Kwabena W. Agyeman's VGA64 driver in XMMC memory model?
Hi, Greetings to all from Spain.
I'm trying to make a program in XMMC memory model . This program uses the Kwabena W. Agyeman's VGA driver .
Unfortunately, it appears that the driver only operates in the LMM.
Anyone know how to modify the driver to work in XMMC mode?
Thank´s.
Thank´s.
Is there a demo or other example where you are having trouble? Post the code here if you can.
I have many drivers that run fine with XMMC mode. What simpleide/gcc version are you using?
--Steve
The program works perfectly on LMM mode.
Unfortunately when I try to add more rows or columns to the grid I get the message "Your program is too big for the memory" and when I change the memory mode to XMMC the program no longer works.
This is the code:
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include "vga.h"
#include "propeller.h"
#define GRID_X 78
#define GRID_Y 55
#define MAX_GENERATIONS 350
uint8_t grid[2][GRID_X][GRID_Y];
uint8_t current_grid = 0;
uint8_t generations = 0;
volatile struct {
unsigned stack[16];
struct vga_param v;
} par;
void startvga(volatile void *parptr)
extern unsigned int _load_start_vga_cog[];
int r;
r = cognew(_load_start_vga_cog, parptr);
#define COLS 160
#define ROWS 120
#define PINGROUP 2
unsigned char framebuffer[ROWS*COLS];
void hline(unsigned char *frame, int x, int y, unsigned char color)
int i;
frame += (y*COLS) + x;
*frame++ = color;
int cmpGrid()
int i, j;
for (i=0; i < GRID_Y; i++) {
for (j=0; j < GRID_X; j++) {
if (grid[0][j] != grid[1][j]) { return 0; }
return 1;
void initGrid()
int i, j;
int t;
memset(framebuffer, Black, ROWS*COLS);
current_grid = 0;
for (i = 0; i < GRID_X; i++) {
for (j = 0; j < GRID_Y; j++) {
if ((uint8_t)rand() % 3 == 0) {
grid[0][j] = 1;
} else {
grid[0][j] = 0;
int count_neighbours(int x, int y)
int i, j;
int sx;
int result = 0;
x--;
y--;
for (i = 0; i < 3; i++) {
if (y < 0 || y > (GRID_Y - 1)) { continue; }
for (j = 0; j < 3; j++) {
if (x < 0 || x > (GRID_X - 1)) { continue; }
if (i==1 && j == 1) { x++; continue; }
if (grid[current_grid][x][y]) { result++; }
x++;
y++;
x -= 3;
return result;
void runGrid()
uint8_t x, y;
int count;
char string[2] = {0,0};
uint8_t value = 0;
uint8_t new_grid;
new_grid = 1 - current_grid;
for (y = 0; y < GRID_Y; y++) {
for (x = 0; x < GRID_X; x++) {
count = count_neighbours(x, y);
string[0] = count+48;
if (count < 2 || count > 3) { value = 0; }
else if (count == 3) { value = 3; }
else { value = grid[current_grid][x][y]; }
grid[new_grid][x][y] = value;
current_grid = new_grid;
void drawGrid()
uint8_t x, y;
uint8_t cx, cy;
uint8_t grid_next_colour = 0;
cx = 0;
cy = 0;
cx = 0;
if (grid[1-current_grid][x][y] != grid[current_grid][x][y]) {
if(grid[current_grid][x][y]) {
hline(framebuffer, 1+cx, 3+cy,rand()%255);
else {
hline(framebuffer, 1+cx, 3+cy, Black);
cx += 2;
cy += 2;
int main()
unsigned int frequency, i, testval;
unsigned int clkfreq = _CLKFREQ;
_DIRA = (1<<15);
_OUTA = 0;
par.v.displayBuffer = framebuffer;
par.v.directionState = (0xff << (8*PINGROUP));
par.v.videoState = 0x300000FF | (PINGROUP<<9);
testval = (25175000 + 1600) / 4;
frequency = 1;
for (i = 0; i < 32; i++) {
testval = testval << 1;
frequency = (frequency << 1) | (frequency >> 31);
if (testval >= clkfreq) {
testval -= clkfreq;
frequency++;
par.v.frequencyState = frequency;
par.v.enabled = 1;
// start up the video cog
startvga(&par.v);
srand(_CNT);
initGrid();
drawGrid();
for(;;) {
runGrid();
drawGrid();
generations++;
if (generations > MAX_GENERATIONS) { // || cmpGrid()
generations = 0;
initGrid();
void startvga(volatile void *parptr) { extern unsigned int _load_start_vga_cog[]; #if defined(__PROPELLER_XMM__) || defined(__PROPELLER_XMMC__) load_cog_driver_xmm(_load_start_toggle_fw_cog, 496, (uint32_t *)parptr); #else cognew(_load_start_vga_cog, parptr); #endif }PS: A tip for the future: if you put your code inside [ code ] and [ /code ] (no spaces) then it'll be much more legible.
As you said, the startvga function's code had to be changed :
void startvga(volatile void *parptr) { extern unsigned int _load_start_vga_cog[]; #if defined(__PROPELLER_XMM__) || defined(__PROPELLER_XMMC__) load_cog_driver_xmm(_load_start_vga_cog, 496, (uint32_t *)parptr); #else cognew(_load_start_vga_cog, parptr); #endif }Does Spin2Cpp include this automatically? Or, will Spin2Cpp code require this change to run in XMM mode?
