repurposing solar path lights, MODS Plz mv to general discussion
so i scraped an assortment of solar cells from the 2.5 to5v range out of those solar path lamps.
first of all i was wondering of cleaning them up with sand paper and rubbing compound was ok, maybe even beneficial.
since there all different, if i were to put them in series how would this effect the max amperage, is it the output of the lowest cell?
Yes that is correct, max amps is the amps of the lowest output cell.
They get pretty cloudy after a year or two - I think the plastic is not UV rated. I used to polish scratched CDs with silver/brass cleaner so that might be worth a try.
im trying to figure out the best way to make a grid that can trickle charge 9.6 to 12v of niMH. basically the idea is to just extend the battery life a bit while the batteries are in use
