SphinxOS - latest version?
Hi guys,
I am working on demos for a couple of my products and I have a couple of questions:
1) which is the latest version of SphinxOS?
http://forums.parallax.com/showthread.php?114023-Sphinx%E2%80%94as-seen-at-UPEW!/page10
message #188, "SphinxOS v011c" the most up to date version?
Or is there an even newer release somewhere?
I modified the version on sphinxcompiler.com to run on PropCade a while ago, and now that I want to get it running on a few more of my boards I want to make sure I start with the latest code base.
2) Is there an editor I can use for SphinxOS that can support a text display of 80*25 or 30 columns?
I'd like to use it with my single cog 80 column driver.
Bill
Bill
I'm not aware of an editor for an 80 x 25 display. The existing display driver keeps the video buffer in the cog to save hub space. I assume your driver keeps the buffer in external RAM.
I also found a "tools" thread at http://forums.parallax.com/showthread.php?114210-Tools-for-Sphinx&p=821109#post821109
No, my driver uses the hub for the buffer and the font; I was hoping to find an editor that used an SPI ram for the text buffer.
Hmm...
I can:
1) try to find the time to write such an editor
2) declare such an editor to be "impossible", thus causing it to be born
Thanks Mike.
(found it at http://forums.parallax.com/showthread.php?119225-PrEditor-Alpha-005&highlight=preditor)
However, it doesn't run the same as Sphinx. I wanted to also be able to use Michael's Sphinx compiler on the prop. But for this to work, I needed to make part of Kye's SD driver resident. I have not had the time to do this yet
Here is a link to the OS I was working on last and use regularly. http://forums.parallax.com/showthread.php?138251-A-Propeller-OS-that-can-run-on-multiple-hardware...&highlight=propeller+os
Latest code is at the end. It uses Homespun to compile and there is a batch compile file to do it in one step. No external RAM is required, just a basic prop and SD card. Currently uses the USB connection via P30/31 though this is easily changed.
