Freebie: Soundcard Oscilloscope
                    Haven't tried it myself, but it looks like fun...  Free for personal use.
http://www.zeitnitz.de/Christian/scope_en
http://www.youtube.com/watch?v=ZRCn9pdgYsg
http://www.fastquake.com/2012/02/simple-transistor-amplifier-circuit-schematic-and-explanation
1. opto-isolated inputs
2. opamp preamp front ends with limited peak output voltage.
I actually have built an opto-isolated version of the 'sound card oscilloscope' interface powered via a 9 volt cell and used it for decoding IR remote controls. There is actually quite a bit one can do with a scope that is limited to about 30Khz. Rs232 serial is not problem.
http://www.sciencetronics.com/greenphotons/?p=459
Would you mind sharing your circuit for this? I think I'd like to give it a go.
Jeff
Peter..
Darn! I knew someone was going to ask, but I have yet to locate a link for the opto-isolated version yet. I do have a printout of the schematic that I used to build it .... somewhere around here.
I actually would prefer the better accuracy of the op amp version now. But with the opto-isolated version you can be absolutely sure nothing bad will reach the sound card or the computer internals.
I'll have to dig a bit further. Ham Radio enthusiast are using 1:1 600ohm transformers to fully isolate the auto signals from their other equipment. If isolation is the primary issue this may be as good or better than the opto-isolators.
Here is another op-amp solution that looks good to me.
http://www.infinitespectra.com/howtos/soundcardtips/soundcardtips.htm
I am finding lots of solutions - op amps, zener diodes, isolation transformers, resistor networks.... but nothing about my opto-isolators. I build this back in 2005 and haven't a clue to where the plans went. Web sites come and go.
It may not have been the best of solutions anyway because it was dependent on what the LEDs did and that pretty much restricted it to DC logic inputs of certain levels.
http://xoscope.sourceforge.net/hardware/hardware.html
http://www.ledametrix.com/oscope/index.html
