Floating Point Programmable Scientific Calculator.
Hi All;
If there an application that is essentially a "Floating Point Programmable Scientific Calculator".
I didn't see one in the OBEX.
So here is the challenge. Write a reasonable Scientific Calculator. It should be able to have these features:
1. Ideally it should be a replica of an HP15C but other calculators may be acceptable models.
2. The number system should internally use 64 bit binary IEEE 754.
3. The input and output should be, like the calculators, in decimal, scientific, or engineering notation as well as the IEEE 754.
4. Programming should work similar to forth, with stacks, but with floating point numbers, just as in the HP15C.
5. In general, I see the human interface as a terminal. But I suppose an LCD and keyboard would also work.
Most programming languages can use 32 bit integers because the applications are restricted but run fast.
Speed is much less important for scientific applications. I see this more for as a calculator.
However, unlike my HP15C I could have measurement inputs and driver outputs.
Does this sound doable?
I'm not a programmer so I don't think I can do this in any reasonable way.
I'm more of an "Appliance User" of GWBasic, FemtoBasic, Forth, and Spreadsheets.
This could be a very useful application.
What do you say guys?
Duane J
Duane J
Codeviper wrote a 32-bit floating point calculator program. It uses a slightly modified version of F32 (IIRC it was modified to make it easier to use from multiple objects).
It uses a TV for output and a keyboard for input. It shouldn't be hard to modify to use a terminal program instead of TV and keyboard.
See others at the HP Calculator Museum.
I only mention the HP15C as its my current favorite.
This calculator has a very limited program storage and was strictly hand loaded. But I really liked how it operated. The HP41 and HP48 are other good models. I really didn't like the HP28 though.
Duane J
No Decimal or Hex or Binary ?
RPN and stacks was ok for numeric-only, limited char displays, but shouldn't a Prop Calc with a Keyboard (either direct, or terminal)
allow a more line-editor approach ? - it will nearly always have a multiple line display ?
This PC one CCalc (100 digits) has a line editor & supports multiple eqns, semi colon delimited.
http://www.zoesoft.com/blog/
http://www.rayslogic.com/Software/Rays_RPN/RayRPN.htm
should be easy enough to port with GCC or Catalina...
Nicely presented. A little light on displayed digits for my liking. What is the internal precision ?
CON _clkmode = xtal1 + pll16x ' use crystal x 16 _xinfreq = 5_000_000 OBJ tch: "Touch" ' touchscreen driver PUB Main | touchtest ' debug value tch.BeginProgram Calculator tch.SetWarmBoot ' clears screen, sets a warm boot and reboots PUB Calculator | xval,yval,address,ascii,operand,font,a,b,answer tch.Clearscreen(%00000000_00000000) ' so something happens immediately tch.ClearRam tch.SDBMPtoRam(string("calcpic.bmp")) ' file 2 tch.DrawBMPRam(2,0,0) ' draw the picture font := tch.Loadfont(string("DSdig.ifn")) ' file 3 in the ram disk, use this number when printing fonts tch.stringdim(10) ' file 4is strings group, create some string space tch.stringclear(0) ' use string 0 tch.SelectSPIGroup ' talk to the spi touchscreen repeat yval := tch.TouchYPercent ' decode yval 0-100% xval := tch.TouchXPercent ' decode xval 0-100% if (xval <> 255) and (yval <> 255) ' valid keypress tch.SelectMemGroup ' disconnect spi and talk to display 'tch.hex(xval,2) ' debugging address :=1 ' button doesn't do anything = default case (yval*32)/10 ' convert 0-100 to 0-320 as easier to work with pixels off the picture 60..101: address :=0 ' row of a 4x6 matrix 104..140: address :=4 146..183: address :=8 187..222: address :=12 228..265: address :=16 271..307: address :=20 case (xval*24)/10 ' column convert percent to 0-239 0..66: address += 0 67..119: address +=1 120..172: address +=2 173..239: address +=3 ascii := lookupz(address: "X","Q","Q","Q","C",8,"/","*","7","8","9","-","4","5","6","+","1","2","3","=","0","0",".","=") case ascii "X" : return ' close the calculator "C" : tch.stringclear(0) ' clear the current string CalcClear "0".."9" : tch.StringAddChar(0,ascii) ' build the string CalcClear tch.StringPrint(font,0) ' print string "+","-","*","/" : tch.StringCopy(1,0) ' copy string 0 to string 1 tch.StringAddChar(0,ascii) ' display these too so can see typed something CalcClear tch.StringPrint(font,0) ' print string tch.StringClear(0) ' clear working string operand := ascii "=" : a := tch.StringVal(1) ' second value b := tch.StringVal(0) ' first value case operand "+" : answer := a + b ' add "-" : answer := a - b ' subtract "*" : answer := a * b ' multiply "/" : answer := a / b ' integer division tch.StringStr(2,answer) ' store answer to string 2 CalcClear ' clear the display ready to print the answer tch.StringPrint(font,2) ' print the answer tch.SelectSPIGroup ' restart the spi group if display something tch.pause1ms(250)' only display once so delay half a second to "debounce" PUB CalcClear tch.ClearRectangle(25,21,220,48,tch.GetBackFontColor) ' clear an area the same color as the font background tch.SetCursor(25,15)
In the latest PropGCC (still not released, but the adventurous can build it from source from the "performance" branch) the floating point code is much smaller and more efficient, and David's calculator will fit in CMM mode even with 64 bit doubles: I tried it and it seems to work fine. There's not a lot of space left for other drivers (screen, touchpad, etc.), though perhaps some could be stored in EEPROM.
