Return to Center Pot for steering & rocker pot for throttle?
I'm working on a remote control for a 4 wheeled robot. I've been using a Futaba 9C but I just don't care for steering with a joystick.
I want to put a steering-wheel on the remote control like the ones that come on car/truck remotes. I have several Traxxas car/truck remotes and they all have mechanical pieces and a spring external to the pot to bring the steering wheel back to the center position.
Does anyone know of a potentiometer with a built-in return-to-center (rtc) feature? I suppose an encoder could be used too.
I'd be willing to rip apart a PC or game controller if it has a pot with a rtc feature. I thought about using a bunge cord to return the pot to center but I'd need a pot with the shaft sticking out the back to attach the bunge to.
I would also like a rocker-style pot for the throttle control that would rtc.
Any thoughts or suggestions.
falcon
falcon
or here: http://www.etisystems.com/joystickselect.asp
http://www.ebay.com/itm/Traxxas-TQ3-Remote-/181004954144?pt=US_Character_Radio_Control_Toys&hash=item2a24bc6a20
That Mouser part was a 3 position switch, not a pot. I looked around their site and found no rtc pots. Have you ordered from ETI Systems? They have a rocker pot that looks like it would work for the throttle.
W9GFO,
Both of those Ebay auctions are for Trassax controllers. I have several of them already and the rtc feature is external to the pot. I'm trying to find a pot with an internal rtc.
I appreciate the replies,
falcon
As Rich suggested, repurposing an RC pot with external mechanism is likely a more affordable option.
Somewhere at home I have some beautiful tiny 2-axis return to center joysticks with a very nice feel. If I find a manufacturer on them, I'll advise in hopes that they may have 1-axis pots.
W9GF0
I can picture what you described, and I think that could work. I ripped open an old thrustmaster PC steering wheel and found a typical long-shaft pot with a bunge cord attached to it. The cord was stretched and each end was anchored. That provided the rtc. I can use normal pots while I do the electrical design. This should give me more time to figure out the best solution.
Thanks for your advice.
falcon
Opinions?
falcon
