L298N Dual Stepper Motor Driver Controller - How do they make money on this?
A Chinese ebay vendor has an L298 H Bridge board available for less than $5 post paid.
http://www.ebay.com/itm/L298N-Dual-Stepper-Motor-Driver-Controller-Board-Module-5V-For-Robot-Smart-Car-/180793346663?pt=LH_DefaultDomain_0&hash=item2a181f8a67
How on Earth are they making money on this? Solarbotics sells a kit for nearly $20 and I built one using parts for more than $5.
In order to help prevent a few broken hearts, I believe something should be clarified. The advertised title is misleading and this stepper driver is not intended to run two stepper motors. The word "Dual" is intended to refer to the bridge configuration contained on the IC chip. As it pertains to this board, which contains an L298N IC, the L298N IC is a dual full-bridge driver, which has the capability of driving two phases and reversing directions, and it has the ability to drive two regular DC motors or one bipolar stepper motor. However, I suppose a person could drive two stepper motors with this driver by wiring the motors in parallel, but in that case each stepper motor could not be controlled individually.
If you already ordered one expecting it to run two stepper motors, please don't blame Martin, because it appears he just copied eBays title
Bruce
http://www.ebay.com/itm/L298N-Dual-Stepper-Motor-Driver-Controller-Board-Module-5V-For-Robot-Smart-Car-/110942422752?pt=LH_DefaultDomain_0&hash=item19d4af06e0
I might just need one...
The prices reach a point where you have to buy one on the principal.
No, you're just paying more to have a blue one....
