Signal integrity and Cables...
rwgast_logicdesign
Ok so I dont have a scope and im not real sure what the best practice in this situation is...
I have two motors each have a piece of flat ide like 6 conductor cable with a female header on the end, the length of these wires is 6cm. The 6 conductors are +18v, Motor Ground, +5v, Logic Gorund, Hall based Encoder A, Hall based encoder B. My issue is I need to extend these cable we will say a MAXIMUM of 6 inches probably more like three or 4 though. If I just use some cheap cat5 (have spools of it so its easily available and pleantiful) to extend the 6 wires will I have any issues getting a clean signal off my encoders? What if I just used 6 wires heat shrinked maybe wrapped in foil? In this instance would a 74xx244 or 74xx425 maybe help boot the signal, I know it will help clean them via its schmitt triggers, but there waves already look good no need to clean the signal if exxtending the wire lenghts is gonna be ok.
I plan to have all kinds of sensors that will probably need 6 inch extensions on them in this project, I know twisting the cables helps but is there anything i need to take in to special consideration?
To be more paranoid take the motor supply and ground along a separate twisted pair away from logic level signals - should further precaution be needed.
[ for 6 inches this is overkill of course! ]
