avr crystal choice
rwgast_logicdesign
ok so i have about 4 avr projects i need to upgrade from the internal ocillator and i cant figure out what crystals im supposevto use! i asked on avrfreaks that place **** never got an answer.
i just need to kmow the load capacitence id assume 22pf but digikey only has 20pf 16mhz amd 20mhz xtals.
also i pulled a 16mhz ceramic oscillatoter out of a radar detector using an atmega32. i noticed it had caps under the oscilator although my my arduino uding a 3 pin ceramic has no caps. do i meed 22pf caps on the oscillator or not?
That 3 pin device has the caps built in. Yes, you will need external caps on a crystal.
The value is only critical if you are ppm-paranoid, and the general Osc Phase/Gain margin issues, see smaller caps used at higher frequencies.
I learned it is rather difficult to do properly.
First, you have to have the right information from the crystal vendor about capacitance.
And even then, the big manufacturers test all the crystals at their factory to verify their quality.
I figured that I might be able to test myself, so I looked around and found the device that does so is available, but costs thousands of USD.
The only real option for the little guy is to build and check with an oscilloscope after the fact. You cannot just read off the PDF an appropriate capacitor as they don't know what you have for a crystal.
But be aware that you can't just hang your oscilloscope probe on a crystal lead. That will throw off everything. But you can have the microcontroller toggle a pin and verify. In the worst case, the crystal just hangs and won't oscillate - change the caps and try again. Or change the drive setting and try again.
The easiest solution is to use resonators that include capacitance all in one package. (that is why they have that third pin for ground) Resonators have gotten nearly as good as crystals, maybe better in some situations.
It is so much easier to just buy a BasicStamp or a ProtoBoard and use it.
Radio amateurs have developed low-cost techniques for characterising and matching crystals.
Thanks.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=445-2568-1-ND&site=US&lang=en
does it require load caps? i noticed two smd caps soldered under it, before i pulled it. I know the three pin redonators dont require caps.
I was pretty tired last night not sure why i was looking for a 22pf xtal... i need a 12pf, obviously the ideal number would be 11pf but that doesnt take into account pin capacitence. my confusion came from knowing wether to go up or down on the pf to account for pin capacitence. Although this is why we use 20pf caps on a prop when the load capaccitence is 36 based on the data sheet its 18pf plus some
do we really need to be so pc about a forum on the internet... it has no feelings and it is the worst forum ive ever been on.
Of course, that requires a capacitance meter. Do you have one? If not, desolder them and use them as well.
So far I have not had any problems with crystals - but they can either not oscillate or under some circumstances oscillate at the wrong frequency.
If you look in Digkey or Mouser you will see lots of crystals at any frequency with different capacitor requirements. And some would argue that the capacitors should not be the same value - but the truth is that capacitors are never exactly the same value.
http://media.digikey.com/pdf/Data Sheets/TDK PDFs/FCR_Rev2011.pdf
If you are really sure it is an FCR series, the above PDF may help.
The suggestion about the title is something I would have suggested as well. There really isn't any reason for it and can reflect poorly on you.
What value does it add by slamming another site?? That just seems like a distraction. It doesn't have anything directly related to the technical issue you have. You could just ask your question and state that you haven't been able to find an answer on any other forum. No need to mention any more.
They are actually feedback capacitors, not load capacitors, although their value depends on the crystal load capacitance as I mentioned.
Two pin resonators do require capacitors.
If you don't want to it's up to you but a link to your post might shed some insight.
@leon ok so if a schematic calls for 24pF caps a crystal with a 12pF load capacitence should be chosen correct? As i understand it a 3pin resonator has a normal accuracy of about 99% while a 30ppm crystal is about 99.7% accurat. So im gonna take a guess and assume a 2 and 3 pin are the same accuracy the only difference is a 3 pin has feedback caps built in. So when would 2 pim be a better choice, when your producing hi volume and wanna save every penny? is price the only reason to go with a 2pin?
You also need to take manufacturing cost and board area into account. A 3 pin device might work out cheaper and save on board size.
Not quite.
Yes, 3 pins have the Caps inbuilt, but now they are supplied and measured by the vendor, so the combination can be more precise.
(Murata spec 0.2% for their 3 pin 5MHz model) - 3 pins also has less PCB area, and less EMI and less BOM...
A quick search at Digikey for 5MHz, shows 3 pin are cheaper and 2 pins are NRND, so that shows the volume users are now all using 3 pin, and the 2 pin are in low-volume-runout
0.2% is just really nice if you are going to try to internally run a real time clock function.
