push button routine
I have a NO push button when I press the button my debug changes btn2=0 to btn2 = 1. When btn2 = 1 then mode = mode + 1. When mode =1 then light a led.
IF Btn2 = 1 THEN
mode = mode + 1
IF mode = 1 THEN HIGH 14
IF mode = 0 THEN LOW 14
I'm sure theres a few ways to get it to latch.
It dosent matter how long I hold down the push button the debug terminal shows a constant value of 1 for Btn2. The modes debug value constantly changes from 0 to 1 depending on how long I hold the button. I need the mode led to only change once no matter how long I hold the button. Im not sure how to code it? If I could get a suggestion for this portion I can work on the rest.
Overview:
The code is part of a larger controller/ boe bot/ xbee project. Eventually I'd like when mode = 1 then my left right joystick controls the ping servo's movement proportional to the joystick.Instead of turning the boe bot. While sending the ping readings to the controllers lcd screen. If not during the movement just after movement stops send the ping reading.
If you want to see more of the codes I have I can post them. Thanks ahead of time.
IF Btn2 = 1 THEN
mode = mode + 1
Overview:
I'd say, post your code so we can see all the nuances. :thumb:
I'm not understanding the explanation/description given.
'{$STAMP BS2} '{$PBASIC 2.5} 'Recieving Boe Bot ' -----[ Constants ]------------------------------------------------------- L_FWD CON 1000 L_REV CON 500 L_STOP CON 750 R_FWD CON 500 R_REV CON 1000 R_STOP CON 750 CmConstant CON 2260 InConstant CON 890 BAUD_MODE CON 84 '---Variables------------------------------------------- UD VAR Byte LR VAR Byte a VAR Byte b VAR Byte c VAR Byte d VAR Byte e VAR Byte f VAR Byte Btn1 VAR Byte Btn2 VAR Byte cmDistance VAR Word inDistance VAR Word time VAR Word mode VAR Byte '---Pin Descriptions------------------------------------ xbee_rts PIN 9 xbee_Rx PIN 10 ' Dout xbee_Tx PIN 11 ' Din nInp PIN 12 'Define the input pin of servo pal Alarm PIN 13 'Define the alarm pin of servo pal HM55B_clk PIN 0 HM55B_en PIN 1 HM55B_Din_Dout PIN 2 Bi_clrLEDred PIN 6 ' when high + low 7 Bi_clrLEDgreen PIN 7 ' when high + low 6 ping PIN 15 ping_servo PIN 14 '---initializations------------------------------------ INPUT nInp 'Make sure nInp isn't being driven. DO : LOOP UNTIL nInp 'Wait for ServoPAL to power up. LOW nInp 'Set pin to an output and hold it low PAUSE 100 ' for 100mS to reset ServoPAL. HIGH nInp 'Raise the pin. PAUSE 100 '---main program------------------------------------------ DO SERIN XBee_Tx\xbee_rts, 84, [WAIT("!"),UD,LR,Btn1,Btn2,mode] PULSOUT 15, 5 PULSIN 15, 1, time cmDistance = cmConstant ** time inDistance = inConstant ** time DEBUG HOME, "Boe Bot Com 13", CLREOL, CR, "UD = ", DEC UD, CLREOL, CR, "LR = ", DEC LR, CLREOL, CR, "Btn1 = ", DEC Btn1, CLREOL, CR, "Btn2 = ", DEC Btn2, CLREOL, CR, "cm = ", DEC3 cmDistance,CLREOL, CR, "in = ", DEC3 inDistance,CLREOL, CR, "mode = ", DEC mode,CLREOL SELECT Btn2 'code locks up when pressed CASE Btn2 = 1 SEROUT XBee_Rx\xbee_rts, 84, ["in",indistance] ENDSELECT 'IF LR = > 140 THEN PULSOUT 14, 1200 ELSE PULSOUT 14,750 'IF LR = < 116 THEN PULSOUT 14, 250 SELECT UD CASE < 90 UD = a GOSUB forwards CASE > 110 