Stepper with driver.- source commentary please.
Does anybody has an experience with this source?
I am collecting parts for my first stepper controlled application.
I understand steppers are not designed for torque, so I will have to couple this motor with suitable reduction / transmission.
I am looking for easy control and torque, positioning/repeatability and speed is secondary.
http://www.ebay.com/itm/Stepper-Motor-5V-4-Phase-5-Wire-Driver-Board-/261118237469?pt=LH_DefaultDomain_0&hash=item3ccbdc1b1d
There is an entire thread devoted to this kind of stepper motor.
http://forums.parallax.com/showthread.php?141149-3-Stepper-Motor-amp-Board
I'm sure there is the best place to get all the answers you want.
Hope it helps
Yanomani
I didn't order from that individual, but I imagine all the ones from the same location with free shipping are in the same office.
I also imagine they are wearing rags and chained to the desks, and make 1% as their cut, if they lose a customer, their family will starve. But I have a vivid imagination.
Point is, if they have free shipping, and offer a bunch of other stuff you want too, AND they have high rating, it is probably worth the risk and a cheaper source thatn anything local.
Even if they game the ratings, at least it shows they care enough to put in the effort, and have a likelihood of following through.
So far all my order from Shenzen(?) were satisfactory. I haven't tried any that said simply "china"
I did find some steppers with gearboxes also. Lacking the experience and any means to measure torgue I guess I;ll have to just test it for smoke.
I did find some miniature geared motor, but without a controller and much more $.
Since I need to stop and reverse the direction when the devices - tunning capacitor and roller inductor - are at the end, using stepper to count revolutions is obviously less hardware than any other way.
If you are looking for a solution like this one:
http://www.tomthompson.com/radio/Antenna%20Tuner/tuner.html
then maybe you can use a DC motor with tachometer feedback like the one Beau Schwabe cited in this thread:
http://forums.parallax.com/showthread.php?143183-DIY-motor-feedback-from-mouse-parts./page3
whose direct link is:
http://www.ebay.com/itm/251172557043?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648
I'm suggesting you to use any kind of feedback you can get because I don't know your exact application. Without any feedback you can't be assured that your tunning capacitor or roller inductor hit the point that you supposed they will be.
Yanomani
I am not concerend about the position of either C or L , I measure SWR externally to the coupler. I just need simple "end of the run" indicator. I understand that DC motors have pronounced stall current but not sure if stepper motor can be monitored same way.
Hope it helps.
Yanomani
