BS2 power supply
I know this probably sounds like a stupid question, but can I run my Basic Stamp Homework Board on a 12v power supply? I know that the BS2 itself can run at 12v, and there is a 5v regulater for the I/O pins. I just want to make sure that using 12v isnt going to harm the board. And I assume that if the board is run on 12v then Vin would also be 12v.
One other thing to consider is that if you're using Vin on the Servo header, then you should use a 7.5vdc wall wart for power in. Although our servos are technically only rated for up to 6 vdc, I've ran them @ 7.5vdc for extended periods of time with no problems... at 8.2 or 8.3 you'll start smokin' servos - well, you know what happens when you let the "magic smoke out"...
-MattG