UD = b GOSUB backwards CASE 90 TO 110 UD = c ENDSELECT SELECT LR CASE < 110 LR = d GOSUB right CASE > 140 LR = e GOSUB left CASE 110 TO 140 LR = f ENDSELECT IF (UD = c)AND(LR = f) THEN GOSUB stall ENDIF LOOP '---Subroutines------------------------------------------ forwards: PULSOUT nInp, 1000 'Program right servo for full forward. PULSOUT nInp, 500 'Program left servo for full forward. PULSOUT nInp, 10 'Program alarm for 1 seconds. DO : LOOP UNTIL Alarm 'Wait for Alarm. RETURN backwards: PULSOUT nInp, 500 'Program right servo for full reverse. PULSOUT nInp, 1000 'Program left servo for full reverse. PULSOUT nInp, 10 'Program alarm for 1 seconds. DO : LOOP UNTIL Alarm 'Wait for Alarm. RETURN left: PULSOUT nInp, 1000 'Program right servo for full forward. PULSOUT nInp, 2000 'Turn right servo off. PULSOUT nInp, 10 'Program alarm for 1 seconds. DO : LOOP UNTIL Alarm 'Wait for Alarm. RETURN right: PULSOUT nInp, 2000 'Turn left servo off. PULSOUT nInp, 500 'Program left servo for full forward. PULSOUT nInp, 10 'Program alarm for 1 seconds. DO : LOOP UNTIL Alarm 'Wait for Alarm. RETURN stall: PULSOUT nInp, 2000 'Turn right servo off. PULSOUT nInp, 2000 'Turn left servo off. RETURNcontrollers code' {$STAMP BS2} ' {$PBASIC 2.5} ' XBee controller '----------------[Initialize]--------------------------- PAUSE 5 SEROUT 0, 84, [22,12] SEROUT 0, 84,50, [22,17, "Hello", 13, "John"] PAUSE 1000 '---------------[Variables]----------------------------- LR VAR Word UD VAR Word Btn1wrk VAR Byte Btn2wrk VAR Byte green VAR Byte red VAR Byte inDistance VAR Word mode VAR Bit '---------------[Constants]----------------------------- #SELECT $STAMP #CASE BS2, BS2E, BS2PE T9600 CON 84 #ENDSELECT Lcd PIN 0 Btn1 PIN 7 Btn2 PIN 5 Tx PIN 9 ' XBee DIN Rx PIN 10 ' XBee DOUT RTS PIN 8 ' XBee RTS LRjoy PIN 6 UDjoy PIN 4 Led_A PIN 15 Led_B PIN 14 PIEZO PIN 3 stickUD CON 25 stickLD CON 25 Baud CON T9600 capture CON 500 '-------------------------[Main]--------------------------- Main: DO HIGH 6 PAUSE 2 RCTIME 6, 1, LR HIGH 4 PAUSE 2 RCTIME 4, 1, UD UD = UD/3 LR = LR/3 DEBUG HOME, "Controller Com 1" ,CLREOL, CR, "UD = ", DEC UD, CLREOL, CR, "LR = ", DEC LR, CLREOL, CR, "Btn1 = ", DEC Btn1, CLREOL, CR, "Btn2 = ", DEC Btn2, CLREOL, CR, "inDistance = ", DEC3 inDistance, CLREOL, CR, "mode = ", DEC mode, CLREOL SEROUT Rx\RTS, 84, ["!",UD,LR,Btn1,Btn2,mode] IF Btn2 = 1 THEN mode = mode + 1 'GOSUB Get_ping ENDIF IF mode = 1 THEN HIGH 14 'GOSUB Get_ping IF mode = 0 THEN LOW 14 LOOP ' -----[ Subroutines ]-------------------------------------------------------- 'Get_ping: SERIN Tx\RTS, 84, 200, Com_error, [WAIT("in"),inDistance] RETURN Com_Error: ' Handle timeout during tilt controlled navigation DEBUG "A communication error occurred...Reconnecting", CR ' Error message FREQOUT PIEZO, 100, 3000 ' Indicate error PAUSE 100 FREQOUT PIEZO, 100, 3000 PAUSE 100 FREQOUT PIEZO, 100, 3000 PAUSE 1000 GOTO mainOk Im back, took my kids out Trick or Treatn. Yes Erco I have pull down resistors on both of my push buttons. These are the latest codes I have. They are still in a rough design phase. A few lines arent being used. They have the apostrophe inserted. Where I was trying to get a time out function working.
