repeat NUMBER_OF_VARIABLES xfds.tx(long[indexl]) index += 4If you increase the index by one instead of four, you'll send all the data.
If you want to use ASCII characters for your data, the infor is usually kept in arrays of bytes.
If you used "dec" instead of "tx" you'd send ASCII characters (up to ten) of the decimal value.
