Blinky Blinky RC Airplane Lights
xanadu
[video=youtube_share;zqv8cyJkHlY]
Sure, it needs a little more work.
Airplane Anti-Collision, Position, and Nav light testing
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
VAR
long beacons [100] 'stack space
long strobess [100] 'stack space
PUB main
'enable output pins
dira[16] := 1 'green nav
dira[17] := 1 'land/taxi
dira[18] := 1 'red nav
dira[19] := 1 'white pos
dira[20] := 1 'beacon/AC
dira[21] := 1 'strobes
cognew(beacon, @beacons)
cognew(strobes, @strobess)
repeat
outa[16] := 1
outa[17] := 1
outa[18] := 1
outa[19] := 1
PUB beacon
repeat
outa[20] := 1
waitcnt(clkfreq * 1 + cnt)
outa[20] := 0
PUB strobes
repeat
outa[21] := 1
waitcnt(clkfreq / 10 + cnt)
outa[21] := 0
outa[21] := 1
outa[21] := 0
outa[21] := 1
outa[21] := 0
outa[21] := 1
outa[21] := 0
waitcnt(clkfreq * 2 + cnt)
C.W.
But the rotating beacon needs work.
Go out to the airport and watch one again for a few minutes.
It doesn't just blink on and off.
There are a lot of little brief low intensity flashes that leak through between the rotating parts.
Yes, thank you. I'm actually a pilot and see them all the time. I'm trying to find a publication that states exactly what it is supposed to do but apparently just like strobes it varies my manufacturer. The light intensity and viewing angle are set in stone.
My red beacon isn't going to flash like a real airplane, I want it on more than off for visibility flying the airplane at night
However, the rotating mechanism isn't strictly a requirement. Just the blink pattern.
For practical reasons lamps aren't usually bright enough to send the blink pattern omnidirectional.
There are xenon arc lamps that can do it but are very expensive compared to the less costly rotating lens version.
For small scale RC use flashing LEDs actually can produce the exact "Legal" requirement.
Duane J
Aerodrome beacon
And
Airway beacon
Duane J
The requirements for aerodrome beacon flash rates are different and they are different colors depending on the type of aerodrome.
Sandy
Look closely at how the rotating beacon is built.
There are (USUALLY!) three lenses mounted in a rotating frame.
So there is a low level "glow" between the lenses then the bright "flash".
I'd launch the rotating beacon in a different cog.
Pulse width modulate that LED down to a steady background "glow",
then pulse it on hard for the flash.
For night flying, I'd leave the wing tip position lights on rather than blink.
That's the way they are on most light aircraft anyway.
I get exactly what you're saying and appreciate the feedback. This is why in my original post I said it still needs some work lol.
Thanks, my FAR doesn't have part 25, guess that is why I never saw it. Anyway this was never meant to be FAA legal and I want to be able to see it well so I might just leave it on most of the time with a small blink, closer to 100 flashes per minute.
Either way I can't wait to put this puppy on my RC airplane.
I had something like this in mind...
A nice little throb - with a blink or two.
I tried this with a large red LED and a 220 ohm resistor.
I suspect that the resistor could be smaller for a brighter light.
It spends quite a bit of time off, so it shouldn't heat the IO up much.
It's not Jonny Mac, of course!
But it puts a bit of action in the thing.
See what you think?
{ Beacon.Spin } CON _CLKMODE=XTAL2 _XINFREQ =5_000_000 MSec = _XINFREQ / 1_000 USec = _XINFREQ / 1_000_000 Tshort = Usec * 400 Tlong = Msec * 350 Tsteps= 50 VAR Byte X, LED PUB Throb LED := 9 dira [LED] :=1 Repeat Repeat X from 1 to Tsteps step 2 outa[LED] := 1 waitCNT ((X*Tshort) +cnt) outa[LED] := 0 waitCNT ((Tsteps-X+1)*Tshort+cnt) outa[LED] := 1 waitcnt(Tlong +cnt) Repeat X from 1 to Tsteps step 2 outa[LED] := 1 waitCNT ((Tsteps-X+1)*Tshort+cnt) outa[LED] := 0 waitCNT ((X*Tshort) +cnt) repeat 20 outa[LED] := 1 waitCNT (5*Msec +cnt) outa[LED] := 0 waitCNT (25*Msec +cnt)Kids...
Jim
I just loaded it and it blinks a little fast, but THANKS! I can modify this and also learn a little more about spin in the meantime. I'd like to have it pulsate more than turn completely on/off.
