Really Stupid Question
If I have an external button that has a constant 4.89 volts on it, and when you press the button it breaks the circuit. How can I emulate this on my board. I can't just use a HIGH command because the external button has its own circuit and power. Any help would be appreciated.
The schematic shows a normally open relay but you'd want a nomally closed relay. Many relays have one pin for normally open and another for normally closed.
I don't use Stamps much so I'm just guessing a 500 ohm would be an okay value for R1. I hope someone corrects me if I'm wrong.
You want to use a diode across the relay coils to protect the Stamp from voltage spikes caused by the coil. You want the diode whether or not use use a transistor.
BEAT THAT, Duane Degn! Low power, no transistor, no resistor! Just yer typical flyback diode.
While you're ordering from EG, get a few of these adapters on sale for $1.69, they can power a BoE: http://www.goldmine-elec-products.com/prodinfo.asp?number=G17336
