faulhaber 141:1 motor specifics, and genral dynamics?
rwgast_logicdesign
@loopy where are u getting the info from faulhaber about this motor? also u mentioned halving the final gear does faulhaber sell gears for this motor, where would i obtain smaller gears that work in this motor?
ok so i used this site
http://www.technobotsonline.com/robot-speed-calculator.html
to calculate my speed with these motors running 6 inch wheels. I just wanted to make sure i was getting the right numbers. here is whatbi entered, these are the no load specs at 6v
rpm 13,400
gear ratio 141:1
wheel diameter 152.4 (6inch)
it said my bot would go .7mph or .77 m/s which i think is meters per second, converted that is 2.5ft a second, is this correct.
if that is right how does this equal out when the motors are under load, and when voltage is raised?
also can anyone with experince with these motors tell me how loud they are?
rpm 13,400
gear ratio 141:1
Basiclly 1 pulse per revolution of the driving motor for both phase A and B, with there being 90 degrees between them which is usefull for precission quadrature speed and direction detection.
Remember, the actual gear ratio is 140.759183:1.
So there would be 140.759183 pulses per output revolution.
Duane J
my other questions specically about this motor is how loud is it? and would how accurate is a low res encoder? would a hi res optical encoder after the gearing be pointless?
I am not sure that a lot higher encoder resolution is really worthwhile as you have your counters rolling over more and that would require watching them more closely for navigation purposes. This would be nice to use with the 32bit Propeller.
All in all it is a good fit. I suggest you go directly to the Faulhaber site to get good information directly about their motors and encoders that are similar to what you have. I have not done it for this motor, but I did it for others and was quite pleased that they provided so much.
What would be good torque. With 20ma at 6v, the best you can expect is .120 watts when 746 watts equals one horsepower. More torquey would be in the tens of watts -- say 10 - 30 watts. But those motors from Faulhaber with encoders and gears are easily over $100 USD each. EBay does sell them used at times.
Regarding doing something with the final gear...
It appears to be attached with a set screw. Once you have the motors, you can remove it and put on something else - any ratio that will work physically and provide the right speed with adequate power. But you will have to find gears somewhere else. In some case, you won't need a set screw as the torque is so low - just glue on with epoxy.
And of course, as said before, the actual wheel size with change the encode rate for distance. You won't know what you have until you actually finished building it.
Also can anyone with experience with these motors tell me how loud they are?
I give up. At 0.120 watt of power, do you really expect a lot of noise? I can barely hear those silly piezoelectric speakers that Parallax provides. Even a 0.5watt 8ohm speaker is rather useless. So think hifi - if it isn't 3 or more watts, it isn't loud. Over 15 watts is way too loud.
I'm using it in a solar tracking heliostat application so it hardly turns at all.
It has a tiny cog belt output, I have some of these tiny belts, for a further gear reduction of 12:1.
Torque? I don't have a good way of measuring it. I can easily stall it with my thumb.
Remember, this is a fairly small high precession motor.
I'm not sure it is suitable to drive a 6" wheel directly.
6" wheel implies a heavy car and possibly over taxing the motor.
I can hardly hear the thing run.
The encoder is low resolution at 1 pulse per motor revolution.
140.759183:1 * 12:1 = 1689.110196:1 on the output is adequate for my purposes.
Duane J
