Quickstart freezes when held in hand: Fixed with tape on bottom
I was just testing out RamPage2 this morning with a Quickstart and noticed that my Quickstart would sieze up if my fingers touched something on the bottom of the board... It didn't reboot, it seemed to freeze.
So, I did a bit of playing around and I think it's touching the XI and XO holes under the crystal that are the most susceptible.
Also, touching around the XI pin on the 40-pin header will do it too, but you have to try harder.
Anyway, I decided to put tape on the bottom of the board, over the crystal and the 40-pin header.
This prevents it from freezing. Just a little worried that the PLL might die without this...
Frankly, I think exposing the crystal inputs like that is a bad design decision. I'm not really sure what benefit it has at all...
To use a different crystal you have to unsolder a resistor from the board. Why not just unsolder the crystal?
And, why have XI on the 40-pin header? I think that would only very rarely be desired...
But, I don't think it really matters too much, unless this is happening to a lot of people besides me...
Or, if this is actually damages the Prop's PLL. It does freeze up, but maybe not really doing damage...
It simply makes the quickstart a little bit more workshop friendly (with wires llying around ;o)
Nicely done, how thick is that ?
Caution!! All tape can produce static charges when pealing from the role.
To discharge this charge "Breath Heavily" on the glue to deposit a film
of moisture before applying to the board.
Packing tape is quite robust especially with 2 layers.
The "best" tape to us is that brown colored "Kapton" tape as its very tough
to mechanically puncture. A bit expensive though.
Duane J
