Battery help
Im in the midst of redesigning my chair-bots chassis and i need a long lasting, 12v lead acid battery that can supply enough power for the robot ( I mean like enough to run a set of 4 2.5" CIM motors carrying a 300 pound load, plus speed controllers, an arduino, a wireless router, and 4 cooling fans) and keep it going for at least an hour of driving. Recommendations?????
I got the different colors confused. For deep discharge use, you want the Yellow-top batteries, not the Blue-top. The others are mostly for engine starting applications.
We got a couple of the Yellow-top batteries some years ago for use with an inverter to power some 120VAC devices and some 12V LED strings outside (in the cold) ... worked well. They'd get charged with a good auto charger during the week, then brought out onto a frozen lake for the weekend with the LEDs running overnight and the inverter turned on during the day.
Off hand I would think, for your purposes, two or three of Mike's recommended batteries would give you the capacity you need, with some reserve.
Once again, it sounds like you knew what you wanted to hear before you even asked the question. You have nothing to lose by trying.