http://www.youtube.com/watch?v=KYnqRgbv6PU&feature=g-crec-u
It's kind of a crappy video, Idk hope it helps
edit: I fixed that also. When mode = 1 the LR joystick only controls the ping servo. The problem of how long I hold Btn2 down and the mode flickering 0,1,0,1 is still an issue. I also still am not getting the ping reading back to the contollers LCD yet.
boe code
'{$STAMP BS2} '{$PBASIC 2.5} 'Recieving Boe Bot '---[ Constants ]------------------------------------------- L_FWD CON 1000 L_REV CON 500 L_STOP CON 750 R_FWD CON 500 R_REV CON 1000 R_STOP CON 750 CmConstant CON 2260 InConstant CON 890 BAUD_MODE CON 84 '---[Variables]------------------------------------------- UD VAR Byte LR VAR Byte a VAR Byte b VAR Byte c VAR Byte d VAR Byte e VAR Byte f VAR Byte Btn1 VAR Byte Btn2 VAR Byte cmDistance VAR Word inDistance VAR Word time VAR Word mode VAR Byte '---[Pin Descriptions]------------------------------------ xbee_rts PIN 9 xbee_Rx PIN 10 ' Dout xbee_Tx PIN 11 ' Din nInp PIN 12 'Define the input pin of servo pal Alarm PIN 13 'Define the alarm pin of servo pal HM55B_clk PIN 0 HM55B_en PIN 1 HM55B_Din_Dout PIN 2 Bi_clrLEDred PIN 6 ' when high + low 7 Bi_clrLEDgreen PIN 7 ' when high + low 6 ping PIN 15 ping_servo PIN 14 '---[Initializations]------------------------------------ INPUT nInp 'Make sure nInp isn't being driven. DO : LOOP UNTIL nInp 'Wait for ServoPAL to power up. LOW nInp 'Set pin to an output and hold it low PAUSE 100 ' for 100mS to reset ServoPAL. HIGH nInp 'Raise the pin. PAUSE 100 '---[Main Program]------------------------------------------ DO SERIN XBee_Tx\xbee_rts, 84, [WAIT("!"),UD,LR,Btn1,Btn2,mode] PULSOUT 15, 5 PULSIN 15, 1, time cmDistance = cmConstant ** time inDistance = inConstant ** time DEBUG HOME, "Boe Bot Com 13", CLREOL, CR, "UD = ", DEC UD, CLREOL, CR, "LR = ", DEC LR, CLREOL, CR, "Btn1 = ", DEC Btn1, CLREOL, CR, "Btn2 = ", DEC Btn2, CLREOL, CR, "cm = ", DEC3 cmDistance,CLREOL, CR, "in = ", DEC3 inDistance,CLREOL, CR, "mode = ", DEC mode,CLREOL SELECT Btn2 'code locks up when pressed CASE Btn2 = 1 SEROUT XBee_Rx\xbee_rts, 84, ["in",indistance] ENDSELECT SELECT mode CASE = 1 IF LR = > 140 AND mode = 1 THEN PULSOUT ping_servo, 1200 ELSE PULSOUT ping_servo,750 IF LR = < 110 AND mode = 1 THEN PULSOUT ping_servo, 250 ENDSELECT SELECT UD CASE < 90 UD = a GOSUB forwards CASE > 110 UD = b GOSUB backwards CASE 90 TO 110 UD = c ENDSELECT SELECT LR CASE < 110 LR = d IF LR = < 110 AND mode = 0 THEN GOSUB right CASE > 140 LR = e IF LR = > 140 AND mode = 0 THEN GOSUB left CASE 110 TO 140 LR = f ENDSELECT IF (UD = c)AND(LR = f) THEN GOSUB stall ENDIF LOOP '---[Subroutines]------------------------------------------ forwards: PULSOUT nInp, 1000 'Program right servo for full forward. PULSOUT nInp, 500 'Program left servo for full forward. PULSOUT nInp, 10 'Program alarm for 1 seconds. DO : LOOP UNTIL Alarm 'Wait for Alarm. RETURN backwards: PULSOUT nInp, 500 'Program right servo for full reverse. PULSOUT nInp, 1000 'Program left servo for full reverse. PULSOUT nInp, 10 'Program alarm for 