accelerometers, 2 or 3 axis
ok so i ended up with 2 of the parallax memsic 2 axis accelerometers today.
I looked at the store and noticed that the memsic 2 axis is the same price as a 3 axis. does anyone know why this is?
What exactly is the 3rd axis for? the 2 axis has x,y and tilt, so can a 3 axis do x,y and then z for height movements?
i know an accelerometer can measure accelration, force, and vibration but can it be used to track distance and speed on the axis? like can i use these things to figure out my bots gone 20ft at 2 miles an hour? is it a suitable replacement for an optical mouse sensor?
i also have a 3 axis out of a wii chuck, so im just really tryin to find out in what situation i would use which accelerometer. and im also curious if theres any benefit to using 2 2axis over a 3axis becuase you get a 4 axis.
Nowadays, nearly all low end accelerometers are 3 axis. There isn't much reason to keep them 2 axis anymore when they're all being put in cell phones.
Mathematically, there is no benefit to using two dual axis accelerometers over one triple axis accelerometer. In practice you could use the redundant axis to provide noise reduction.
also i agree a 3 axis is cheap but if you have two 30 dollar 2 axis accelerometer why throw them a way. im still failing to see the need of a 3 axis in most applications that arent flying. what would you use a z for on a robot traveling on the ground
MEMS accelerometers are not very good - noise is high and linearity errors are in around-a-percent range. "Real" accelerometers used in inertial guidance systems are many orders of magnitude better in performance (and have to be).
Remember most of the time these MEMS devices are only being used to measure the _angle_ of the accelation vector due to the earth's gravity.
While some accelerometers don't care about being upside down or not, based on the memsic documentation, I think the memsic would provide more accurate readings when mounted right side up. I think mounting a memsic accelerometer at 90 degrees from level (in order to gain a third axis) will greatly reduce its accuracy.
After lookng over the memsic documentation, I'm guessing its advantage over a 3 axis version is it may be easier for a Basic Stamp to use the pulses the memsic module uses to communicate than having a BS try to read from a different module with some other protocol.
