MC14489 - driving higher current displays
xanatos
Hi, I'm driving some large 7-segment displays that have several LEDs per segment. I'm using MC14489 chips but I will need to use external circuitry to actually drive the displays, since I need at least 8v and around 40ma to light them up. I'm thinking 2N3906 PNP on the 5 common cathode lines and 8 2N3906 npn on the segment lines. Am I missing anything in this scheme?
Thanks!
Dave
Thanks!
Dave
Thanks for your thoughts,
Dave
Thank you and I'm sorry for bothering!
No bother, happy to help - if I can... I have to dig a bit to get that schematic. I'll post when I find it.
So here's the schematic piece I made, and the PC Board layout. The left-most chip is the BS2xx I used. p13, p14 and p15 are running to the MC14489, and the three remaining "chip pad patterns" are really not chips, but are actually chip sockets stuffed with my TLP781 opto-isolators). The two at the top of the image are driving the segments, the one at the bottom right is driving the commons via a 2N2222 or 2N3904 - any GP switching NPN will do. The column of 8 pins at the upper right are the segment outputs, and the 4 below that are the digit commons.
If you look at the pinouts for the MC14489 and the TLP781, you should be able to recreate the schematic. You should also be able to see where the discrete resistors go, and the few surface mount items go in between the pads in the BS2 and the MC14489.
Good luck & have fun!
Dave
Have a great day!
1- is the 2n3906 transistor that is driving the common anodes a PNP?
2- if I want to drive 4 single large segments with only one MC14489 do I just wire together all the segments of the four displays?
Thank you so much and I swear this is the last time asking too much questions.
Have a great day!