1 seconds. DO : LOOP UNTIL Alarm 'Wait for Alarm. RETURN left: PULSOUT nInp, 1000 'Program right servo for full forward. PULSOUT nInp, 2000 'Turn right servo off. PULSOUT nInp, 10 'Program alarm for 1 seconds. DO : LOOP UNTIL Alarm 'Wait for Alarm. RETURN right: PULSOUT nInp, 2000 'Turn left servo off. PULSOUT nInp, 500 'Program left servo for full forward. PULSOUT nInp, 10 'Program alarm for 1 seconds. DO : LOOP UNTIL Alarm 'Wait for Alarm. RETURN stall: PULSOUT nInp, 2000 'Turn right servo off. PULSOUT nInp, 2000 'Turn left servo off. RETURNcontoller code' {$STAMP BS2} ' {$PBASIC 2.5} ' XBee controller '---[Initialize]------------------------------------------------- PAUSE 5 SEROUT 0, 84, [22,12] SEROUT 0, 84,50, [22,17, "Hello", 13, "John"] PAUSE 1000 '---[Variables]--------------------------------------------------- LR VAR Word UD VAR Word Btn1wrk VAR Byte Btn2wrk VAR Byte green VAR Byte red VAR Byte inDistance VAR Word mode VAR Bit '---[Constants]---------------------------------------------------- #SELECT $STAMP #CASE BS2, BS2E, BS2PE T9600 CON 84 #ENDSELECT stickUD CON 25 stickLD CON 25 Baud CON T9600 capture CON 500 '---[Pin descriptions]--------------------------------------------- Lcd PIN 0 Btn1 PIN 7 Btn2 PIN 5 Tx PIN 9 ' XBee DIN Rx PIN 10 ' XBee DOUT RTS PIN 8 ' XBee RTS LRjoy PIN 6 UDjoy PIN 4 Led_A PIN 15 Led_B PIN 14 PIEZO PIN 3 '---[Main]----------------------------------------------------------- Main: DO HIGH 6 PAUSE 2 RCTIME 6, 1, LR HIGH 4 PAUSE 2 RCTIME 4, 1, UD UD = UD/3 LR = LR/3 DEBUG HOME, "Controller Com 1" ,CLREOL, CR, "UD = ", DEC UD, CLREOL, CR, "LR = ", DEC LR, CLREOL, CR, "Btn1 = ", DEC Btn1, CLREOL, CR, "Btn2 = ", DEC Btn2, CLREOL, CR, "inDistance = ", DEC3 inDistance, CLREOL, CR, "mode = ", DEC mode, CLREOL SEROUT Rx\RTS, 84, ["!",UD,LR,Btn1,Btn2,mode] IF Btn2 = 1 THEN mode = mode + 1 'GOSUB Get_ping ENDIF IF mode = 1 THEN HIGH 14 'GOSUB Get_ping IF mode = 0 THEN LOW 14 LOOP '---[ Subroutines ]-------------------------------------------------------- 'Get_ping: SERIN Tx\RTS, 84, 200, Com_error, [WAIT("in"),inDistance] RETURN Com_Error: ' Handle timeout during tilt controlled navigation DEBUG "A communication error occurred...Reconnecting", CR ' Error message FREQOUT PIEZO, 100, 3000 ' Indicate error PAUSE 100 FREQOUT PIEZO, 100, 3000 PAUSE 100 FREQOUT PIEZO, 100, 3000 PAUSE 1000 GOTO mainCODE REVISED see here http://forums.parallax.com/showthread.php?143290-xbee-not-recieving-proper-values
post #8
Looking at your code there is no use of the BUTTON command as debounce and when you press the button you could be adding +1 to the variable "mode" several times,you're conditions only allow for mode to be 1 or 0 you need to make sure mode cannot be higher than 1 if the button contacts bounce or if the button is pressed more than once by putting something like IF mode >1 then mode =1 in your code.
You see, what that does is to cause mode to flip only when the button input makes the transition from 0 to 1. So you have to release the button and press it again to flip the mode back.
