Hi Tim, Jim and John, thanks for all the tips, the GPS is working fine now.
Once realizing it was really a 648 and after disabling the static navigation with ID 143 as suggested by Tim the GPS is updating coordinates all the time for very short movements.
Code I used to sent the configuration strings bellow.
Thank you!
Diego
Modification to: GPS_Str_NMEA_Lite.spin v1.0
PUB StartCOGs(rX_FR_GPS,tX_TO_GPS,nmea_Mode,nmea_Baud) : oKay | i
GPS_UART.str(string("$PSRF100,0,4800,8,1,0*0F",_CR,_LF)) 'Switch to SiRF binary protocol at 4800,8,N,1
'Diable Static Navigation
waitcnt(clkfreq + cnt)
repeat i from 0 to 9
GPS_UART.tx(BYTE[noparse][[/noparse]@DisStatNav])
'Switch back To NMEA Protocol Message ID 129, leave only GGA and RMC strings and keep speed at 4800
waitcnt(clkfreq/2 + cnt)
repeat i from 0 to 31
GPS_UART.tx(BYTE[noparse][[/noparse]@BackToNMEA])
Dear Diego,
If I send ID143 to the PMB-648, will it save this configuration? Or do I have to do this with every power up?
I'm having a similar problem with the PMB-648 updating lat/long coordinates for a slow moving mobile robot (or, walking with the GPS, for that matter). The GPS is connected correctly to an Arduino Mega 2560 and I'm able to retrieve GPS data using the TinyGPS library. Does anyone have sample Arduino code that will turn static navigation on/off?
The following will turn it off:
Using 4800 baud send/Serial.print
this string:
("$PSRF100,0,4800,8,1,0*0F",\r,\n)
followed by this series of Hex bytes
0xA0,0xA2,0x00,0x02,0x8F,0x00,0x00,0x8F,0xB0,0xB3
To clarify:
re. the bytes --
Serial.print(0xA0, BYTE);
Serial.print(0xA2, BYTE);
and so on
Thanks very much for this, PJ. And thanks for the additional link. One other question: is WAAS enabled by default on the PMB-648? It is my impression that it is. If not, how does one turn it on? The SiRFstar IIII documentation is a bit confusing in this regard and the PMB-648 datasheet is unclear as well.
I haven't looked into that. You've stumped me. (Didn't want to leave you hanging w/ no reply.)
I have recently purchased a parallax PMB-648 and have fallen victim to the static navigation situation, I need speed to update below 3 MPH and it obviously isn't. I have been trying like crazy to make this work. I am connected to, and am working with, Arduino.
This is the (Arduino) code (to try to disable it, only relevant portions copied) that is in my setup routine. I am using software serial on pins A3, A2. they are connected to the TX0 and RX0 (TTL) pins on the module. I assume those pins are what I want to use?
Ahh, this was my problem too. I have the 648, and it was only updating after I got half way down the block. Not good for my purposes. Thanks to this thread, I can now add the appropriate strings in my init code, and it will operate properly. I'll make the modifications (using a bs2 for testing) and perhaps then I can get output more often. That should help.
Thanks for the work guys.
However, I would be interested in finding out whether or not the 248 gives better accuracy. So if you've tried it, and found out, please let us know.
BUT.. I just download BST onto a new Windows 7 machine, and I may not have set all the proper configurations yet for BST files, etc.
Jim
Jim
It reverts to stock config after a couple of days if unpowered.
this string:
0xA0,0xA2,0x00,0x18,0x81,0x02,0x01,001,0x00,0x01
0x00,0x01,0x00,0x01,0x01,0x01,0x00,0x01,0x00,0x01
0x00,0x01,0x00,0x01,0x00,0x01,0x12,0xC0,0x01,0x61
0xB0,0xB3
http://forums.parallax.com/showthread.php?143222-bs2-gps-lcd&p=1137310&viewfull=1#post1137310
To clarify:
re. the bytes --
and so on
First post on the forum.
Seemed good to place the question here.
#include <SoftwareSerial.h> SoftwareSerial nss(A3, A2); nss.begin(4800); nss.println("$PSRF100,0,4800,8,1,0*0F"); nss.write((byte)0xA0); nss.write((byte)0xA2); nss.write((byte)0x00); nss.write((byte)0x02); nss.write((byte)0x8F); nss.write((byte)0x00); nss.write((byte)0x00); nss.write((byte)0x8F); nss.write((byte)0xB0); nss.write((byte)0xB3); nss.write((byte)0xA0); nss.write((byte)0xA2); nss.write((byte)0x00); nss.write((byte)0x18); nss.write((byte)0x81); nss.write((byte)0x02); nss.write((byte)0x01); nss.write((byte)0x01); nss.write((byte)0x00); nss.write((byte)0x01); nss.write((byte)0x00); nss.write((byte)0x01); nss.write((byte)0x00); nss.write((byte)0x01); nss.write((byte)0x01); nss.write((byte)0x01); nss.write((byte)0x00); nss.write((byte)0x01); nss.write((byte)0x00); nss.write((byte)0x01); nss.write((byte)0x00); nss.write((byte)0x01); nss.write((byte)0x00); nss.write((byte)0x01); nss.write((byte)0x00); nss.write((byte)0x01); nss.write((byte)0x12); nss.write((byte)0xC0); nss.write((byte)0x01); nss.write((byte)0x61); nss.write((byte)0xB0); nss.write((byte)0xB3);
Any help to make this work would be appreciated!!!! Thank you!
Roto.
