ARM busts out server-to-superphone superchips
Bob Lawrence (VE1RLL)
ARM busts out server-to-superphone superchips - Low-power juggernaut takes two more steps towards world domination
By Rik Myslewski in Santa Clara Get more from this author
Posted in Servers , 30th October 2012 22:40 GMT
ARM TechCon ARM has rolled out a new series of processors the Cortex-A50 Series that it says will find their way into everything from smartphones to mega-data centers.
The beefier member of the two-chip series has already found at least one data-center home in future ARM-based Opteron server chips, as announced this Monday by AMD.
The processor design that AMD chose, the high-performance Cortex-A57 (formerly code named "Atlas"), was unveiled along with its low-power sibling, the Cortex-A53 (née "Apollo"), by ARM processor honcho Simon Segars during his keynote on Tuesday at the ARM TechCon 2012 conference in Santa Clara, California.
Describing the A57 as "the highest-performance processor from ARM," Segars said that it would provide "PC-class performance in a superphone power envelope." (An ARM spokesman told us that by "superphone", ARM means devices such as the Samsung Galaxy S III and the iPhone 5.)
The Cortex-A53, on the other hand, was described by Segars as "the most energy-efficient processor that we have built," providing superphone-level performance at not only low power levels, but at low cost as well.
Simon Segars, EVP and general manager of AMD's Processor and Physical IP Divisions, at ARM TechCon 2012
Both the A57 and A53 employ the 64-bit extensions to the ARMv7 architecture that were announced when the 64-bit ARMv8 architecture was unveiled last October at that year's ARM TechCon. They're not limited to 64-bit code however; they'll also run existing 32-bit code without a hitch, thus easing the transition to the inevitable all-64-bit, all-the-time future.
In case it is not too obvious, we'll point out that to run both 32-bit and 64-bit code, the operating system being run on the A53 and A57 will have to be 64-bit. But you knew that.
Source:http://www.theregister.co.uk/2012/10/30/arm_cortex_a50_series_announcement/
"The first AMD64-based processor, the Opteron, was released in April 2003".
So 11 years behind the X86, and final performance still comes down to Process, and Memory and Data Links.
Still you can't stuff a Opteron in a cell phone or any of the Intel egg cookers that are called CPU's. AMD and Intel may rule the desktop market, but it's not growing anymore. They're not capturing other markets with their ancient x86 power guzzling devices either. ARM's are.
before it changed to Advanced Risc Machine
Depends what is behind what. ARM have been a bit busy in those 10 years making sure all our phones, smartphones. tablets and any number of gadgets with embedded processor work. Emphasis here being on small, low power consumption and cheap. Features that Intel are clearly behind with.
I'm not sure where the 64 bit ARMs will go. Do we really need 64 bit processesors in phones? In the server space they might make sense if they can deliver decent performance with lower power consumption.
Yep, and now I can run the original Archemides operating system on a 30 dollar Raspberry Pi and have that Archie I could not afford at the time.
