A robot that flies like a bird
Plenty of robots can fly -- but none can fly like a real bird. That is, until Markus Fischer and his team at Festo built SmartBird, a large, lightweight robot, modeled on a seagull, that flies by flapping its wings. A soaring demo fresh from TEDGlobal 2011.
http://www.ted.com/talks/a_robot_that_flies_like_a_bird.html
Have to say as soon as I saw the subject I thought "that'll be those Festo guys again" - having seen their wonderful bio-mimetic robots before. For instance http://www.youtube.com/watch?v=F_citFkSNtk
I am amazed every time I watch a butterfly or moth in flight. Their wing motion is completely different from a bird and provides a very erratic-looking flight path. Imagine it from their point of view. Talk about the ultimate in image stabilization and path planning to fly from A to B.
I wonder what sort of motors they are using? Would a servo be powerful enough or would they use a brushless motor with a gearbox?
It looks like each wing has two motors so that would give you directional control.
Have we enough collective smarts on this forum to build this?
Sure, but I want to build one, too!
As far as I can tell, there is only ONE motor that drives both wings, and the folding and rotation of the wings is a function of the linkage, and steers is controlled by the direction of the beak and tail, like in real birds. But I'm just guessing.
I tried looking for some technical details but couldn't find any with a quick search. I agree, if I was designing this I'd have a single powerful brushless motor through a gearbox running to linkages to both wings, and then I'd add and subtract a little from that movement with individual servos. I think you need rotation as well as being able to alter the lift on either side (eg if a gust of wind catches it on one side and tries to flip it over).
Actually, for full control you want to replicate all the muscles of a bird. Particularly when coming in to land and flapping the wings fast for a hover. I am more and more amazed at the way birds come in to land on my bird feeder, dodging between branches and ducking between narrow gaps.
? 6 servos, 3 on each side, - one for amount of wing flap, one for rotation of the wing and one for the tail? It adds up to a fair bit of weight though.
Weight is the enemy of things that fly. This one doesn't take off and land, and looking at the guts in the vid I think its 1 motor and 1 servo. And the battery only lasts for 90 seconds. But I still want one.
The german bird looks a bit more expensive than the french one.
http://en.videobuzzy.com/Avitron-RC-Ornithopter:-Remontely-Controlled-bird-341.news
Enjoy!
Directional control is an interesting issue as seagulls do heavily depend of their tail movements to assisting in turning, but it seems the presentation is ignoring what the tail actually does.
Can we build one in this Forum? The structure looks like carbon fibre, then there are those gears that look custom plastic, and the interior structure of the wings may have been done via some sort of 3D printer. Added to all that is shaping the outer shell from some sort of foam sheet plastic via vacumn molding.
I think we have the smarts. Shared resources is another thing.
if anyone wants to draw a frame, i will print it if i can get it into stl
i will also buy a brushless air craft motor i have been wanting one for months
how hard could it be?