Eric
You need the line editor because it's hard to keep algebraic notation straight. Once you know how to properly use RPN it's much easier than algebraic, and you don't need a line editor because at any given time you're looking at an intermediate result on the display, not a middle of edit cursor.
Do you have a quick resource summary of that ?
Main RAM usage, how many COGS and what was in each COG ?
This would make a great education/benchmark for Prop I and Prop II
David's expr program, compiled in CMM mode with the performance branch PropGCC and 64 bit doubles, takes 31424 bytes of HUB RAM. Only one COG is used, (the main one) so there's lots of room for drivers there, which is why I suggested that storing some drivers in EEPROM might work well.
64 bit doubles give 15 decimal digits of precision (very nearly 16, actually); 32 bit doubles give 7 digits, so if that's enough precision then it's probably worth dropping down to 32 bit "doubles". The saving is pretty significant, both in code and data. The expr program takes only 25900 bytes of HUB RAM using 32 bit doubles.
Eric
Sounding impressive. 64 bits is the clear winner, given it fits, and this is a great test & bench vehicle for 64 bit libraries & CMM.
With many COGs spare, could some be used for GCC->PASM blocks, as co-processors ?
A Calc does not need cutting edge video, so it would be a good place to see what GCC-Display could look like
(ie code written (mainly) in GCC, compiled to target PASM in COG & Keyboard IO )
Too cool! I've been using XCALC for years. It's a great tool, but yours is so cute!
Just out of interest, I compiled Dave's expr program with Catalina. The only thing I had to do was substitute strcmp for strcasecmp (strcasecmp is not an ANSI function). You can do this on the command line. When compiled with CMM and 32bit floats, the total program size is about 16K of HUB RAM (code size ~14Kb, and data size ~2Kb).
The commands I used (for the C3) were:
catalina expr.c -lc -lmb -C C3 -C COMPACT -C TTY -D MAIN -D strcasecmp=strcmp payload expr -i
Of course, Catalina saves some space by using the Parallax Float32 OBEX component. There is no equivalent for 64 bit floats, but I've found a 64 bit floating point implementation in ANSI C that looks quite interesting. I may include it in a subsequent release of Catalina. Using that, the program size would go up to about 20kb.
Ross.
Ah! Should have read the whole thread before posting - yes, David is quite right. For instance, if you have a 64Kb EEPROM and compile the program to use the Catalina EEPROM loader, you can use any of the available Catalina HMI options (e.g. TV or VGA, HiRes or LoRes).
For instance, to use HiRes VGA only requires a slight modification to the commands I gave previously. Again, this is for the C3:
catalina expr.c -lc -lmb -C C3 -C COMPACT -D MAIN -D strcasecmp=strcmp -C HIRES_VGA -C EEPROM payload EEPROM expr
One of the nice things about Catalina is that the Hub RAM used by the application remains the same no matter what plugins you use - so this version still has a code size of about 14k and data size of 2k. Of course, the VGA buffers will now take another chunk of Hub RAM (about 6k for HiRes) but you would still have another 8k or so left for more code - more if you used LoRes VGA or TV HMI options instead.Ross.
catalina expr.c strcasecmp.c -lc -lmb -C C3 -C COMPACT -D MAIN -C HIRES_VGA -C EEPROM
Makes almost no difference to the code size.
Yes, I keep hoping someone will write a 64 bit equivalent - it would save me a chunk of work!
Ross.
I wrote one for PropGCC (http://forums.parallax.com/showthread.php?142523-using-a-COG-as-a-floating-point-coprocessor); it handles both the 32 bit and 64 bit cases, although the 32 bit code is quite a bit slower (since it converts to 64 bits internally). Porting it to Catalina probably wouldn't be hard. I've attached a Spin version here, although there's no actual Spin interface yet (it's just the raw PASM code plus a C interface in the comments, which spin2cpp can recognize).
Eric
No, the reverse -- PropGCC's 32 and 64 bit code are both IEEE compliant. As far as I know it and the Double.spin/fpucog.c coprocessor that I wrote are the only IEEE compliant implementations for the Propeller. Float32 and its derivatives (including, I believe, Catalina's floating point) use 32 bit IEEE format but the operations are not quite IEEE compliant. For example, they implement a non-standard rounding mode, and do not distinguish between NaN and infinity.
The paranoia program (http://www.netlib.org/paranoia/) is an excellent test of floating point operations, and a good way to check the quality of IEEE floating point implementations,
Eric
That's great Eric - thanks. I'll look into adding this as a Catalina option - I can probably slot it right in in place of the current floating point plugins. I think it would be slower than Catalina's current implementation even for 32 bit floats, but I know there are some people who seem to think 64 bit floats are necessary.
Ross.
But, if you really want to do a nice calculator, then 64-bits would be nice.
That said, I did program a calculator for the old Timex Datalink USB that was only 16 bits and that is good enough for many things too...
