KILLER DEAL 2.95 6-18v gear motor most likely with encoder
rwgast_logicdesign
https://www.goldmine-elec-products.com/prodinfo.asp?number=G18335 I wasted so much time looking for a drivetrain for 4wd that was affordable and I just found this picked up 6, under blowouts they also have 6 and 4 inch wheel sets for a buck
I'm sorry, that motor looks just like the Faulhaber motor.
Anyway here is some data that might still apply.
Here is what I gleaned about that motor last spring:
Faulhaber Right Angle Gear Motor
you guys dont think this is gonna work out? i mean at surplus price the beuhler u mentioned has a 20 dollar price..
@duane why are you sorry? you guys dont think this will live up to my expections?
I think your decimal place is off by one. The motors draw 0.02 amps (20mA).
I wish Electronic Goldmine gave some torque information other than "Features high torque". "Features high torque" compared to cell phone vibrator motor? A stall current would also be nice.
You can at least learn how to program with these. And repair or replacing the ribbon cable can't be any harder than working with surface mount packages.
I bet the encoder works the same though. And the Micromo is a re-badged Faulhaber.
I was sorry because I jumped the gun and assumed it was the Faulhaber just by looking at the picture.
Duane J
https://www.goldmine-elec-products.com/prodinfo.asp?number=G16279
here is micromo
the description reads exactlty the same. as a matter of fact when i type faulhaber into the search micromos motor comes up, and the review linked to above also says the micromo and faulhaber motors are the same.
so looking at these specs at the review the motor seems pretty week
@duane since you acually own these motors what do think about using them on a 5lb size rover?
if nothing else 2.95 for for 141:1 gear box is a good deal maybe i can adapt the gears to my two current motors to build a 4wd set uo.
Faulhaber provides detailed info on rpm performance at various voltages. You have to visit them and find out what their specs are.
Mircomo is at 6V 20ma and 80rpm. Higher voltage would allow a smaller gear to double the rpm. The Faulhaber says the same thing, so their reference may be good for both.
http://forums.parallax.com/showthread.php?143379-faulhaber-141-1-motor-specifics-and-genral-dynamics&p=1137720#post1137720
No, I don't think you'll get it to work on a robot that big. These motors are as big as a slightly larger than average male index finger (for reference). One thing to be careful about is mounting the motor. The gear on the output shaft has a very small and unusual size setscrew, so it's difficult to remove. The motors that I have seen usually have the wheels attached directly to the robot.
You should rename this thread, not create a new one.
http://www.robotroom.com/FaulhaberGearmotor.html
Also look through the similar threads links at the bottom of this page.
Do you have a way of measuring the current of the small (but not too small) motors? I'm curious how much they draw with both no load and as you try to stop them.
Thanks for the info. I had missed the Robot Room link. You're right, it does have a lot of good information.
I ordered some of these motors. They seem like they'd work well at the end of an leg of some sort. I purchased enough to make a Mars rover type bot with a rocker-bogie suspension.
I wonder how these motors/gear box/encoders compare with the motors/gears/encoders of a Rover 5 chassis? I suppose I'll find out shortly.
another tip is i got cordless 6v 130rpm screw drivers for the gearing and motors on a rover. they are good at 12v fairly quiet for a power tool and genrally hi hi torque motor set up for 2 dollars. the only issue is the planetary ring is molded as part of the chuck/cap
